Old 07-21-2009, 10:48 PM   #1
Don Landis's Avatar
1978 28' Argosy 28
Monterey , California
Locking Door From Outside
I'd like to put an extra lock or a locking system on the outside of the door to be secure when I store the vehicle. But I'm unclear on what and where the best place is to put this lock. The regular key lock in the handle just doesn't cut it after all these years. Anyone have any suggestions?
Don Landis is offline   Reply With Quote
Old 07-22-2009, 03:09 AM   #2
volvophile's Avatar
colorado springs , Colorado
Images: 14
Well, you can do what the previos owner did on mine and poke a couple of eyebolts through the skin. One on the door and one on the door frame, coat it with a couple pints of silicone caulk and run a paddlock through them. Thats on my list of things to remedy, but I've been putting it off because its so effective for all it's ugliness.
Ace hardware, and other places stock an RV deadbolt in stainless steel, which appear to be constructed the same as a household deadbolt but requires a 3/4" hole instead of a full 2 1/2". I will probably go that route and see if I can get it keyed the same as my home deadbolts. One less key to loose.
Champagne wishes and Caviar dreams!
Budwieser budget.
volvophile is offline   Reply With Quote
Old 07-22-2009, 08:49 PM   #3
fabu007's Avatar
1978 28' Argosy 28
eatontown , New Jersey
Than ACE is the place cause i just got a 2 key lock rebuild kit for my KEELOR latch and it looks way too complicated for me to be bothered, turns out its not a rebuild kit its a complete replacement... involves drilling riviting re holing, etc...
fabu007 is offline   Reply With Quote
Old 07-22-2009, 09:52 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
The PO put a dead bolt on my door. And it's not that bad of a job..
I will take some pics and post them in the morning...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-23-2009, 09:12 AM   #5
purman's Avatar
1968 28' Ambassador
Dead Bolt on AS
Ok, here is the dead bolt the PO put on my AS.
He had to cut the Dead bolt down to fit into the door and also had to cut a hole in the door frame. Not sure what structurally this has done to the door, but it's been like that for years.
It works well, And it's easier to use than the one on the door handle.
ID:	84373   Click image for larger version
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-23-2009, 10:51 AM   #6
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
If that is the cast door frame, it can make it weak. But if the fix is working now after a number of years, glad it is keeping the door closed properly.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 07-23-2009, 11:36 AM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
We have a similar 'dead bolt' to purman's, that was installed by the original owner of our AS...I have paperwork that shows he had it installed by his dealer when he bought the trailer, 31 years ago...
Our trailer has been 'well traveled' and shows no damage or weakness in the area where the dead bolt is installed - or the door itself...
We use this dead bolt as the main locking point of our trailer - don't want the door to flop open on the road...!
Ray & Pat; Morada, CA
Old 07-23-2009, 04:27 PM   #8
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Ray, I need to look at your dead bolt when were in Jackson. I'd like to add one to our Ambassador too.
Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 07-23-2009, 10:42 PM   #9
fabu007's Avatar
1978 28' Argosy 28
Hey looks good to me and a hell of alot easier to put in than the keelor replacement!
"I Can do That!"
Old 07-23-2009, 10:43 PM   #10
Don Landis's Avatar
1978 28' Argosy 28
Wow. Sounds like it should be professionally done, especially if it could weaken the door frame. I'm not too keen on drilling into the skin to put one in either. Wonder if there is some magical way of doing it short of what's been shown above?
don
Old 07-23-2009, 10:46 PM   #11
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's some pics...
Name:	DSCN1744 [Desktop Resolution].JPG
ID:	84397   Click image for larger version
Name:	DSCN1746 [Desktop Resolution].JPG
Name:	DSCN1749 [Desktop Resolution].JPG
ID:	84399   Click image for larger version
Name:	DSCN1750 [Desktop Resolution].JPG
Old 07-24-2009, 12:09 AM   #12
tallytwo1994's Avatar
tallahassee , Florida
They carry them here:
RV Deadbolt
Carol
tallytwo1994 is offline   Reply With Quote
Old 07-24-2009, 06:32 AM   #13
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Has anyone installed the one from Vintage Trailer? How did the install go?
crispyboy is offline   Reply With Quote
Old 08-12-2009, 01:09 AM   #14
Don Landis's Avatar
1978 28' Argosy 28
I was wondering if those who have left photos could take pictures a little farther back so I can see how it sets in the door as compared to the whole door and trailer. I'm trying to get a sense of placement on the door and location.
don
Sheared door locking mechanism upper bolt woppa 4 Doors & Locks 3 06-18-2009 08:39 AM
Door not locking cookeville34 Doors & Locks 8 01-28-2007 01:18 PM
Door locking by itself! FiveGreers 2005 Safari 6 08-03-2006 09:06 PM
'72 Tradewind: Locking the Door From Inside yochanan Doors & Locks 2 11-05-2005 07:25 PM
Door locking after being slammed shut TomD32 Doors & Locks 4 06-25-2003 09:56 AM
