Old 01-18-2016, 07:03 AM   #463
For the time being if it works then leave it alone!
I'd rather have a sender tell me I'm empty and have several inches of fuel left than have it tell me it's 1/4 and be empty!
Old 01-30-2016, 12:58 PM   #464
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
A good news/bad news day....and in future I will keep my mouth shut and not tempt the Airstream Gods.
Good news first - Bella is back!
All new brakes, bell cranks, suspension, steering overhauled, ball joints checked, and now steering damper in place and working great
First long run on the Centramatics, showed the improvement in terms of vibration - I can let go of the wheel and she carriers on in a straight line with no movement of the steering wheel - hurrah!
She drives, steers and stops great. Probably too well as the slide out dinette table shot out the first time I braked heavily.
Now for the bad news.
The aforementioned fuel gauge sender appears to have gone out on the way home and flipped the reading from reading nearly empty to open circuit (full). Hopefully just a wire come loose but who knows.
Worst she has decide not to change gear. Goes into drive and reverse fine but at the point that she should change up she doesn't.
Oh well progress is progress just now have some more 'essential work' that needs to get down before the motorhome get together.
martin300662 is online now   Reply With Quote
Old 01-30-2016, 01:06 PM   #465
Martin,
Have you tried placing the shift lever in D1, D2 and D3 individually? You should be able to feel the shift lever give a little bit of feed back as you select each gear. Once each gear is selected does Bella move in that gear?
Also, the TH400 uses vacuum to shift so it's possible you have something wrong with either the vacuum hose or the shift modulator on the transmission.
If you do end up determining that your transmission needs to be removed I have what is supposed to be a freshly rebuilt TH400 that I just removed from my Argosy. When I bought the Argosy it supposedly had a freshly built 350 engine (never started) and the freshly built TH400. I also have a new torque converter to go with it.
The TH400 is of no use to me so if it will help you out I'm sure we can work something out that doesn't affect your pocket book
It might be your cheapest option to keep you going until you decide to do a power train upgrade.
Old 01-30-2016, 02:58 PM   #466
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
Martin,
I think the shifter linkage is working and adjusted correctly, as (following the instructions in the light truck manual) I have to lift to move from Park to Reverse, and from Neutral to Drive, D2 and D1 (although it feels like I could slide from Reverse into Neutral without lifting, same with Drive back to Neutral). Reverse engages reverse, Drive engages drive, D2 engages drive and D1 engages drive.
So I am suspecting the modulator; the issue is I can't find the modulator! It appears from the manual it should be on the drivers side towards the tale of the trans....there is nothing there. Also I can't find a vacuum take off on the intake manifold that routes towards the trans. Any suggestions?
Old 01-30-2016, 03:53 PM   #467
That sounds right.
Passenger side right next to where the dipstick tube enters the transmission.
Old 01-30-2016, 07:38 PM   #468
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I still can't see the modulator but have a replacement reserved at the local NAPA....just need to build a pair of ramps like Peter's first to get Bella up in the air to get under her!
Old 01-30-2016, 07:52 PM   #469
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Martin, no need for fancy ramps quite yet, you should be able to see the modulator from inside looking down on the passenger side. Usually there is a metal tube running up to the intake for the vacuum line. I would first check that you dont have any cracked rubber down by the modulator and up by the intake.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-30-2016, 08:15 PM   #470
Here's a another picture with a slightly different view.
Name:	2634d1244385634-yet-another-transmission-mystery-th400-new-one-attached-vacuum-hose-cleaned-up-.jpeg
Old 01-30-2016, 09:12 PM   #471
One thing still confuses me about your problem. You said no matter which drive selection you make it stays in the same gear. So in D1 (low) you're still in D3. That would indicate the transmission is not down shifting. I think when you manually select the gear the shift mechanism is forced to the selected gear. That doesn't seem to be working.
I'm not sure what that means
Old 01-31-2016, 01:04 AM   #472
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Hi Brad, the issue is, when pulling away normally, and selecting the Drive position on the gear selector, Bella isn't upshifting based on engine speed. So she pulls away and I can run her right up to 50mph (with the engine screaming) and she does seem to upshift.
When I select L1 or L2 it goes into a forward driving gear but I haven't tried actually anything other than just moving forward to check it is engaged so have on idea what actual gear it is in (or if she would upshift to 2nd if I select L2).
I have assumed that Drive means selecting a gear where the trans would shift 'automatically between all gears (dependent on engine speed) whereas L2 still gives gears 1 and 2 (so could be used to downshift for overtaking if the trans is in 3rd) and L1 would restrict the range just to 1st gear (so should not be selected if already travelling above a speed that would over rev the engine) and really is only there to stop upshifting when pulling away on a surface with low traction, maybe this is wrong?
So Bella appears to engage a gear for pulling away no matter if I select Drive, L2 or L1 (so I assume 1st gear in each case) but does not upshift, even if travelling at over 40mph (which is supposed to be the max speed at which 1st should be engaged).
Does that make for sense?
Old 01-31-2016, 06:51 AM   #473
Hi Brad, the issue is, when pulling away normally, and selecting the Drive position on the gear selector, Bella isn't upshifting based on engine speed. So she pulls away and I can run her right up to 50mph (with the engine screaming) and she does NOT seem to upshift.
I added the word NOT in the last sentence above. I'm assuming that's what you meant to say.
It would be interesting to see what it actually does when you make the above tests.
You're correct about the Drive (D3). It should start out in 1st (D1) and then up shift through 2nd and then to 3rd.
When the selector is in D2 or D1 I'm thinking it should be stuck in the gear selected. In other words if you selected D2 it should strain to accelerate until it gets into the speed range where D2 would be appropriate. Selecting D1 should keep it in 1st gear.
I say the above based on what I vaguely remember happening with my Ford truck, different manufacturer so may not be the same. For some reason I'm thinking if you manually select D1 or D2 then that is the gear the transmission is in just like a manual transmission.
Yep, makes sense. It sure sounds like the vacuum modulator is not working. Like Peter suggested it could be a vacuum line or it could be the modulator or worst case somethings wrong inside the transmission.
Old 01-31-2016, 07:13 AM   #474
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks for catching the typo Brad!
Just for info, can anyone explain how the modulator actually causes an action? It appears a plunger mechanism actuated by vacuum, but how does the plunger change gear? Does it push against a mechanism or have some sort of hydraulic action?
Old 01-31-2016, 08:39 AM   #475
Keen amature
1975 20' Argosy 20
Chestfield , Kent
So after a little "interweb" searching, I found this video that is pretty explanatory
Old 01-31-2016, 01:21 PM   #476
Keen amature
1975 20' Argosy 20
Chestfield , Kent
This is what I found at the connection of the modulator vacuum line to the inlet manifold (which itself is a twin connector).
If that isn't bad enough the plastic T was broken and the connection would have been flaky at best.
Trouble is I can't find a piece of 7/32" vacuum line in stock anywhere (1/4" is to big and 3/16" too small for the inlet end).
At least I have a smoking gun.
'74 Argosy 20' Motorhome restoration/rebuild bkahler Argosy Motorhomes 1186 02-18-2018 07:39 AM
Lake Logan Martin Pell City, AL chuman70 On The Road... 0 05-23-2015 05:52 PM
Phipps Park Martin County Florida chaimemet On The Road... 2 12-06-2008 10:28 PM
Argosy rebuild list bkahler Argosy Motorhomes 2 07-25-2008 02:21 PM
