Old 10-23-2007, 05:59 PM   #15
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Howie....Because there is no point on the converter to check output voltage...I did what I thought was next best thing....followed the output wire to the DC power distribution panel and checked voltage there. Like I said....with nothing turned on I get 13 volts...granted...that's not amps...but I assume that's pretty normal reading. Now....when you turn on the lights that reading drops to 10 volts. I would think...in order to operate the lights plus keep the battery charged....it should continue to put out somewhere around 13 volts. I will run the test you gave but I ran out of time today....thanks much for your help
Charles
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 10-23-2007, 06:02 PM   #16
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Thanks Ricky.... I will check voltage at the battery tomorrow
Old 10-24-2007, 05:19 PM   #17
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Okay....here's what I get when I check voltage at the aux battery post.
To start with....the ground power (120) has been connected for 24 hours.
I started with unplugging the ground power and took a reading...I got 9 volts. Then I plugged in ground power and I got 13 volts. Then I turned on the lights and the voltage dropped back down to 9 volts.
The troubleshooting continues
Charles
Old 10-24-2007, 05:32 PM   #18
richinny's Avatar
2011 34' Classic
pull that battery and have it tested, it seems to be bad.
Ricky
Old 10-24-2007, 08:05 PM   #19
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sounds like that battery has at least one shorted cell.
Since a battery has to be charged to realy test it I would just try another battery overnight and test in the am.
2004 Excursion 4x4
Old 10-26-2007, 02:16 PM   #20
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Interior lights
I really hate to admit this......
My light problem was just a aux battery very low on water.
What I am wondering about....since that battery is almost new....is it a problem to leave my external power plugged in all the time. I thought the univolt system would just drop off to nothing when the battery was fully charged. It appears to me this isn't the case and it is overcharging the battery...with the results it boils the water out.
Thanks for all your help...you actually did lead me to the problem
Charles
Old 10-26-2007, 02:22 PM   #21
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Boiling batteries is a common issue with the Univolts. Limit the amount of time that the shore power is plugged in or replace the Univolt with a better converter. Converters with 3 stage charging should not have this problem.
Richard
Old 10-26-2007, 04:25 PM   #22
richinny's Avatar
2011 34' Classic
i always like a resolution :-)
the bad news is that your battery may or may not recover. the good news is that it you'll know to watch it now.
Ricky
interior lights towguy Electrical - Systems, Generators, Batteries & Solar 4 06-27-2005 01:03 PM
Interior lights trio Lights - Interior & Exterior 5 08-25-2003 09:03 AM
New interior lights 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 6 05-06-2003 10:34 AM
interior lights jaiman Electrical - Systems, Generators, Batteries & Solar 1 03-03-2003 11:43 AM
Interior lights Daddy4Bob Airstream Motorhome Forums 9 09-25-2002 03:29 PM
