Old 03-06-2016, 04:04 PM   #547
Martin, how are the camera cables being routed?
Old 03-06-2016, 06:18 PM   #548
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
There is a single 5m video cable from the GPS display that runs along a floor level cable duct behind the driver side 'door' panel, and behind the kitchenette. That surfaces just forward of the wheel well, and goes into a simple RCA splitter, to allow two individual 5m video cables to run through the drivers side underbed cabinet, up behind the panel under the drivers side pano and out through the outer skin via a grommet behind the light panel (same as the tail light wiring). The video cable is not switched in any way.
However the power to the cameras is supplied from a dash mounted on-off-on switch so when the switch is off the cameras have no power and are 'off' and the GPS stays in GPS mode. As soon as either camera is switched on, the GPS auto-switches to AV display. Because it isn't possible for the cameras to be on at the same time there is no interference even though I am using the splitter (as a joiner).
martin300662 is offline   Reply With Quote
Old 03-07-2016, 11:16 AM   #549
That's a nice clean routing arrangement. So much better than going overhead through the ceiling area. I wish there was a way to route cables up to the back rear overhead area from below but I don't think it's possible.
If I want a camera up high like we discussed previously my only option is overhead
Old 03-07-2016, 11:46 AM   #550
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I actually have an overhead route because the rear wall lights, the Fantastic Fan wiring, and the AV cables from the TV/PC to the dash stereo actually run along the center of the roof, then swing around to the passenger side, routing down forward of the door frame/behind the cab sliders....I guess that was my options; below the panos and the wiring went drivers side, if I went above the panos then the wiring would have gone passenger side.
Old 03-07-2016, 01:08 PM   #551
I'm still debating how much of my interior skin I want to remove to clean up the wiring and insulation. I just know that if I start with just the bottom row I will eventually end up removing all of it
Old 03-07-2016, 06:12 PM   #552
1982 31' Airstream 310
Henniker , New Hampshire
I added a rear camera up high on my 310. It was really prompted by a short in the clearance light wiring that I had to repair.
I used a "wireless" camera. It only required a 12v feed and ground.
I removed the left rear stereo speaker and spent hours with a fish tape tapping around inside the wall until dumb luck allowed me to hit a hole in the crossbrace inside the wall.
Then I drilled a hole up from underneath the coach into the wall space. I then spent several more hours until I snagged the first fish with another fish from the bottom.
I drilled 3 big holes through the skin inside the rear overhead cabinet to access the back of my clearance lights and pulled new wires for the lights and camera up from the bottom with my fish tape. Covered the holes inside the cabinet with 4" square electric box covers. No visible evidence when the cabinet doors are closed.
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 03-07-2016, 06:44 PM   #553
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Sounds like a neat solution Chiefair. Any chance we will be joining us at the motorhome get together so we can admire that new 502?
Old 03-08-2016, 10:06 AM   #554
I want to but I am hesitant to commit. Last spring we had the worst brush fire season in many years in NH. That was after a winter with near record snowfall. This year we have had very limited snow cover all winter. If this spring fire season is busy I won't be able to get away. I am the Chief Coordinator for a 22 town fire mutual aid system. I am hoping that I will be able to join up at the last minute if work and the group planning the event allow it.
Old 03-08-2016, 11:09 AM   #555
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Martin
You might want to do a moch-up of your camera location.. I went to a lot of trouble to mount my camera over the rear window. When I got it all done I was disappointed to find that in order to point the camera down low enough to see the trailer hitch I could only see 10 or 20 feet behind the MH. Seems like the fisheye lense in the camera was designed to mount down low ie. the license plate.
Gregsch is offline   Reply With Quote
Old 03-08-2016, 12:33 PM   #556
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Martin's Argosy rebuild thread
Hi Greg, I have been doing exactly that. Before being 'installed' I have had the cameras taped on a piece of wood (actually inside Bella looking through the rear windows), so I was 100% happy, even using the GPS/cameras, before installing. The Esky cameras I have are designed for 170 degree (non-distorted) viewing so are more like a wide angle rather than fisheye lens. This is actually why I went with two cameras preferring to have a two switchable 'ideal' views rather than one compromise.
As you say these particular cameras are designed to be mounted in or around the license plate, but I have a great view straight back from the light bar.
Old 03-08-2016, 12:38 PM   #557
Martin, would you mind sharing the part numbers for the Esky cameras you used?
Old 03-08-2016, 01:52 PM   #558
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Sure Brad. The GPS came with a generic 'look-a-like' camera, but I replaced it with two Esky EC170-06HD cameras (from Amazon, http://www.amazon.com/gp/product/B00...ilpage_o02_s00). They use the same power supply connection etc
They are much better definition and also for use in low light. Esky actually make a -08 now that has the same specs as the -06 but is slightly different shape (and chrome plated).
Within the same model you can also chose with or without grid-lines; I actually bought one with grid-lines and tried out for the hitch view, but then found it distracting so changed to two without.
Old 03-09-2016, 07:13 AM   #559
Martin, thanks for the info. I just bought an Esky EC170-07HD with the grid lines. I have one with grid lines installed on my F250 and I've found the grid lines are helpful for judging distances. For connecting to hitches I really like where you placed the camera that points down. I will likely place my reversing camera just below the rear center window to get a better view of the hitch.
I'll probably order an -06HD for the camera that's going to point rearward.
Thanks!
Old 03-09-2016, 08:18 AM   #560
Keen amature
1975 20' Argosy 20
Chestfield , Kent
One of the fortunate side effects of keeping the light bar is the lower edge actual slopes quite considerably (approx 10 degrees). This downward slop means the camera actually is about 190 degree to vertical so actually looks 'backwards' slightly.
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1154 Yesterday 04:25 PM
Lake Logan Martin Pell City, AL chuman70 On The Road... 0 05-23-2015 05:52 PM
Phipps Park Martin County Florida chaimemet On The Road... 2 12-06-2008 10:28 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 02:21 PM
