Old 02-04-2009, 04:53 PM   #1
1976 20' Argosy 20
Wilmington , North Carolina
how? moho fuel filler hose
Is there a way to replace the fuel hose from the exterior fill cap to the gas tank without removing or dropping down the tank? MAM
mamanda is offline   Reply With Quote
Old 02-04-2009, 04:57 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
It was easy n my 1951 Chevy Styleline. What vehicle is your question refering to?
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 02-05-2009, 10:54 AM   #3
1976 20' Argosy 20
Fuel line replacement
I have a 1976 Argost 20 ft. Seems to need a new line. The seller replaced it with some inapproiate rubber tubing and it leaks like a seive. Do I need to drop the tank or is it accessable?
MAM
Old 02-09-2009, 08:49 AM   #4
MAM
MAM, I missed your original post.
I can't tell you what size that is but your best bet is to remove the old one and take it with you to a place like NAPA who should be able to find something matching that is fuel rated. The odds are the previous owner used something like a radiator hose when they replaced it. As you've just found out that type of hose doesn't work to well for fuel related areas.
On our 20' Argosy motorhome we have two fuel tanks, one on the left side and one in the rear which is definitely custom made, probably by Airstream. The rear tank won't be to hard to replace the hose, the side tank will have to be dropped to replace the hose.
By the way you might want to try posting your Argosy Motorhome questions in the Motorhome section of the forums. Its easier to keep track of Motorhome related issues that way.
Good luck!
Old 02-09-2009, 09:37 AM   #5
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
I replaced mine on my 1984 Airstream 34.5. Was able to replace without dropping the tank. Went to NAPA they have two different type of hoses one more flexible than the other. I have used both the more flexible one is the way to go.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 02-24-2009, 02:41 PM   #6
1977 28' argosy moho
scarborough , ontario
I replaced mine on my 1977 Argosy 28. It also was done without dropping the tank. My hose must have been the more rigid one since it was a bear to bend properly. I had to remove the sofa behind the driver and the inside cover that keeps gasoline vaours outside to gain access. Good luck!
Warbs is offline   Reply With Quote
Old 02-24-2009, 04:06 PM   #7
Streamline Imperial
SilvrSausage's Avatar
Bellflower , California
Post
Gates makes a very good flexible fuel fill line, in fractional sizes even. Use an accurate caliper to measure to within 1/8 inch, then the length you need.
See here: Gates Marine Engine Fuel Fill Hose - 4663K Fuel Tank Filler - Corrugated
I found what I needed for my SOB moho online, once I had a part number. Annoying at best, to see the hose sweating from its midsection right after putting over 100 gallons at last summer's prices!
Good luck.
It seems I love the mountains and deserts more than my friends do. I sure miss them!
1971 Streamline Imperial project "Silver Snausage", 1985 Coleman tent trailer, 1964 Little Dipper, 1975 Northwest "Proto Toyhauler", 2004 Harbor Freight folding, still seeking my Airstream.
SilvrSausage is offline   Reply With Quote
Old 02-24-2009, 05:13 PM   #8
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
No problem in my argosy 26' just open the curved access panel doors hardest part was getting the old screws out.
Bibbs
bibbs is offline   Reply With Quote
Old 02-24-2009, 05:17 PM   #9
1976 20' Argosy 20
Thanks for the help. I just picked up my moho yesterday after they fabricated a metal line that has a 90'0 angle for a real slow fill. I have not tried it yet. I am still at the ouch phase. MAM
Old 01-12-2014, 04:46 PM   #10
1977 28' Argosy 28
Springfield , Missouri
Hey Warbs where did you find your replacement hose? I have a 77 Argosy 28 that is needing one.
Thanks!
Thadster is offline   Reply With Quote
Old 01-13-2014, 05:55 AM   #11
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Welcome. It is great to see another Argosy 20 motorhome owner on-board.
My fill tube is OK but it is a pain to fill. I think my vent is blocked and the gas fuel fill shuts off if I pull the level all the way out. I have to fill it with the lever 1/4 pulled and watch it carefully so I don't over-fill it.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 01-13-2014, 09:14 AM   #12
Hey Thadster! I got my fuel filler hose from the local GM truck dealer. I chatted up the parts guy and he found a part number and could order it.I think it was sort of generic since it was about 6 inches too long. I remember wrestling with it and I put it in a pail of hot water to make it more pliable. Once I quickly dried it off, it went without too much bad language or skinned knuckles. Good luck!
Gas Tank Filler & Vent Hose geodrake General Motorhome Topics 4 01-05-2011 09:42 PM
Moho Fuel problems doorgunner Mechanics Corner - Engines, Transmission & More... 20 09-15-2008 11:08 AM
Fuel leak in the gas filler hose mrgump Airstream Motorhome Forums 5 04-04-2007 02:51 PM
Leaky fuel filler neck Ray Pena Argosy Motorhomes 8 06-20-2005 10:11 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
