Old 11-08-2018, 10:12 AM   #29
chevy2man's Avatar
1975 20' Argosy 20
Jeffersonville , Indiana
Price for prep and re-lining of fuel tank. $425. Just a start to the money pit.
chevy2man is offline   Reply With Quote
Old 11-08-2018, 11:59 AM   #30
2007 22' International CCD
Sadly, that sucking sound you hear is coming from the general vicinity of your wallet...and it's not the sound of your wallet inhaling money...quite the opposite.
Do be sure to replace every last bit of fuel lines with material rated for gas containing alcohol--the older hoses deteriorate rapidly with "corn gas" and have destroyed some really nice old Airstream motorhomes. You are right to work on the fuel system first!
Old 11-08-2018, 12:35 PM   #31
It cost me $450 to have a custom 50 gallon tank built for my 20' Argosy. You might look into that option if you want a larger tank.
Old 11-08-2018, 01:54 PM   #32
chevy2man's Avatar
1975 20' Argosy 20
I might have some leftover braided Teflon from when I went to dual Bosch 044 pumps on my Toyota Supra turbo. If not, the Parker store is close.
Old 11-08-2018, 03:01 PM   #33
chevy2man's Avatar
1975 20' Argosy 20
I might look at that option later if I decide to repower it at some point. Daydreaming about Duramax w/Allison combination.
Old 11-08-2018, 05:08 PM   #34
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Keep dreaming! Trying to assimilate the Duramax electronic nannies and sensors into your Argosy is almost impossible; you'll have error codes and it'll go into limp home mode every 50 miles; which is what happened to the other guy that swapped a Duramax.
Keep it simple is my moto. I'm going with a 12 valve Cummins; basically needs three wires to run; a positive, ground and relay wire to the starter; no computers, sensors or other crap. A Cummins will run for a long time.
Cheers
Sidekick Tony
Old 11-08-2018, 08:57 PM   #35
chevy2man's Avatar
1975 20' Argosy 20
Cheers
Sidekick Tony
I would go stand-alone ecu and harness. I’ve done it on my 1994 Toyota Supra turbo and tuned it to make 500whp on pump gas (93 octane). Car runs and drives like stock unless you get a heavy right foot. trying to swap factory harness and all sensors into a different vehicle without the ability to actually control VATS and other systems would be a major headache. It’s doable as long as there is room physically for the drivetrain. Dirty Hooker diesel and a few others sell stand alone harnesses for the Duramax/Allison drivetrain to swap into just about anything and do it without a ton of problems.
Old 11-29-2018, 12:14 PM   #36
chevy2man's Avatar
1975 20' Argosy 20
ID:	328735Click image for larger version
ID:	328736Click image for larger version
Old 11-29-2018, 12:16 PM   #37
chevy2man's Avatar
1975 20' Argosy 20
Tank is back from clean and re-coating. Cost me about as much as a new tank but I get to keep my baffles.
Old 11-29-2018, 12:17 PM   #38
Good deal. I don't understand why the repro tanks don't include the baffles, other than cost. Pretty annoying.
Old 11-29-2018, 12:49 PM   #39
chevy2man's Avatar
1975 20' Argosy 20
I hear ya Brad, I looked to buy a reproduction tank until I saw on you and few other’s threads talking about them not having them. Fortunately for me my tank wasn’t rotted out bad. The coating they used is supposed to last for long time. We shall see.
Old 11-30-2018, 12:07 AM   #40
GREEN ARGOSY's Avatar
1977 20' Argosy 20
Matsubushi , Saitama
Looks beautiful! Also the behind car too.
Is that Chevy Nova? Whatever it is, it's cool!
GREEN ARGOSY is offline   Reply With Quote
Old 11-30-2018, 05:05 AM   #41
chevy2man's Avatar
1975 20' Argosy 20
Thanks! Yes, it’s a 1966 Chevy II. 55,000 original miles. 327ci, powerglide transmission, positraction rearend. I’ve had it for about 20 years. It has always been garaged.
Old 11-30-2018, 05:42 AM   #42
1977 20' Argosy 20
Wow!! That's great!!! Ahh! I got it why your name is "chevy2man".
You have a Chevy II! I understand it just now.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
TinyTin
The Long long long trip Foiled Again Full-Timing, Winter Living & Workamping 39 03-24-2016 11:27 AM
The long road ahead..... prob All Argosy Trailers 10 11-26-2011 08:32 AM
