Old 12-20-2016, 07:26 AM   #827
This should be the power steering pump that you need.
I'm rather surprised that there are still some out there.
Old 12-20-2016, 10:14 AM   #828
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Bloody hell Martin. Bella isn't willing to go off into the sunset without a fight is she! Just getting revenge for 1812 and you Brits/Canucks burning down the Whitehouse and all public buildings in D.C .
Adds a whole new meaning to "keep a stiff upper lip" my friend.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-20-2016, 02:06 PM   #829
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
The spline lug nut socket and the replacement steering pump are on order (yet another big thank you to Brad for finding the part and offering to receive them and ship on).
Our run of bad luck has continued this evening when our dog Missy had a stroke, and although we rushed her to the vet, she didn't make it. 14 years old which is ancient for a Cavalier King Charles spaniel. Relocated from the UK to the US and back....twice, she had her own passport. Our constant companion and occupier of the 'dog house' whenever we went anywhere in Bella. Hasn't really sunk in yet, but it will.
martin300662 is online now   Reply With Quote
Old 12-21-2016, 11:13 AM   #830
Geismar , Louisiana
Sorry to hear about your troubles Martin. It's hard losing a companion after they've been with you so long. We recently had the same happen. Best wishes.
Dane
Danec020 is offline   Reply With Quote
Old 12-21-2016, 12:02 PM   #831
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
So sorry to hear about Missy 😢
They so crawl in to our hearts - it aches when they leave that spot. I hope years of happy memories help you through.
Old 12-27-2016, 12:52 PM   #832
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by PeterH-Airstreamer View Post
Martin, Before you pull the pan, have someone check the speedometer gear housing seals (there are 2 seals). They are notorious to harden and leak and make it appear like the pan gasket is leaking. A very easy and cheap fix.
Leak seems to be coming from the pan seal Peter.
Although the shops definition of a significant oil leak seems different to mine....leaking yes....significant? It is a 40 years old trans for heavens sake!
Old 12-27-2016, 05:33 PM   #833
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Could also be the governor cover gasket or bolt seal. I had to replace my bolts with pan style bolts to get them to stop leaking.
ID:	277324   Click image for larger version
1996 Airstream B190
1997 30' Excella Wide Body Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-31-2016, 11:20 AM   #834
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Changing topic, I went and collected the portable transformer we are going to use to connect Bella to UK/European shore power today.
I bought a commercial, 'site' (as in, designed to be used on a construction site) 3KVA transformer when Bella first arrived, and made a adapter using a 30amp (US RV plug) dogbone and fitted a 16amp (UK 110V) plug just to get us going, but these site transformers are not capable of delivering good stable power over long periods.
So Marc Harris from the Europe unit WBCCI specified and then built a portable transformer from a 3KVA Airlink toroidal transformer (rated for constant output) into a Pelican case fitted with a European style shore connector on the supply side and a regular 30amp outlet for my Furrion 30amp cable....very neat and only weighs about 25lbs so easily carry-able, and most importantly means no need to change any coach wiring within Bella.
Old 12-31-2016, 11:48 AM   #835
Very cool!
What's the paddle lock for?
Old 12-31-2016, 12:25 PM   #836
Keen amature
1975 20' Argosy 20
Chestfield , Kent
It serves two purposes, the first is to stop anyone opening the case and poking around inside! The more useful is that gives an anchor of a lock and chain to stop someone walking off with the transformer (same issue that folks have when leaving a generator unattended).
Old 12-31-2016, 04:26 PM   #837
Makes sense. That would suck to have something like that walk off.
Old 01-01-2017, 01:37 AM   #838
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hello Martin
You are in the right topic that I am looking for some time. The transformer you bought is 220v-110v 30 amp? How many watts are those 30 amp?
And with that transformer also reach for the air conditioning?
Herman
german6563 is offline   Reply With Quote
Old 01-01-2017, 03:15 AM   #839
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by german6563 View Post
Hello Martin
Herman
Hi Herman, Happy New Year!
Airlink make a range of transformers up to 10KVA, specially for powering American appliances either in the UK or Europe (here is the link to the European page http://www.airlinktransformers.com/a...ge_converters/), however this is only part of the calculation.
If you take the example of one of their 6KVA units, it gives 52amp and 120v, almost the same as the 50amp campground supply BUT needs a 26amp/230V supply. Most campgrounds in UK/Europe only have a 16amp/230V max supply (and often it is lower). It doesn't matter what your transformer will convert it will trip the circuit breaker in the supply.
If you work backwards....the most that will be supplied to the campground is 16amp/230V so the biggest transformer that will stay under that is 3KVA (as I have), which gives 26amp/120V or about 3KW.
This is enough to run a 13.5K AC (with the compressor start-up load) which is at about 20amp, but not if you were using a hairdryer/heater/kettle at the time.
And remember....this gives 120V/50Hz shore power but all appliances have to be able to run on it, it is different from the 120V/60Hz in the US. If you want to plug in any 230V appliances you will need a separate circuit. Which is why many people add a transformer for AC, fridge etc, but also a 230V circuit so you can use local appliances (kettles/hairdryers which don't come dual voltage)
Old 01-01-2017, 05:20 AM   #840
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Martin
Happy New year too
thanks for tip.
only I would like running the AC the rest I have in 12 volt and 220
Herman
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1473 12-07-2018 03:14 PM
Lake Logan Martin Pell City, AL chuman70 On The Road... 0 05-23-2015 05:52 PM
Phipps Park Martin County Florida chaimemet On The Road... 2 12-06-2008 10:28 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 02:21 PM
