Old 10-06-2010, 01:14 PM   #99
1972 Travelux Princess 25
Cobourg , Ontario
For a deluxe steering wheel you can have it wrapped in leather like the latest luxury cars. Any good auto upholstery shop can do this. Cures cracked wheels too.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 10-07-2010, 02:13 PM   #100
projector's Avatar
1972 23' Safari
NSB , Florida
I'm planning on getting a steering wheel from a junk yard. They're full of cash for clunkers so there should be one arround. I liked the wheel that was on my '87 Suburban. It was the same diameter and ring size, and comfortable. I loved that truck. sniff
projector is offline   Reply With Quote
Old 10-07-2010, 03:31 PM   #101
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by gmehal View Post
The initial cleaning works great, like new! It's a few weeks later that the stickiness slowly starts to return. It's like there's a chemical breakdown happening.
It is possible that the PO had a faux-leather steering wheel wrap on it...the kind you get from WalMart. They used to have a foam padding on the inside that would melt in the heat and stick to the wheel. I never had one, but I've seen the residue on other's steering wheel and they also felt gummy.
I like the idea of having the steering wheel wrapped by an auto upholstery shop.
Family of Disney Fanatics
WBCCI# 4821
Old 10-07-2010, 04:09 PM   #102
PLDodd's Avatar
1975 Argosy 26
Portsmouth , Virginia
wow thats old! vari-jection was a setup to "inject" water, alcohol, jet fuel or whatever into a vacuum hose near the base of the carb in order to get even distribution across all 8 cylinders. haven't seen one in years (lots of years) all the so-called motorheads that used it only thought they had something there instead of doing something real to that "hotrod" trans am of theirs (haha). Piece of advice: when you do get it going for good, if the carb acts funny and the idle stays high from wear in the throttle plate do NOT replace the carb with an across the counter type reman carb. While a quadrajet 4 bbl carb is a quadrajet 4bbl carb they are not all the same (jets, etc. are for certain vehicles and even though physically it is the same, internally it isn't and it will never run right unless it's jetted for the HD 454) If all is well, that camper will roll just as fast as any and will have PLENTY of power!
PLDodd is offline   Reply With Quote
Old 10-07-2010, 04:33 PM   #103
PLDodd's Avatar
1975 Argosy 26
I don't think the steering wheel will ever stop getting sticky once it starts doing that. You are right, it is some kind of wierd chemical breakdown that comes from years of oil from hands, heat, sun etc & then never being touched for a long time. I even had an old set of snap on screwdrivers (old old set, originally purchased in the 60's) that I stopped using when I bought a new set and after a couple of months they started getting sticky & gooey in my toolbox. Good thing is its the same as any old chevy truck or van so finding a good one is probably going to be easy. I even replaced my steering wheel in my 85 Suburban (same wheel you have) with a wheel out of an older Chevy Astro van. I used the sport style wheel, got the tilt levers and all. It fit perfect and looked great, plus it was all oe, no dumb stuff.
Old 10-07-2010, 04:38 PM   #104
PLDodd's Avatar
1975 Argosy 26
Whoops! little late on that one. Big Holley carb is good. Just give 'r all the gas she needs and that baby will run like a top. All those old big blocks just needed FUEL! Helps it run cooler too.
Old 10-16-2010, 02:57 PM   #105
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Since I put the holly carb on it runs like a champ! Double pump as well so plenty of fuel
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Old 10-16-2010, 02:59 PM   #106
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Agreed 100%
I have cleaned it more than once and it just keeps getting sticky. I used to have an old VW eurovan with the same problem, the entire interior plastic panels did the same thing, I eventually sold it because of that
Old 12-12-2010, 09:42 AM   #107
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
GMEHAL and TODBOT
So far, I cannot do anything with Airstream about the fading.
However, if both of you PM us your regular name and address, we will replace that material, at no charge.
Andy I never heard back from you on this and also did not receive any material, did you get the pm I sent you?
Old 12-12-2010, 09:42 AM   #108
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Originally Posted by todbot
I too had fading a few months after installing the new orange trim and purchased through Inland. Although I have no gripe with Inland, I sure wish it stayed true to the original color. I've never said anything other than a grumble under my breath because I assume nothing could or would be done about it.
Did you ever get your material?
Old 12-12-2010, 09:44 AM   #109
No, we did not receive a PM.
Old 12-12-2010, 12:44 PM   #110
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Just resent you the pm again, let me know if you receive it. Thanks
Old 12-12-2010, 12:54 PM   #111
Received your PM ok.
I will contact the powers that be at Airstream tomorrow, and will report back.
Old 12-12-2010, 12:55 PM   #112
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Got the heater finally working. Was easier to get out than I thought. Shown here is the guilty auto ignition board, dinosaur electronics got me a new one for $100 and now it works great. The other photo is my youngest helping with the dissabbemble and the volt meter. Nice to have heat again
ID:	116883   Click image for larger version
argosy
'73 Argosy 20.....Bought! MotorSeven All Argosy Trailers 27 04-11-2007 04:49 PM
Just bought 1975 Argosy 26- RV Newbie RVnDixie Member Introductions 7 06-09-2006 09:29 AM
Hi, I just bought a 1973 20' Argosy!!!! sfixx All Argosy Trailers 8 11-11-2004 08:38 AM
I just bought a '76 28' Argosy MH!!!! Mr.Motorhome Argosy Motorhomes 3 05-17-2004 09:02 PM
