Old 11-22-2014, 10:55 AM   #1
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
ID help requested
I would like to see if someone might help me narrow down the year and model of this argosy motor home. It sits in the same storage lot as my international series and the owner I am told is sick and no longer uses it. It's badged with a 454 (Chevy I assume?)
Ian
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 11-22-2014, 11:07 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The VIN number should be in the windshield. If so call Jackson Center and ask.
2004 Excursion 4x4
Old 11-22-2014, 11:25 AM   #3
Ian
The chassis number is where Howie said.
But, that is a useless number if you call Airstream. Their records don't show chassis numbers back then.
The Airstream factory serial number is located under the hood.
Standing outside, facing the coach, open the hood, look for the left hand side pillar next to the radiator.
You will see a 4 inch vertical strip of aluminum riveted to that pillar.
That, is your Argosy serial number.
Old 11-22-2014, 11:57 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Are you sure it's not a 1979 Airstream? It says "Airstream" on the front, some of the early '79 models were painted like Argosies. If it really IS an Argosy with Airstream badging, it looks like a 1978 model.
Old 11-22-2014, 12:10 PM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Fred's Airstream Archives - Motorhome Class A History - ViewRVs.com
Fred's Airstream Archives - Airstream Class A Motorhome History. ... very good units but do not have all of the bells and whistles that the Airstream models have.
mayco is online now   Reply With Quote
Old 11-22-2014, 01:35 PM   #6
IanPoulin's Avatar
Aldie , Virginia
You are very right then! I was of the thought the argosy would be badged airstream - and the paint took me in. Further, the paint is flaked off the rear end cap and i looked more steel in nature than aluminum - but it may just be the patina. It then is an Airstream motor home. probably a 28' by the looks of it? Supposedly the motor runs well, but I am sure the vehicle would require a ground up rennovation to bring it back to full working order.
Thanks!
Ian
Old 11-22-2014, 03:31 PM   #7
Well Preserved
1993 21' Sovereign
You are very right then! I was of the thought the argosy would be badged airstream - and the paint took me in. Further, the paint is flaked off the rear end cap and i looked more steel in nature than aluminum - but it may just be the patina. It then is an Airstream motor home. probably a 28' by the looks of it? Supposedly the motor runs well, but I am sure the vehicle would require a ground up renovation to bring it back to full working order.
Thanks!
Ian
The end caps on those motor homes were steel, no matter whose name ended up on them.
Old 11-23-2014, 07:57 AM   #8
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Ian,
That is a 1978 Argosy that someone has re-branded as an Airstream. The paint scheme gives it away. It is not that uncommon to see Argosy units painted and re-branded.
Yes, the front and rear caps on an Argosy are galvanized steel. If there is any doubt, you can do the "magnet test". If a magnet sticks, it is galvanized steel. The Airstream units have aluminum front and rear caps.
Based on the windows, it is a center bath and rear bedroom floorplan. The rear would have either twin beds or a rear "salon" (convertible sitting area).
The Argosy units do have a few less bells and whistles but are still very solid units. For example, none of the Argosy motorhomes have leveling jacks or remote start water heaters. The Argosy units have steel rims where many of the Airstream units have Alcoa aluminum rims. Both are built on Chevy P-30 truck chassis. They are good solid units and you can usually get them for far less than the Airstream counterparts.
On an Argosy, the Chevy chassis VIN (used for the title) is in the engine compartment wall (upper left). The Argosy serial number is on the driver's side dash but only visible from the outside window. It is a sticker so many of them have fallen off!
There are a few rare examples of actual painted Airstream units (1979) but those have this paint pattern. I refer them them as transition units. Here is another example.
I hope that helps! Here is a link to my Argosy motorhome page.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Colorado Information Requested: Durango - Silverton - Ouray emdubyadee On The Road... 51 07-26-2011 03:53 AM
Suburban NT35K fURNACE update as requested by Peter Forwood catson4 Furnaces, Heaters, Fireplaces & Air Conditioning 0 02-09-2009 10:54 PM
Toilet removal advice requested Lockwasher Sinks, Showers & Toilets 5 11-14-2004 08:43 AM
