Old 12-08-2015, 11:12 PM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Heater Valve - need part #?
My heater valve has corroded through. I can't seem to find a replacement that uses the pull wire at Autozone, etc. I don't care about using an exact replacement if someone has an updated solution. 12V switch might work better anyway.. ? Anyone have a part#/vendor? Thanks
MrJ is offline   Reply With Quote
Old 12-09-2015, 05:14 AM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Google "push pull heater core valve" and youll get several hits.
mayco is offline   Reply With Quote
Old 12-09-2015, 06:17 AM   #3
This is the one you should use. It bypasses the heater core when heater control is all the way to cool.
Four Seasons 74643 Heater Control Valve
Old 12-19-2015, 07:48 AM   #4
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I replaced mine a year or so ago. Got it at O'riellys. As I remember the valve lever was the opposite so the cable had to be reworked. These are fun to install. Could they have put it in a more difficult location?
Gregsch is offline   Reply With Quote
Old 12-19-2015, 09:22 AM   #5
Greg, any pictures of the install?
Old 12-20-2015, 03:05 AM   #6
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Thanks for the info. I'm going to move mine down away from the top of the radiator.
Old 12-20-2015, 07:10 AM   #7
Central , Mississippi
Brad,
I'm aware of a drawback to that style valve. If you have a heavy heat load, the heater water is bypassing the radiator and going back to the block.The style that simply shuts off the flow forces all of the coolant thru the radiator.
I ran into issues in street/racecars where they ran hot because of this but admittedly this was at the extreme end of the scale.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-20-2015, 09:53 AM   #8
Vernon, that's an interesting side affect of using the H valve.
I wonder if in addition to the H valve add a manual shut off valve inline with the heater hose to totally shut off flow. A lot of motorhome owners already add the manual shutoff valve that is accessed from under the hood.
Thanks for the tip!
Old 12-22-2015, 06:46 PM   #9
Gregsch's Avatar
Tipp City , Ohio
Found these, does that help?
As I recall the hose near the Prestone tee connects to the valve right inside the firewall then there is a couple inches of hose connecting directly to the heater core.
ID:	254380   Click image for larger version
ID:	254382   Click image for larger version
Old 12-22-2015, 06:51 PM   #10
Gregsch's Avatar
Tipp City , Ohio
Brad, How does this valve work? Does it divert the water flow directly to the return hose? What would be the advantage of that? Looks like my valve stops flow to the heater core thus stopping all circulation.
Old 12-22-2015, 07:06 PM   #11
Greg, as the valve goes closes the H style starts diverting coolant back to the radiator instead of blocking off flow which creates a dead head in the line. Eventually all of the flow would be diverted to the block and flow to the heater core would be blocked.
This valve was a recommended field upgrade by GM for the P-30 chassis although HiHoAgRV indicated that this could also cause over heating of the engine in some high stress applications.
I'll try and find the document that GM provided and post it. It may already be posted on Airforums but I don't know when or by who.
Old 12-22-2015, 07:07 PM   #12
For some reason I thought you were installing the H style of valve.
Old 12-23-2015, 01:06 PM   #13
Greg, here's a little more info on the H valve. I copied this image from this thread.
Name:	heater H valve installation.jpg
The page is also included in the Chevrolet Motorhome Chassis Service Guide.
Old 12-24-2015, 01:43 AM   #14
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hi all
I discovered this week that my heater core is leaking, and many, is that this broken, why carpet was wet all the time.
so now I looked, and I find the right size or if I find out the extent of the tubes are different and then I'll have problems with the valve.
someone has an address where to get the original?
thanks
herman
german6563 is offline   Reply With Quote
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Replacement Sink / Shower Faucet part - No clue on part # natmoody71 Sinks, Showers & Toilets 0 03-07-2010 10:08 AM
Valterra dual dump valve part number? Zstream Waste Systems, Tanks & Totes 0 11-08-2009 03:42 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
