Old 10-02-2016, 10:30 AM   #785
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Originally Posted by martin300662 View Post
Dangit!
The Schlange deadlock won't open and I can't get it Bella. I think it is just the cylinder as the my spare key is just turning in the lock as well....time to look for a small child to climb through the window!!!!
Martin - mine failed on me. You can get a replacement cyclinder fairly easily. If it is the same mechanism, you need to be really careful when you open here all up not to drop bits through the outer and inner hull. As a workaround, I was able to open mine up from the inside and manually turn the lock by pliers or hand (can't quite remember). Let me know if you need any more info and I'll try and remember when I did......although still haven't completely finished the job.
Boom Sounds is offline   Reply With Quote
Old 10-02-2016, 10:33 AM   #786
Oh and have a look through the forums. There is a funny square post which Airstream modified to make it all work. From memory, it might even have been Brad who posted some pictures of the bolt and Airstream mod....that is an essential, so you either have to re-use the existing square piece of metal with a kinda hook thing on the end or take the one from your new Schalange cylinder and modify it........or crawl in and out of the emergency windows!
all the best
Nick
Old 10-02-2016, 10:40 AM   #787
Nick, the dead bolt arrangement on Martin's coach is totally different than yours. The db on Martin's is in the door and yours is in the wall. Martin's is a custom add on done by AS NE.
Old 10-02-2016, 03:43 PM   #788
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I think the Schlange was fitted several owners ago. What AS NE did was modify the screen door to add a second gizzy, or rather alumin(i)um flap to allow access to the inside lever of the deadbolt.
The issue is that flap fouls the inside lever and as I found out if the inside lever can't fully rotate then the dead bolt isn't retracted; the outside key can fully turn, without retracting the deadbolt, if the inside lever is fouled.
In the end I was lucky/persistent enough that I found moving the outside key moved the gizzy enough (each turn), that if I could turn, then put pull on the outer door to pull it away from the screen door, I could rotate the key back to 'lock', I could walk the gizzy back to free the lever.
Fundamentally the issue is AS NE added a second panel to the screen door, inside of what they should have done and that was make the first panel larger like a modern screen door to give access to both locks!
So I have this,
And needed this,
What was it Bob used to always say....its never done.
martin300662 is offline   Reply With Quote
Old 10-02-2016, 04:22 PM   #789
Hopefully you won't have to do much to correct the problem.
I still haven't made up my mind whether I want to add a deadbolt. I still have a few weeks to decide
"What was it Bob used to always say....its never done"
Needless to say, I really hope Bob is wrong abut that!
Old 10-14-2016, 05:48 PM   #790
Keen amature
1975 20' Argosy 20
Chestfield , Kent
The deed is done.....I booked the shipping for Bella's trip across the Atlantic today.
First stop when she arrives is at LAS Motorhomes in Roade, Northants. They will change the lights for local regs and the first UK annual inspection. These guys have some experience in working on Classic motorhomes having previously worked on the 'Rush' motorhome (https://www.lasmotorhomes.com/case-s...ream-re-paint/).
Old 10-14-2016, 07:05 PM   #791
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Good luck, Martin!
Old 10-15-2016, 07:29 AM   #792
Good work fella. I've not used LAS, but spoken to the chap and he seemed straight and very knowledgeable. Will be interested to hear your experience with them.
Old 10-19-2016, 02:03 PM   #793
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Sad day, glad I got to see her in person!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 10-23-2016, 06:53 AM   #794
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Shes one of a kind, what great love, time, energy, and commitment youve put into Bella.
Best of luck shipping her across the pond Martin. Its been a great pleasure sharing the process of Bella's resurection here on the forums.
Mike
mayco is offline   Reply With Quote
Old 10-24-2016, 11:50 AM   #795
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks guys, but you wont be loosing me just yet....the reason for buying Peanut was to keep a base in the US and with a little luck and a fair wind, I hope to be at the next Classic Motorhome get-together in Peanut!
Old 10-24-2016, 07:31 PM   #796
I definitely have my fingers crossed
Old 10-24-2016, 07:43 PM   #797
Vycan's Avatar
Manhattan , Kansas
Wait... is your peanut and brad's peanut the same peanut?
Old 10-24-2016, 08:21 PM   #798
Yep...
I'm just the caretaker
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1473 12-07-2018 03:14 PM
Lake Logan Martin Pell City, AL chuman70 On The Road... 0 05-23-2015 05:52 PM
Phipps Park Martin County Florida chaimemet On The Road... 2 12-06-2008 10:28 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 02:21 PM
