Old 08-07-2011, 09:17 PM   #1
Wellington , Nevada
May day! May day! I have a leaking Argosy
I all, I have a 1975 28' Argosy that I am trying to find all the leaks in the fresh water system. I method is to attach the hose, turn it on, and listen. I have done pretty well until I heard one that seems to be under the area where the inverter is in the far driver's side corner of the coach. I can't see the leak, all I see if water pouring out from the belly near the grey/black water tanks. My questions are:
Does any one know where that line is going in there?
Does any one know how to access the area without ripping out the sink?
Does any one have a picture/schematic of the fresh water system?
Does any one have any suggestions about rebuilding the fresh water system?
Does any one know where Jimmy Hoffa is?
I will consider 4 out 5 answers a perfect score.
Thanks folks.
BP
bpappas is offline   Reply With Quote
Old 08-07-2011, 10:12 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
I don't have a clue. Welcome!
My trailer came with a pop off valve stuck open and two drain valves left open. I assume somebody slammed the system with a shot of compressed air to knock the pop off valve out of it's seat.
I fixed the pop off, found the drain valves, shut them off and my system held pressure and my pump worked, then I tore it all out and threw it away.
Old 08-08-2011, 03:20 PM   #3
Wellington , Nevada
I wish mine was that easy. I have leaks from broken lines and right now a complete rebuild, even though it needs it, isn't an option.
BP
Old 08-08-2011, 03:44 PM   #4
Bfrank's Avatar
1979 24' Airstream Excella 24
Adams , Tennessee
leaks
Make sure that the valves for draining the system are closed as the PO may have had the system open after winterizing there should be two or three valves under the fridge or sink I don't know about an argosy but if hooking to city water if they are open will look like a heck of a leak till you realize they are drains and they got left open.
Frank & Lisa Sullivan
Bfrank is offline   Reply With Quote
Old 08-08-2011, 04:20 PM   #5
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Compressed air imight be better and does not damage the floor..... Just an after thought. Not too much pressure.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-08-2011, 04:56 PM   #6
Baltimore , Maryland
They all leak
Wally and Jimmy Hoffa are touring Europe together.
Old 08-08-2011, 09:00 PM   #7
Wellington , Nevada
Winterizing valves are closed. Change the term leak to torrent, there is a major hole is something. How are the lines for the shower routed? I even borrowed a borescope to see if I could see something and it is very tight back behind vainity and the toilet. I was mistaken, it doesn't look like the are any water lines under the inverter area. Any ideas? Glad the Hoffas are having fun.
BP
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 25 08-25-2018 01:46 PM
'74 Argosy 20' MH - stripped... value? Robbo Argosy Motorhomes 2 07-14-2011 10:37 PM
Argosy shakedown cruise to Tyler State Park DKB_SATX Our Community 18 06-27-2011 09:06 AM
It's a GREAT day when ....... RangerJay Airstream Lifestyle 0 03-31-2011 01:56 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
