Old 08-12-2009, 08:38 AM   #15
Ottawa , ON
Maybe just park with the door up against a wall, if you can?
Old 08-13-2009, 06:48 PM   #16
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's some more pic's with some measurements...
Name:	DSCN1947 [Desktop Resolution].JPG
ID:	85329   Click image for larger version
Name:	DSCN1948 [Desktop Resolution].JPG
Name:	DSCN1950 [Desktop Resolution].JPG
ID:	85331   Click image for larger version
Name:	DSCN1951 [Desktop Resolution].JPG
Name:	DSCN1952 [Desktop Resolution].JPG
ID:	85333   Click image for larger version
Name:	DSCN1953 [Desktop Resolution].JPG
Name:	DSCN1954 [Desktop Resolution].JPG
ID:	85335   Click image for larger version
Name:	DSCN1956 [Desktop Resolution].JPG
Ray & Pat; Morada, CA
Old 08-14-2009, 04:54 PM   #17
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Ok, here is a pic of my door. It pretty much looks like everyone else's...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-14-2009, 08:55 PM   #18
2010 27' FB Classic
N/A , Texas
If you guys make it to Jackson Center sometime, have them install a dead bolt for you.
They did mine, and it looks factory installed. (a little humor)
Really, it looks like it was made for my trailer.
Old 08-14-2009, 10:16 PM   #19
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Other then holding the door closed when travelling, I leave the door unlocked when not using the trailer. Take out anything you don't want stolen. That way you won't have an expensive repair when someone pries open the door. I learned this from the local Airstream dealer. He leaves the lot trailers open and says it saves a lot of trouble with people breaking in. So far I've only lost 1 old propane tank and it was outside. I left another out hoping someone would take it away but no luck.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-16-2009, 06:17 PM   #20
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
I didn't want o replace the original and added a deadbolt. Mine is a regular house lock. I didn't know there was one made RV's. I'll change it out now, but here is what I have for now. Works great. I had to cut the bolt down lengthwise to make it slimmer.
lol, I cant get a pic in here, but will post it in photo's.
Alwhisman is offline   Reply With Quote
Old 08-16-2009, 06:30 PM   #21
purman's Avatar
1968 28' Ambassador
Lock? I never lock my trailer at home. But then I live in the middle of nowhere and don't lock my house when I leave either...
Neighbors all have guns. Better than locks.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-16-2009, 10:30 PM   #22
fabu007's Avatar
1978 28' Argosy 28
eatontown , New Jersey
I dont lock up either cause of the mess they'll make trying to get in, besides i have dogs and they are liable to wake them up!
(beagles)
fabu007 is offline   Reply With Quote
Old 08-18-2009, 09:32 PM   #23
Don Landis's Avatar
1978 28' Argosy 28
Monterey , California
Everyone, thanks for the pictures and comments. I was looking to put the lock in the door. But it looks like everyone puts the lock in the wall that goes into the door. Interesting. I'll have to look at mine again and see if it's possible.
don
Don Landis is offline   Reply With Quote
Old 08-18-2009, 10:23 PM   #24
Images: 59
I put mine in the door and it works great. Bought the special deadbolt from Vintage Trailer, same as in post #12.
It's not a slam dunk. Don't try this unless you've done a few deadbolts and locksets in regular doors. You need to measure carefully.
Easier to do if you take off the door gasket.
ID:	85661   Click image for larger version
Sheared door locking mechanism upper bolt woppa 4 Doors & Locks 3 06-18-2009 08:39 AM
Door not locking cookeville34 Doors & Locks 8 01-28-2007 01:18 PM
Door locking by itself! FiveGreers 2005 Safari 6 08-03-2006 09:06 PM
'72 Tradewind: Locking the Door From Inside yochanan Doors & Locks 2 11-05-2005 07:25 PM
Door locking after being slammed shut TomD32 Doors & Locks 4 06-25-2003 09:56 AM
