Old 01-25-2009, 09:33 AM   #1
1976 28' Argosy 28
waldron , Indiana
Angry Hard to open windows!!!!!
my 76 argosy has a problem with the windows opening when i bought it it was very clean in side but its that exstream cleaning and the odd and ins that need delt with . the tracks itself are very dirty as i sprayed pb blaster to freeze the windows since its cold right now and i cant do my cleaning. if anyone has had this problem and got a solution would be great as i dont wanna change tracs.thanks
rv-n is offline   Reply With Quote
Old 01-25-2009, 09:42 AM   #2
If the schlegal channel is worn out, or old age, there is no fix, other than replacement.
Old 01-25-2009, 09:52 AM   #3
Andy's got it right. With the age of your Argosy you will have to replace all the seals and tracks in your windows.
This is a project on both of our motorhomes I've got to do this summer as well. Not looking forward to it but its got to be done.
Inland RV has all the parts you'll need for the repairs.
Old 12-19-2009, 03:02 PM   #4
1978 24' Argosy 24
Berkley , Michigan
I've got a 28' Argosy that had really hard to open the windows. The weatherstripping and the tracks are severly worn, but I was able to get the windows to open relatively easy by cleaning the tracks with a stiff, horsehair brush (shoe shine brush) and then spraying silicone in it. It's not a perfect solution, but it works for the short term.
slapshot1031 is offline   Reply With Quote
Old 12-19-2009, 05:00 PM   #5
Your describing aged out Schlegal channel, which is the fuzzy material's name.
Replacing it along with the gray gaskets, will fix the coach up for another 20 years or so.
There is however, a little technique that is used in order to install the fuzzy material, correctly.
After installation, a yearly dose of silicone spray, does wonders.
'Nice' Windows vs. 'Cheap' Windows on New Units AZ-JH Windows & Screens 10 05-08-2008 05:27 PM
Can't open the windows ! IrishRover2 Windows & Screens 13 02-08-2007 04:14 PM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 09:19 AM
Open your frameless windows wide? TomW Windows & Screens 17 08-23-2004 08:14 PM
