10-23-2015, 07:16 PM
#361
2012 27' Flying Cloud
W
, New England
Sorry to hear that Martin!
10-23-2015, 07:24 PM
#362
Richmond
, Kentucky
I think I'd be having a conversation with the last shop. The ending could have been a whole lot worse than what it was.
1975 24' Argosy Motor Home
10-23-2015, 08:33 PM
#363
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
i'm not best pleased but holding off from confronting the first shop until I actually find out what is wrong (this time).
The good news is I seem to have finally found a shop and a mechanic who is a little old school and seems to know what he is talking about....fingers crossed.
10-24-2015, 06:23 AM
#364
1982 31' Airstream 310
champaign
Wow. Bright side, you werent rolling up to a stop light with traffic. Ya never know, maybe this mishap has lead you to the right shop, with the right mechanic to finally get you past the dang brakes so you can move ahead. Ill put my money there. Good luck Martin.
Mike
10-24-2015, 06:26 AM
#365
Richmond
, Kentucky
Finding the right mechanic can be like trying to find a needle in a haystack. Here's hoping you've found one
10-24-2015, 07:09 AM
#366
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Having done brakes on these big beast several times, I am very curious to hear what went wrong. The rear drums require for the axle shafts to be pulled, which is a job most car repair shops try to stay away from. Once you do that you are ALWAYS better off to replace the wheel cylinders, oil seal and check or replace the bearings, besides the shoes and drum inspection.
Anything less would not be acceptable.
AIR #13
10-24-2015, 08:16 AM
#367
Rivet Loser
La Ronge
, Saskatchewan
Excuse this if it is only demonstrating my usual ignorance, but I believe you might have a hydroboost system on your MH. If so, then your sudden loss of fluid despite all the brake work might indicate that your fluid is being sucked into the accumulator. An occasional problem with this system.
1989 345LE
10-24-2015, 08:37 AM
#368
Airstream Driver
1994 30' Excella
Austin
They are 2 independent systems, one uses Brake fluid the other powersteering fluid.
AIR #13
10-24-2015, 08:46 AM
#369
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The issue is definitely the brake fluid system, the hydroboost/power steering/accumulator is working fine.
The first shop must have disturbed something, I suspect in the combination valve, as it is the only place that both the front and rear circuit are in the same place (but even then separated), and MC was empty on both sides.
10-24-2015, 09:00 AM
#370
Airstream Driver
1994 30' Excella
Austin
very odd, maybe they forgot to fill it
did you see a puddle anywhere? Thats a lot of fluid
AIR #13
10-24-2015, 09:27 AM
#371
Rivet Loser
La Ronge
, Saskatchewan
Well, at the risk of being guilty of recidivistic ignorance, I know that you can get PS fluid in your brake MC with the Hydroboost system, so I think that they must interface.........
How is your PS fluid level? Lost fluid must go somewhere, and if it isn't on the ground, where is it? In the cab? In the accumulator? I'm just trying to think of empty spaces that could take mysteriously disappearing fluid. Your brake professionals have looked at the normal and likely things, so time to think of the unlikely but possible.
1989 345LE
10-24-2015, 09:39 AM
#372
Dazed and Confused
Hillsburgh
, Ontario
I reserve the right to state my opinions once all the facts are in. To speculate on where the brake fluid went on a moho this old would be redundant, although my jaundiced eye is on those pesky Airstream Gods.
You might want to get her fixed right before shipping her back home, as there are a lot more things to hit in the Old Country. I can see the headline now; "OAP claims no brakes in an American icon terrorist attack on the front gates of Buckingham Palace."
I can only hope that Martin had a spare set of skivvies after the pedal went down to the floor.
On the bright side, as Mike put it, you now know what your brake pedal feel should be, and you felt fine with it......before it crapped out on you; so that's a good thing.
Lots of luck with the old school mechanic. It's the buggers who walk out to our rigs with a laptop and an OBD connection you shake your head at.
Cheers
Tony
10-24-2015, 09:40 AM
#373
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The hydroboost is not the issue here, and the hydroboost circuit never comes anywhere near the brake circuit.
Best way to think of hydroboost is as an amplifier, increasing the mechanical advantage of the brake pedal on the MC, and it is effort not leverage that is assisted.
10-24-2015, 10:06 AM
#374
Rivet Loser
La Ronge
, Saskatchewan
But I'm going to annoy you, because my Chevy chassis manual has this little note:
And I really don't see why they put it in if the systems don't get anywhere near each other.
(Plus all you have to do is a little Googling to find plenty of reports of Hydroboosts leaking into the master cylinder.) Don't shoot the messenger.
1989 345LE
10-24-2015, 10:13 AM
#375
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Attachment 250946
Because the hydroboost is an amplifier....you push the brake pedal with a certain effort, the hydroboost amplifies that effort on the MC. It is akin to changing the pivot point on the brake pedal to give a longer lever, without changing the length of the lever.
Just because the fluidic paths never come near each other, doesn't mean the hydroboost doesn't help with braking, it does.
10-24-2015, 10:15 AM
#376
Dazed and Confused
Hillsburgh
, Ontario
You're both right....
Yes, the hydroboost sytem is tied to the brake system and supplies boosting power for the brakes. Bad hydroboost system would lead to poor braking, or no brakes.
Yes both systems are independent of each other fluid wise. The foot note in your manual Punch is to stop anyone adding power steering fluid to the master cylinder to top up fluid as people could be confused by someone stating that the Hydroboost sytem control the brakes.
Martin has power steering so the hydroboost system is probably working.
Is that all fixed?
Cheers
Tony
10-24-2015, 10:38 AM
#377
Rivet Loser
La Ronge
, Saskatchewan
Is that all fixed?
Cheers
Tony
OK, now I'll shut up.
1989 345LE
10-24-2015, 10:40 AM
#378
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Yes, Tony.
I did say a few posts back, the hydroboost/power steering is working fine and levels are all good. There is a separate test procedure for testing both the high and low pressure circuit on the hydroboost and the system passes.
10-24-2015, 10:58 AM
#379
Airstream Driver
1994 30' Excella
Austin
no wait, there is more.
Both the hydroboost and the master cylinder work via pistons and seals.
A leaky hydroboost output rod piston seal would eventually help destroying the Master cylinder piston seal, but not in a rapid way Martin experienced brake failure. A catastrophic failure may even slightly pollute the brake fluid, but that is very far fetched and it would cause failure of all the power steering stuff too.
And there are 2 piston seals in the Master cylinder, which means the first one would have to fail first before reaching the second one.
Feel better now, Punch ?
AIR #13
10-24-2015, 11:19 AM
#380
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Sorry Peter, I missed this in the exchanges.
No sign of any fluid leaks but also the MC gasket had been 'sucked' (deformed) into the cylinders (sorry for the non-technical description). To me this suggests fluid being pushed out rather than leaking.
I had driven straight from the shop to the local car park (which just happens to be next to the beach), and had been driving around braking with different levels of intensity, before the light came back on and the pedal returned to how it was previously (I didn't loose all brakes fortunately, it just went back to how it was before the repair). If they filled the MC (and I assume they did because the brakes were great for a while) then I can't rationalize both sides of the MC would be effected.
