Old 05-24-2016, 05:29 AM   #645
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Martin's Argosy rebuild thread
Deleted double post
Old 05-24-2016, 07:19 AM   #646
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by SteveSueMac View Post
And I missed the inside tour!!!! 😕
Absolutely stunning to see it live. Truly beautiful - congrats!!!
We came around to take a look at the Tin Goat's new door but missed you as well!
We will be at the Diamonds in the Rough rally so can catch up then.
martin300662 is offline   Reply With Quote
Old 05-24-2016, 07:57 AM   #647
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by Philuk View Post
Welcome to our world Martin, expect the same over here when you arrive.When most people step inside the first thing they say is WOW !!!, so expect a double WOW !!! with Bella. ( ours is a little tired inside ) Last weekend we actually had a line of people round to the spare wheel wanting a look inside. & one lady even tried to stop Debbie getting in as she thought she was pushing in ! & as for traveling get used to being looked at & people doing strange things. A couple in a Austin Healey slammed their brakes on in frount of us so that their friends in another car could take their photo with us behind them ?? They then just waved & sped off.
We are off to the Enfield Pagent of Motoring this weekend A large show with quite a lot of American vehicles in a special fenced off area next to the show ring. You can see pics from last year on their website, although we did not get our pic taken ( we are not polished but painted, get used to the comments of 'ruined that Airstream by painting it ' )
So enjoy a new chapter in your life .
Phil
Maybe we will join you at Enfield next year Phil!
Old 05-24-2016, 09:23 AM   #648
W , New England
Let's make this the first thing we do! See you then!
Old 05-24-2016, 11:36 PM   #649
Philuk's Avatar
1975 20' Argosy 20
Coalville , Leicestershire
That would be great Martin, look forward to it
Phil
Philuk is offline   Reply With Quote
Old 06-05-2016, 08:51 PM   #650
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Bella is getting plenty of use, but we have had to delay shipping to Europe until I am sure all the annoying issues are resolved. There are two real 'pains' that so far a couple of mechanics can't get there heads around.
The fast idle does not appear to be something simple (gas cap changed, timing has been checked, chokes are coming off as they should, idle adjusted correctly) and also seems to be related to the load the engine is under; for example Bella can be ticking over fine when sitting in drive and held on the brake, and then races when I put here in neutral - happy to listen to any suggestions.
She had new wheels and tires for the Get Together; I noticed the fronts (and in particular the passenger front) was not holding pressure. The shop worked on the valves and now claim they are holding pressure but we noticed about half way home from the Get Together we started to get a lot of road vibration (through the whole cab but especially the steering) between 25-35mph; above 35mph and it disappears. Feels like the front tires are made of concrete, and it is getting worse. Certainly even when the pressures are correct the vibration is still there. Bella already has new SuperSteer bellcranks, new suspension, brakes (disks, pads and calipers), bearings, steering dampener etc but also has centramatics both front a rear - any suggestions?
Old 06-05-2016, 09:26 PM   #651
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Martin
A PO installed a brand new set of Hercules tires on our 1995 Jaguar XJS convertible. I noticed a vibration and steering shimmy at speeds only between 100-110 kph. I had the wheels rebalance after having the rims refinished, painted and tires remounted. The vibration continued and was discovered to be a bad tire that was completely out of round. The tires can be balanced, sort of, but once out of round they wear differently and quickly go out of balance again. A new set of Pirelli's solved the issue once and for all.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 06-06-2016, 06:29 AM   #652
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Centramatic claims that their balancers start to work at ~35 mph...
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 06-06-2016, 06:38 AM   #653
Sounds like a long test drive to Kentucky is in order.
The fast idle does not appear to be something simple (gas cap changed, timing has been checked, chokes are coming off as they should, idle adjusted correctly) and also seems to be related to the load the engine is under; for example Bella can be ticking over fine when sitting in drive and held on the brake, and then races when I put her in neutral - happy to listen to any suggestions.
Sure sounds like a vacuum leak to me. Possible sources could be the port between the carburetor and the distributor, transmission servo (you replaced this already), carburetor ports and the intake manifold itself could have a bad gasket.
When did you take the first trip with the new tires? I know you swapped tires and gave Peanut Bella's old tires. As Tony mentioned out of round tires can cause vibrations at various speeds. If Bella road fine before and the only thing that's changed are the tires and wheels then my first reaction would be the tires are at fault.
Old 06-06-2016, 07:03 AM   #654
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Good to know Peter
The vibration doesn't feel like normal tire balancing, more like consent chatter; imagine driving over a very corrugated concrete surface - actually feels harmonic rather than out of balance!
Old 06-06-2016, 07:08 AM   #655
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I will check this out Brad. Bella is back in the shop now so won't be for a few days.
This only started after approx 700miles on the new wheels/tires, for the first 700miles the new wheels/tires were absolutely fine. To me seems to be getting worse; and is definitely related to road speed, if I drop in neutral it is still there, if I take my foot off the gas it is still there.
Old 06-06-2016, 12:18 PM   #656
Forgot to mention the gasket between the carburetor and the intake manifold.
The out of round tires I had on the 310 were noticeable from the get go. I wonder if your tires are starting to break down internally?
You might also try rotating the tires front to back to see if that makes any difference.
Old 06-08-2016, 11:32 AM   #657
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Hmmm......valves changed, two days in the tire check tank shows no drop in pressure or evidence of leakage, and it is being reported that there is no surface vibration now - could it have been that simple?
Old 06-08-2016, 01:06 PM   #658
There's always a first time for everything
Hopefully your problem is solved.
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1155 01-16-2018 09:43 AM
Lake Logan Martin Pell City, AL chuman70 On The Road... 0 05-23-2015 05:52 PM
Phipps Park Martin County Florida chaimemet On The Road... 2 12-06-2008 10:28 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 02:21 PM
