07-13-2015, 02:05 PM
#221
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Seems I need the same type as used in a 75-78 L82 (350) Chevy and of course none of the supply houses have one.
07-13-2015, 02:15 PM
#222
Richmond
, Kentucky
I don't want to get your hopes up but I know I've seen one of those or one similar to it in my parts boxes. The real test will be trying to find it
Stay tuned.....
1975 24' Argosy Motor Home
07-13-2015, 04:25 PM
#223
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I'll take anything you have (even similar), Brad.
Thanks!
07-13-2015, 06:11 PM
#224
Richmond
, Kentucky
Thanks!
Well one way or another I think we got you covered
The following four pictures show what I have available. It came from an 86 345 with a 454 engine. The fourth picture shows an adapter plate that is bolted to the main bracket. It was probably for the cruise control cable.
Here's the one that is hanging from my Argosy throttle cable. If push came to shove and nothing else would work I would probably let this one go.
Here is the one I installed on the Edelbrock 1406 carburetor on my 454. The motor is currently sitting on the test stand that I built.
And last but not least here are a few that I found on ebay that would likely work as well.
73-86 chevy big block throttle cable bracket
73-86 chevy small block throttle cable bracket
If you want the one from the 345 I could probably get it in the mail tomorrow.
Let me know if I can help out.
07-13-2015, 08:21 PM
#225
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Thanks Brad.
With the original mia I think the best approach is for me to buy one of the two small block brackets on eBay. They look very similar to the big block link and the one you have still installed so maybe the any of them will need some gentle fettling.
07-13-2015, 08:36 PM
#226
Richmond
, Kentucky
From looking at the three that I have there really doesn't seem to be much difference between them. They all have the important part which is the correct hole for the cable.
Let me know if the one you buy doesn't work and I will ship you the one from the 345.
07-14-2015, 06:10 AM
#227
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Brad, about 3 hours after I ordered one of the 3 that you sent in the links, I get a (very apologetic) email from Dick, who woke up at 3am worrying about the darn bracket, only to find it where he had left it to dry after bead blasting and painting....so now I have two expected in the mail tomorrow.
What's that saying...all's well, that ends well?
07-14-2015, 06:22 AM
#228
Richmond
, Kentucky
Martin, look at it this way. If you hadn't bought the one off of ebay then your original one likely wouldn't have shown up and you'd still be looking for one
I would be interested in knowing what the differences are between the one you bought and your original one. If you have the opportunity could you post pictures of the two?
07-16-2015, 01:02 PM
#229
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
07-16-2015, 01:35 PM
#230
Richmond
, Kentucky
Tonight I'll compare your original 350 bracket to the one that came on my Argosy and then I'll compare it to the one on my new engine. Be interesting to see if there really is a difference between big block and small block.
07-17-2015, 05:27 PM
#231
1971 21' Globetrotter
Arvada
I am thoroughly enjoying your adventure, I can't wait to see how it ends.
07-18-2015, 04:34 AM
#232
1978 28' Argosy 28
Austin
Also, how it begins! 😀
07-18-2015, 04:45 PM
#233
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Just back from a decent length test drive on the Dick Paterson rebuilt carb.....what a difference. Drive along at the 45 limit on a local road, limit changed and the pick-up and pull through to highway speed was great.
Holding good water temp on the re-cored radiator and the mystery of the fuel tank not taking any more fuel is solved - according to the now working gauge I can see the tank is full!
Still some teething problems like the oil pressure gauge isn't working (it was during the last run so I suspect they have fitted the printed circuit and gauges from Brad's cluster (but my speedo), so hopefully just a case of swapping mine back in).
Basically we are ready to camp now and I will drop the mattresses/bedding in tomorrow.
Certainly seems to be grabbing attention, and we had one guy pull along side us at a set of lights pull out his camera and start taking photos....we both obliged with out best 'smile and wave'.
07-18-2015, 05:02 PM
#234
Arvada
Are you going to have it repainted, if so what's the color scheme
07-18-2015, 05:35 PM
#235
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Nice looking interior! Are you putting window shades on those portholes
AIR #13
07-18-2015, 06:14 PM
#236
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Yes it will go into 'body and paint' either at the end of this season or more probably early next year.
Some of that depends scheduling; current 'plan' is to join the local NEU caravan to Florida in October but then leave Bella somewhere south for the winter (probably along with my better half and our dog to avoid the New England winter)....we are looking at RV resorts along the gulf costs but want one where we can also have a fixed structure as well as the parking spot.
I will 'commute' down at the weekends, and we can still camp all winter.
When we bring her back up depends on weather but hopefully we can find a window in March where weather is good enough and we can drive back and get the paint (probably Chevy Willow Green or something similar) and any service needed for the new season.
Well that's the plan anyway!
07-18-2015, 06:23 PM
#237
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Hi Peter
No blinds on the VistaViews but we are going to add GILA Platinum heat reflective coating ( GILA Heat Control Window Film ). Suppose to reflect 70% of the heat with minimal drop in transparency.
All the ones in the living area are single pane, but the one in the wetroom is a double pane so needs converting to single (the gasket arrived from Can-Am this week) before adding the film.
All the regular sliders and panos have blinds or blackouts.
07-18-2015, 08:32 PM
#238
Airstream Driver
1994 30' Excella
Austin
.......we are looking at RV resorts along the gulf costs but want one where we can also have a fixed structure as well as the parking spot.
Martin,
If the wind blows you as far as Texas, consider yourself a welcome guest at my place in Austin. I do have hookup with 30 amp, sewer and water in a private spot on my property (away from where all the work on my Airstreams is happening )
AIR #13
07-19-2015, 01:47 PM
#239
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Martin,
Be careful what you offer Peter, one day you may wake up to a family of strays sitting on your doorstep. Seriously though, many tanks for the offer.
07-19-2015, 05:09 PM
#240
Airstream Driver
1994 30' Excella
Austin
You are welcome and bring it on.
I am known Pit stop for those that dare to cross the Llano Estacado.
For that matter any Airstream/Argosy Motorhome is always welcome at my place.
AIR #13
