Old 05-13-2015, 07:48 PM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
LED replacements for the aisle lights?
Anyone know of a source for LED replacements for the aisle lights?
I'd like the keep the original look of the unit but switch to LED.
Yes, I could buy bulbs but the original lights are pretty corroded at this point. I know I saw LED versions somewhere but I cannot find it now.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 05-13-2015, 07:57 PM   #2
ViewRVs's Avatar
1977 20' Argosy 20
Nevermind. I win the dumb question of the day award.
The unit I was looking at actually has an LED bulb. It was just buried down in the text and not in the title.
http://www.amazon.com/dp/B006WGAGR8/...=IR8KBB5EN3XCK
Fred H.
Old 05-14-2015, 05:50 AM   #3
1978 28' Argosy 28
Not a dump question. I need a bunch of these also and your link made it easy. Especially love the LED. Thanks.
bpg_austin is offline   Reply With Quote
Old 06-08-2015, 07:53 PM   #4
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
ViewRVs did you ever install these isle lights.
I purchased some after reading this post.
When I received them I questioned whether or not they are led. The illumination looks like incandescent light. When I check them with an ohm meter they read 0 resistance. When I check my other led bulbs they read infinite resistance. Naturally when you check a good incandescent bulb it will show 0 resistance. The only way I see to be sure is to cut one open and see what's inside.
Gregsch is offline   Reply With Quote
Old 06-09-2015, 03:55 PM   #5
ViewRVs's Avatar
1977 20' Argosy 20
I have not ordered them yet. They are still sitting in my wish list.
Interesting because the package never says LED lights yet the description does say LED. I did ask a question on Amazon.
Fred H.
Old 06-13-2015, 12:36 PM   #6
Gregsch's Avatar
Tipp City , Ohio
As I suspected, these lights are not LED. Now lets see what Amazon has to say.
Old 06-15-2015, 07:32 PM   #7
ViewRVs's Avatar
1977 20' Argosy 20
Sorry if I steered you wrong! Amazon ad says LED! I have not bought mine yet.
Here is one that says LED and the reviews mention LED.
http://www.amazon.com/Peterson-Licen...ct_top?ie=UTF8
Fred H.
Old 06-15-2015, 08:10 PM   #8
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Amazon.com: Peterson License Plate Light Chrome Finish: Automotive
Hi Fred,
I ordered some of these for my isle and step lights. Comes with 2 wires, since I am mounting them on wood. They come in chrome and black. Will report back when I get them.
Amazon.com: NEW LED LICENSE PLATE TAG LIGHT CHROME BOAT TRAILER RV TRUCK INTERIOR STEP LIGHT: Automotive
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-18-2015, 08:34 PM   #9
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by PeterH-Airstreamer View Post
Hi Fred,
LED isle lights arrived. They put out a lot of light with a low profile. They are made out of thick plastic and need to mounted where they have a little overhead protection. Overall, good price and nice look
ID:	241058   Click image for larger version
1996 Airstream B190
AIR #13
Old 06-19-2015, 05:36 PM   #10
Peter, those lights look good!
Old 02-28-2016, 06:35 PM   #11
Gregsch's Avatar
Tipp City , Ohio
Found some LED bulbs that work in the aisle fixtures. http://www.ebay.com/itm/121695282248...%3AMEBIDX%3AIT
The fixtures that I bought on Amazon noted in previous posts did not have a ground wire. I found that the copper ring used to crimp 1/2" PEX was a perfect fit on the base of the socket. I just stripped a piece of #16 wire and placed it on the socket and trapped the ring onto the socket with a small hammer. It created a nice friction fit, I added a little solder just to be safe. It took a few minutes to add the ground wire but, once that was done they snapped right into the original hole and matched the original perfectly.
I replaced all 6 of the outside storage compartments as well. The origionals in the compartment had smaller bulb (the base size). I was a little disappointed to find that the LED's used more power than the smaller incandescent bulbs. (2.2 amps vs. 1.7 amps) but, they are considerably brighter. I did not get an accurate before and after on the aisle lights since they were not working to begin with.
It was a simple and inexpensive fix, took about 4 hours to replace all 9 fixtures.
ID:	257967   Click image for larger version
Old 02-28-2016, 06:41 PM   #12
Gregsch's Avatar
Tipp City , Ohio
Whoops! Not sure how I got that link. This is actually the listing I bought;
http://www.ebay.com/itm/281743835989...%3AMEBIDX%3AIT
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
LED Lights replacements drus2 Lights - Interior & Exterior 3 11-01-2008 10:02 AM
Tidee Products Plugs in aisle? Chaplain Kent General Motorhome Topics 5 04-19-2005 07:50 AM
Aisle Lights drm61 General Motorhome Topics 3 06-03-2004 11:01 PM
