03-09-2016, 01:08 PM
#561
Richmond
, Kentucky
Slightly backward would be perfect from the height you're installing it at. I think I've figured out a way to mount my camera up high where the center lights are above the window.
Originally the upper rear lights are mounted directly to the shell. I plan on using some of those aluminum plinths like those used for the side marker lights and adapt one of them to hold one of the cameras. Shouldn't be difficult and should make it less noticeable.
1975 24' Argosy Motor Home
03-18-2016, 08:09 AM
#562
1982 31' Airstream 310
champaign
So are the wiresless cameras just not up to snuff yet? Not dependable?
03-18-2016, 09:08 AM
#563
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Personally I use a lot of wireless technology for work, and if I can run a wire, I will always run a wire. Standardization in wireless technology helps but (at least at the moment) the performance is still compared to the "Gold Standard" of a direct connection.
Wireless is for convenience not performance....
03-21-2016, 08:50 AM
#564
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
03-21-2016, 09:24 AM
#565
Richmond
, Kentucky
Panel replacement looks good. I'm assuming they used Olympic rivets since your interior walls are in place.
Getting closer
03-21-2016, 12:29 PM
#566
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Not to throw a grenade into discussions on other threads but they claim Airstream service bulletins approve the use of Olympic rivets....
03-21-2016, 12:55 PM
#567
Richmond
, Kentucky
My Argosy is plastered with Olympic rivets. I'm fairly certain most of them were done at the factory based on where they were used.
03-27-2016, 10:30 AM
#568
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Bella's new wheels arrived yesterday (set of ION 167 Alcoa look-a-likes, new caps and lug nuts)
Too late to get some rubber on them this weekend. Hopefully that will happen before the end of the week, to allow the existing (new) tires/rims to come off Bella and get taken to fit on Peanut, to get him back on the road by next weekend.
03-27-2016, 10:56 AM
#569
Richmond
, Kentucky
How does the wheel quality look?
Would you mind posting a picture of one of the lug nuts? I'm curious what style was supplied.
03-27-2016, 10:58 AM
#570
1977 Argosy 24
forest city
, North Carolina
what do you think
we found a 77 -24 , it had not been opened in lets say 35 yrs or more , everything inside is like new, 8 track still works , carpet is shag covered with clear runners ,stove has never been used ,did have to replace the curtains .tires, bearings and a few bulbs . my ? is should i keep it as is or not.from the trip log that was inside it was used twice since new, i like the old school. W
What say YOU
03-27-2016, 11:08 AM
#571
Richmond
, Kentucky
What say YOU
Dennis, did you find a trailer or a motorhome?
03-27-2016, 11:36 AM
#572
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The wheel quality looks great. Front and rears are different. Rear are -127mm offset polished on one side, front are +102mm polished both sides, all are 3200lb rated. They were made in China (but I guess everything is nowadays) and the center caps are just chromed plastic but look OK.
The lug-nuts are a little funky.
They supply an adapter to allow standard 6 sided lug-nut to be used
03-27-2016, 11:53 AM
#573
Richmond
, Kentucky
Interesting lug nuts. Whatever you do don't lose that socket!
03-27-2016, 11:54 AM
#574
champaign
Those are good looking wheels!!
03-27-2016, 12:21 PM
#575
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Thanks Mike, it is one of the advantages of the early 20s, they use standard 1 ton GMC wheels so we have a bit of the choice.
03-27-2016, 12:27 PM
#576
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
What say YOU
Is it a rear bath, twin or double Dennis?
04-20-2016, 03:32 PM
#577
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
First photos of Bella totally in her new base coat.
Its not very clear but that also means the new lower front valance is fully installed and the new insulated ceramic roof coat also in place. Also the first proper look at the new wheels.
Three weeks to the 'Get Together' as we are pretty much exactly on schedule.
04-20-2016, 03:53 PM
#578
Richmond
, Kentucky
Wow! That's impressive
What's the color scheme going to be?
04-20-2016, 04:07 PM
#579
2012 27' Flying Cloud
W
, New England
WOW!!!! That's gonna be a stunner!!
04-20-2016, 04:12 PM
#580
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Modern equivalents to the factory colors.....
44534-A Light Beige
44721-AM Metallic Brown
