Old 08-18-2016, 08:04 AM   #743
Mike, I'm sure others can/will describe it better but from what I understand, when you're going 55 mph or higher it shifts into overdrive. Under 55 mph it drops out of overdrive.
I believe there is also a button on the floor that you can push causing it to shift as well.
I'm looking forward to Martin's driving experience review
Old 08-18-2016, 10:04 AM   #744
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
First impression is very good!
To explain a little the GV comes with the overdrive+speed sensor plus a controller and two switch systems. The controller can be set to various modes, but the one I have it set as is as an overdrive above 3 only. The controller can also be adjusted for what speed to change, I currently have it set to change at 50mph because these gives a even spacing during acceleration from 2 to 3 to OD. That said, that only happens if in automatic mode.
If you look under the dash just to the right of my steering wheel you see the main switch. This allows selection of manual/auto and if in auto the auto light comes on with the ignition and when the OD is engaged the OD light comes on when the speed sensor says so. Basically in auto you do nothing, it changes up at the trigger speed and down at a trigger speed.
However if you need to change down for overtaking, a second switch gets added. This is the additional floor switch you can see next to the headlamp dimmer. Touch that and the OD disengages.
At Interstate speeds Bella is so much quieter it is incredible, and to be honest I can't see myself ever using the 'manual' mode now, the auto works seamlessly.
martin300662 is offline   Reply With Quote
Old 08-18-2016, 10:06 AM   #745
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Ahhhh, for some reason I was thinking it split gears kind of like a two speed set up.
Thanks Brad.
mayco is offline   Reply With Quote
Old 08-18-2016, 10:11 AM   #746
mayco's Avatar
Thanks for the explanation Martin. What kind of drop in rpm did you read while in overdrive?
Old 08-18-2016, 10:18 AM   #747
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I don't have a tacho Mike, but the book says 22%.....If you have a 3-speed, it is roughly equivalent to switching from a TH475 to a 4L80/85E in terms of ratios - maybe even a little taller.
Old 08-18-2016, 01:11 PM   #748
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Mike you can use it to split gears but you have to do it manually with the switches and your shift lever. I leave mine in the auto mode except in the hills where you can use first over, second over or third over as well as first, second, and third direct. With your tach and exhaust gas temp you can pick the gear that makes your engine happy.
The bad or inconvenient thing is the gears a angle cut to stay engaged under load so they recommend not using overdrive going down hill. Also you cannot beck up in overdrive.
With the noise reduction and rpm drop it really is a great improvement to these old coaches.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 08-18-2016, 02:08 PM   #749
mayco's Avatar
Ok, got it. Thank you. I also read somewhere that GV did not make a unit for the Allison AT545, 4sp. (At least at one time they didn't). But, I think on someones thread here on the forums, I read a post that said that they had a GV on their Allison 4sp behind the Isuzu diesel. Anyone else read that or am I hearing voices again?
Old 08-18-2016, 02:39 PM   #750
The GV is normally mounted by removing the tail housing of the trans and installing an adopter and the GV. I don't know if they have an Allison adopter. They do have a provision to frame mount the GV with short driveshaft from the trans to the GV and another drive shaft from GV to differential. Obviously you have fun with custom mounts and driveshaft angles as well as challenging driveshaft, u-joint, and slip joint design and also possible multiple driveshaft and carrier bearing issues. Anything is possible with enough time and money.
Cheers, Dan
Old 08-19-2016, 08:00 AM   #751
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Hmmm....the first downside of having the GV.
It is sooo much quieter inside, that I can hear the AC compressor rumbling under load (flip the AC off and the noise goes away). The compressor is 'new', part of the Classic Auto Air Street Rod III system installed during the rebuild, so a quick trip to the local CAA recommended service shop. They seem to think the compressor is OK, just the it is low on gas (which means a leak), and they can't do a dye leak test. Off to another shop that can do the test but are not on the CAA service network, they can do the work but not for a few days. I have to pop back to the UK for a week or so, so this will have to wait until I come back!
Old 08-19-2016, 02:29 PM   #752
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Bella's new homebase for the next few months....pretty descent stop on a local secure self store.
We can drive from there to any rallies or camping trips for the next few months.
Old 08-19-2016, 06:51 PM   #753
Is the air blowing out the vents cold or just cool?
With an all new system I would have hoped there would be no leaks for years. Hopefully the shop can get it resolved when you take Bella in for service.
Old 08-20-2016, 08:26 AM   #754
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Air is coming out with the same velocity as previously, just not so cold, and with the electric controls switched off the compressor is still spinning just not grumbling about it!
Old 08-20-2016, 10:03 AM   #755
When the AC is turned off the compressor clutch disengages stopping the pump from running. My old 310 had the same sort of rumbling when the clutch was engaged. My assumption at the time was that it needed R12 added.
Old 08-20-2016, 10:14 AM   #756
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I am tempted to get one of the recharge kits available in most auto part stores, just to see if it stops the grumbling!
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1473 12-07-2018 03:14 PM
Lake Logan Martin Pell City, AL chuman70 On The Road... 0 05-23-2015 05:52 PM
Phipps Park Martin County Florida chaimemet On The Road... 2 12-06-2008 10:28 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 02:21 PM
