Old 12-14-2010, 05:17 PM   #113
Originally Posted by gmehal View Post
Just resent you the pm again, let me know if you receive it. Thanks
FINALLY.
Please send us your invoice number, for the inserts.
We will then forward replacement insert at no charge.
Please indicate belt line or rub rail, or both, as well as MH or trailer.
Old 12-18-2010, 06:18 PM   #114
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Upgraded the headlights last week to some nice hella's with replaceable bulbs. This way I can upgrade the bulbs or convert to hid's. Also significantly better optics
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Old 12-18-2010, 06:24 PM   #115
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Fixed the front bumper today, way mor involved than we thought. Both front main supports were broken from the main frame. Both side attachment bolts were also not attached! Basically the bumper was hanging on by a thread, literally a couple of small screws. So we re welded the main supports an attached the bumper side bolts. No it might actually do something in the event of a bump.
ID:	117229   Click image for larger version
Old 12-18-2010, 06:30 PM   #116
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
New developments, burst pipe and floor under water tank disintegrated. Floor should be n easy fix along with the burst pipe. Hopefully the burst pipe is only in the spot where I can see. I drained the whole tank but apparently I need to do some winterizing research going forward.
ID:	117232   Click image for larger version
Old 12-20-2010, 10:07 AM   #117
projector's Avatar
1972 23' Safari
NSB , Florida
I need to research that also. We had a recent cold snap that made me nervous. Not as bad as up north but cold for us. I put a light in the back to keep the temp up a little.
projector is offline   Reply With Quote
Old 12-20-2010, 03:13 PM   #118
Originally Posted by Inland RV Center, In View Post
GMEHAL and TODBOT
So far, I cannot do anything with Airstream about the fading.
However, if both of you PM us your regular name and address, we will replace that material, at no charge.
GMEHAL.
Today, we shipped to you, via USPS, 3 rolls of the Orange insert, at no charge.
Sorry it took so long to get Airstream's approval.
Old 01-28-2011, 10:57 PM   #119
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Hedman headers arrived, now I just have to get them on. Trouble is the custom exhaust I had made now needs to be modified for the long tube headers, think I will have to have the same shop install them again and modify the system. Should be good for another 20hp.
Old 01-28-2011, 11:01 PM   #120
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
I'm also thinking it's time to overhaul the gererac generator. It needs a new exhaust system for it so the real questions are,
Is it cheaper to replace? maybe with a similar sized used Onan?
Or do a lite rebuild and make a new exhaust for the generac?
How do you get that thing out anyway?
Old 01-30-2011, 10:08 AM   #121
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Let me know what you find out about the Generator exhaust I need to do the same thing. Can't seem to find out much info about the exhaust here.
My restoration has pretty much stopped minus 20 degrees here can't do much for another month maybe 2.
Got my dash air and heater all cleaned up. Had to have new hoses made up for the air conditioner,The old ones were porous and a new dryer I just have to reinstall and have it recharged.I also had to make new seals for the doors that close off the heat and defrost and fix any cracks and holes in the plastic housing. Also had to replace some of the vacum hoses
shepherd57 is offline   Reply With Quote
Old 02-02-2011, 07:43 PM   #122
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Just got the long tube headers installed on the Moho today and boy what a difference! Way better sound and easily another 15-20hp seat of the pants. Also had a new generator exhaust installed
ID:	121259   Click image for larger version
ID:	121261   Click image for larger version
Old 02-05-2011, 01:17 PM   #123
Octane's Avatar
1977 Argosy 28
1977 28' Argosy 28
Lyngby , Denmark
Nice!
I'm planning on something similar,
would you mind telling me where you got them,
the brand and the price ?
Is it a 'bolt-on' kit or does one have to make some sort of adaptor
to make it fit the rest of the system ( backwards to the mufflers etc. )
Thanks !
“If you don’t follow your dreams, you might as well be a vegetable”
Burt Munro
Octane is offline   Reply With Quote
Old 02-06-2011, 05:15 AM   #124
Octane's Avatar
1977 Argosy 28
1977 28' Argosy 28
Lyngby , Denmark
Originally Posted by Octane View Post
Nice!
Thanks !
I should have payed a bit more attention to your
previous posts, shouldn't I !!?
Answers a couple of my questions.
...you have any idea if the Hedman headers is a direct fit to an original-type exhaust system?
Thanks.
Burt Munro
Old 02-08-2011, 05:13 PM   #125
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Generic generator fun!!! Carb cleaning, removal of old fuel filter and replacing with an online filter, new fuel lines from carb, new run time meter and oil change
ID:	121846   Click image for larger version
Old 02-08-2011, 07:24 PM   #126
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Anybody know how to get the hours counter to work? Seems like the wiring is wrong per PO. Wondering where the + wire goes
argosy
'73 Argosy 20.....Bought! MotorSeven All Argosy Trailers 27 04-11-2007 05:49 PM
Just bought 1975 Argosy 26- RV Newbie RVnDixie Member Introductions 7 06-09-2006 10:29 AM
Hi, I just bought a 1973 20' Argosy!!!! sfixx All Argosy Trailers 8 11-11-2004 09:38 AM
I just bought a '76 28' Argosy MH!!!! Mr.Motorhome Argosy Motorhomes 3 05-17-2004 10:02 PM
