Old 06-04-2009, 11:24 AM   #1
Dr.Theopolis's Avatar
1977 24' Argosy 24
St. Augustine , Florida
How to access inboard side of generator?
I need to access the far side (the inboard side) of my Onan BF generator in my 1977 Argosy 24 to access the cylinder head for maintenance. Does anyone know if this can be done from inside? Is there a panel that was designed to be removed for this purpose?
Dr.Theopolis is offline   Reply With Quote
Old 06-04-2009, 01:23 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I know lots about gen sets, but zip about Argosys. Can you post a pic? Also, what kind of
"maintenance" requires you to be back there?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-04-2009, 02:36 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Dr.Theopolis View Post
...access the cylinder head for maintenance. Does anyone know if this can be done from inside? Is there a panel that was designed to be removed for this purpose?
You can change the plug, but that is about it - to scrape the carbon from the head the genset is removeable without too much difficulty - if you have an engine hoist or a fork lift.
You have to take off the air filter assembly, drop the exhaust, separate the wiring and gas line, and about 4 bolts on the bottom and it will come out of the compartment.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-04-2009, 03:45 PM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
And don't take any shortcuts, and make sure that you have adequate lift in place for the genset when you loosen those bolts. You don't want to drop it on any thing you can squish like arms or feet. The current version of the Onan 4k genset weighs 172 lbs. IIRC, the 7.5 kw Onan in my '85 325 weighed something close to 350 lbs!
Roger
Old 06-09-2009, 07:31 PM   #5
1977 24' Argosy 24
Yay! I finally got the generator out. After I have fixed it all up and have it running good, I'll let you know if I am going to sell it and buy that Yamaha 3000w inverter generator I saw for sale somewhere for an outrageously good price (damn craigslist - makes me make all these decisions). The Onan is from my 1977 Argosy 24 mh (BF model 4kw).
Power side to side leveling idea truckasaurus Jacks, Stabilizers, Lifting and Leveling 12 10-10-2008 10:43 AM
Compare Kipor, Honda, Yamaha quiet generators side by side ShinyTwinkie Generators & Solar Power 17 09-26-2008 09:01 AM
Brake controller side by side comparison Boondocker Brakes & Brake Controllers 4 10-17-2007 12:05 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
