Old 02-08-2011, 07:31 PM   #127
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by gmehal View Post
Anybody know how to get the hours counter to work? Seems like the wiring is wrong per PO. Wondering where the + wire goes
Not sure how your generator is set up but if you can access the hot side of the coil you will see 12V when the switch is on. Another common set up is a sender for an oil pressure idiot light. You will see 12V when the engine makes oil pressure.
Cheers, Dan
Old 02-12-2011, 03:01 AM   #128
Octane's Avatar
1977 Argosy 28
1977 28' Argosy 28
Lyngby , Denmark
Sorry for banging on about this,
but bear with me;
I'm a total novice when it comes to motor-homes
and I know very little about V-8's
Tried to find out where and what to buy
in terms of Headman headers.
Tried the Headman web-site.
Just made my head spin.
Tried another web-site...is this it ?: CLICK
"... Fit Note: Class A Motorhome Fits the following 1978 Chevrolet P30 submodels:
  • 1978: Base; 8 Cyl 7.4L; "GAS, CARB"..."
The note also says they are painted black
unlike the one on your pics...so I'm uncertain
if the same
...you have any idea if the Hedman headers is a direct fit to an original-type exhaust system?
“If you don’t follow your dreams, you might as well be a vegetable”
Burt Munro
Octane is offline   Reply With Quote
Old 02-12-2011, 11:01 AM   #129
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
http://www.hedman.com/products/Defau...set=4572&rsku=
Here ya go, I believe it's the 69820
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Old 02-12-2011, 11:09 AM   #130
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Originally Posted by Smartstream
Not sure how your generator is set up but if you can access the hot side of the coil you will see 12V when the switch is on. Another tcommon set up is a sender for an oil pressure idiot light. You will see 12V when the engine makes oil pressure.
Cheers, Dan
Ok I just got this cool digital meter for the generator, you simply attach a ground wire anywhere and then attach the just wrap the positive wire around the spark plug wire, it's that simple. Now I can view rpm, hours and set a maintenance warning interval. Very cool
Old 02-12-2011, 12:20 PM   #131
Octane's Avatar
1977 Argosy 28
1977 28' Argosy 28
Lyngby , Denmark
Thanks !
Burt Munro
Old 02-12-2011, 02:16 PM   #132
I'm not sure if it is the same but I have a similar meter on my ATV. It is powered by a small watch type battery that lasts about 5 years and is not designed to be replaced. I suppose you could carefully pry it apart but I don't know if you would lose the info recorded.
Mine died and I just haven't been motivated enough to play with it.
Cheers, Dan
Old 02-14-2011, 12:12 AM   #133
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Originally Posted by Octane
Thanks !
I own and automotive related business, let me know if you need me to get the headers for you. Just send me a pm
Old 02-28-2011, 03:22 AM   #134
audiv8q's Avatar
1986 34.5' Airstream 345
Longview , Washington
Send a message via MSN to audiv8q Send a message via Yahoo to audiv8q Send a message via Skype™ to audiv8q
Originally Posted by Inland RV Center, In View Post
As of today, your the only one that has had any problems with the materials, that has made any written or verbal negative comments about them, this year.
He did say "You're the only one THIS YEAR"... Indicating that others may have had problems with the materials during "previous years"...
audiv8q is offline   Reply With Quote
Old 02-28-2011, 03:25 AM   #135
audiv8q's Avatar
The initial cleaning works great, like new! It's a few weeks later that the stickiness slowly starts to return. It's like there's a chemical breakdown happening.
I have had the same problem with the "leather wrapped" steering wheels on several of my Audis over the years. Cleans up nice - even with Windex - but after it sits in the sun for a couple of weeks unused, it gets this sticky, gritty grime that comes off black on my hands.
Old 02-28-2011, 03:26 AM   #136
audiv8q's Avatar
GMEHAL and TODBOT
So far, I cannot do anything with Airstream about the fading.
However, if both of you PM us your regular name and address, we will replace that material, at no charge.
Wow...
No wonder so many here in the forums are happy with Inland RV.
Old 03-29-2011, 10:04 AM   #137
Octane's Avatar
1977 Argosy 28
1977 28' Argosy 28
Lyngby , Denmark
Thanks a lot !
Lars
Burt Munro
Old 04-24-2011, 09:12 PM   #138
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 32
Wow! What a great project! (and price!!). When we replaced the 350 engine in my '75 Argosy 20' MH with a Chevy high performance 330hp engine we thought about fuel injection, but decided to stay with the 4 barrel carburetor. We did add a serpentine belt kit to lower the belt problems.
http://www.airforums.com/forums/f463...-mh-42788.html
Good luck! It's looking great!
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 04-25-2011, 01:40 PM   #139
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Thanks! I am currently replacing most of the copper plumbing, a freeze burst most of it much to my dismay. Chalk it up to new Moho owner stupidity. Is that serpentine belt conversion a kit you bought? I would love to convert to that, those V belts are a total pain!!!
Old 05-17-2011, 12:11 AM   #140
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Well my plumbing nightmare is finally over!! I had to redo the entire plumbing system from scratch. As many of you know a rare freeze burst the copper pipes everywhere. New to the Moho I did not know about winterizing and figured opening the drain valves would simply do the trick. Problem was that the drain for the pipes was so clogged that it never drained. Turns out it was so clogged that it would even hold water pressure when fully open!! Live and learn I guess. So what did I do ? I replaced all the copper with plastic pex pipe. It was easy enough to push along the wall from back to front but working under the sinks was a real pain. I used the shark bite fittings from home depot, expensive but ultra easy to use, highly recommended. I also upgraded the water heater to a 10 gallon dual fuel gas/electric vs. the old 6 gallon. I upgraded the toilet to a nicer oval unit. The old toilets water foot pedal was bad anyway . Much nicer than the old round one. Lastly I installed a antifreeze bypass kit for the water heater and a antifreeze feed for the pump, next year I guarantee you there will be no more busted pipes!!
ID:	130016   Click image for larger version
argosy
'73 Argosy 20.....Bought! MotorSeven All Argosy Trailers 27 04-11-2007 05:49 PM
Just bought 1975 Argosy 26- RV Newbie RVnDixie Member Introductions 7 06-09-2006 10:29 AM
Hi, I just bought a 1973 20' Argosy!!!! sfixx All Argosy Trailers 8 11-11-2004 09:38 AM
I just bought a '76 28' Argosy MH!!!! Mr.Motorhome Argosy Motorhomes 3 05-17-2004 10:02 PM
