Old 04-11-2008, 07:43 PM   #29
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Brad,
After working with mechanical temperature gauges, there is another feature I like very much. You can monitor temps after you shut everything off. Not that you can do anything about it short of a cool-down supplementary coolant pump, I have seen them, but you can watch what happens during the heat-soak period.
Vaughan
Old 04-11-2008, 07:45 PM   #30
1983 34' Excella
1967 24' Tradewind
Images: 32
Originally Posted by tn2
I've often thought I would like to get a pyrometer.....$40 is not too bad of a price. Hey....thought just crossed my mind....I was wondering what else I might use the meter for....do you think it would work for making fudge....LOL
I personally have found that I prefer my “beverages” at 25 degrees.
Vaughan
Old 04-18-2008, 09:32 PM   #31
geirws's Avatar
Looks like my radiator in my 24 ft 1977 argosy. I have three. One for the engine one for the airconditioner and one for the transmission.
geirws is offline   Reply With Quote
Old 04-18-2008, 10:50 PM   #32
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
second that!
Originally Posted by vswingfield
Hi Brad,
After working with mechanical temperature gauges, there is another feature I like very much. You can monitor temps after you shut everything off. Not that you can do anything about it .
yup I remember those days, Red flag drops, park up high on the track.Kill the motor and watch the temp gauge climb, 240,250,260 man oh man. even higher at times. Finally "moused" a cooler with a 2 gallon bug sprayer and a long hose that sprayed water on the radiator. worked, thinking of maybe doing the same thing on my moho.It worked much better when the car was moving-forward.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 04-19-2008, 11:59 AM   #33
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I have seen a water spray set up on a classic MH. Its's very simple if you sue the "house" water system. All you need is the spay nozzle(s), an electrically operated valve, and some pex. (And a working water pump and water in your tank).
My rig runs cool enough (even when climbing in hot weather) that I don't have a need).
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-27-2013, 04:55 PM   #34
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Originally Posted by QuietWater View Post
If you haven't read the thread "Radiator Blues" that is listed down below the Quick Reply box, do so. It has a wealth of information on removal, repair, replacement, installation, and other cooling issues, like the oil and transmission coolers.
Here is a link to The Radiator Blues thread.
My radiator also has a leak so I am doing the research!
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 09-09-2013, 11:36 PM   #35
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I have a place in Dallas if you need it re-cored. My 76 had to be re-cored. No other options.
MrJ is offline   Reply With Quote
Old 09-10-2013, 06:21 AM   #36
ViewRVs's Avatar
1977 20' Argosy 20
Thanks. I did find a place in Ashland, Kentucky that is going to re-core my radiator (today actually). The first radiator that came in did not match. Re-coring the existing radiator eliminates the problem of finding the right replacement.
Fred H.
Old 09-11-2013, 03:03 PM   #37
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I searched a long time with no success. Re-coreing my 76 was the only option. Getting the radiator out was painful. Next time I'm jacking it up or something.
Going to move the oil cooler when time permits.
radiator hoses GSTAG General Motorhome Topics 8 08-18-2015 07:22 PM
The Radiator Blues swebster Mechanics Corner - Engines, Transmission & More... 46 08-01-2013 08:47 PM
Radiator repair. Howard Lefkowitz Classic Motorhomes 2 08-21-2007 09:32 AM
What's this? Radiator bag? TinCanSue Our Community 4 07-30-2003 08:01 PM
