If you can, take the air cleaner off and spray a little start fluid into the carb. Then try to start it right away. If you get it to fire a few times, this means you have a fuel supply issue. If not, then a spark issue. My Onan has a couple fuses on it, one of which is for a fuel pump. Check the fuse and the output of the pump to make sure its working. If its a spark issue, check your wires and replace your plugs. My wires press into the caps that go on the plugs so if the wire comes loose it will not get good spark. Report back once you do that and we can go from there if you are still having issues. Hopefully not
