Old 04-22-2015, 05:39 PM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Front interior cap/headliner replacement?
The plastic front interior cap above the driver/passenger in my 1977 continues to crack. Are there any replacements available? If not, what are my options for replacing it?
I did drill tiny holes to stop some cracking but it is falling apart around the sun visor mount.
ViewRVs is offline   Reply With Quote
Old 04-22-2015, 09:05 PM   #2
Mixter's Avatar
1976 27' Overlander
Wood or metal seem to be the most common for those that completely remove the endcaps. I think I'll be doing aluminum, but I'm not quite to that point yet. Colin Hyde just came out with a kit, where he provides the precut and pre-punched aluminum segments. larry b did it in a way that looks relatively painless here: http://www.airforums.com/forums/f46/...ed-102982.html
Mixter is offline   Reply With Quote
Old 04-22-2015, 09:25 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
The aluminum kits won't work in the motorhome cab. I have just had all new aluminum skins added to my 20ft, including the end cap, but the cab is a totally different shape and there is 'nothing' to attach a aluminum panel to - not saying it can't be done, but it is a totally different task to replacing an end cap. I am having to have the original cap refurb'ed and re-installed. I sent Fred a pm saying he can have the cab cap from my donor if it is OK
martin300662 is offline   Reply With Quote
Old 06-30-2015, 05:01 PM   #4
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Fred, Not sure if you did anything with your cap in the last couple months. I just fixed mine by reinforcing it with some ABS plastic. Only time will tell but, right now it seems like the problem is solved. I removed it and made the repair on the back side. Total cost less than $100.
ID:	241975   Click image for larger version
ID:	241977   Click image for larger version
Gregsch is offline   Reply With Quote
Old 06-30-2015, 05:44 PM   #5
ViewRVs's Avatar
1977 20' Argosy 20
I have not done anything yet. Priorities....
That is all good to know. Seems pulling it down and reinforcing it is the only option.
I did hear a rumor that the reason Airstream no longer has these is that the mold was lost in a fire(?).
I was told they are an ABS Plastic with a high petroleum content. This person recommended "Plastic Welding". I was also told to be careful not to get too hot or it will melt (i.e. using an epoxy or resin would create heat).
Did you coat the back with the ABS cement to reinforce it or just work on the broken spots? I was thinking about a full coating of ABS cement on the back to make the whole thing stronger.
Old 06-30-2015, 06:43 PM   #6
1979 23' Safari
Wayland , New York
Just laying down abs cement won't add any support, it's got to be reinforced by something. Did the edges of my end caps by using a 2" strip of aluminum that I gorilla glue epoxied the whole length behind the holes that would support the end cap. Had to do about 1.5-2 ft a day so what I laid down could set without disturbing the epoxy as it began to set. Also drilled the end holes for cracks and reinforced the big cracks same way. I used wood clothes pins covered with masking tape as clamps along the edge.
Old 06-30-2015, 06:45 PM   #7
1979 23' Safari
Wayland , New York
If you cement, glue, or epoxy make sure to clean and rough up the surface a little bit.
Old 06-30-2015, 06:50 PM   #8
1979 23' Safari
Wayland , New York
Use slightly larger holes at the end of the cracks. 1/8-5/32". You can then tape over the hole and fill the hole with epoxy, then sand it smooth when set, it'll be almost unnoticeable if painted over.
Bigger cracks need reinforcement.
Old 06-30-2015, 07:07 PM   #9
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Wonder what the break even point is (in terms of numbers) for getting a new ones made?
I spoke to a local company that can make a mold using my cracked one for around $1500-2000, but was then saying each cap would be around $700, so basically the first 10 would come in at around $900 to cover the cost of the mold.
This seems a little steep when the regular end caps (trailer or motorhome) are available for a little over $300 (Rear End Liner Motorhome Classic and Front and Rear Trailer 1983-1994)
Old 07-01-2015, 05:57 AM   #10
If I remember correctly I also have the front and rear interior caps for a 1986 345. I didn't have the heart to scrap them when I dismantled the 345. They currently reside in my barn loft.
Not so sure your $900 would be considered to much to pay, I believe the real expense would show up when you tried to ship them to their future owners.
1975 24' Argosy Motor Home
Old 07-01-2015, 05:23 PM   #11
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Good point Brad.
I may just have a play with the cracked one I have and see if I could get a mold off of it. It is trashed anyway so worth a try.
Old 07-04-2015, 02:05 PM   #12
Gregsch's Avatar
Tipp City , Ohio
Your shell is ABS. ABS is relatively easy to work with. ABS can be returned to its liquid state by adding MEK. If you mix ABS chips and MEK in a glass jar for a couple days it will turn into a paste. That paste can be formed to any shape and allowed to harden. If you don't like the result simply and MEK and start over. There are several threads on the subject, just search on ABS, MEK.
A previous owner tried to repair my front fascia with fiberglass. That just made a mess.
Old 11-30-2016, 07:21 PM   #13
ViewRVs's Avatar
1977 20' Argosy 20
I have not addressed the cap yet but I might soon.
What are the white pieces? Are they ABS plastic sheets? How thick are they?
So then you used ABS glue between the cap and the reinforcing pieces?
Did you then put up fiberglass insulation behind the cap?
Old 11-30-2016, 07:58 PM   #14
ViewRVs's Avatar
1977 20' Argosy 20
Is this the type of thing you used? This is ABS sheets with a thickness of 0.060".
http://www.eplastics.com/Plastic/ABSWHT0-060HC24X48
Others are saying they used fiberglass sheets and ABS cement.
Old 12-01-2016, 01:12 PM   #15
1982 31' Airstream 310
Henniker , New Hampshire
Here is another source: https://www.mcmaster.com/#standard-p...heets/=15a6us5
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 12-02-2016, 08:36 PM   #16
Gregsch's Avatar
Tipp City , Ohio
Yes, the white pieces are strips of ABS. I got mine from Pop Signs on e-bay but, it looks like the same thing in your link. Use a heat gun to soften the strips on shape them to match the contour of your end cap. I placed a wet rag on the other side of the end cap so that it did not distort when placing the hot strip on the end cap. Often when I let it cool the first time it did not fit as well as I wanted. I simply heated it back up and did it again until I liked the fit.
I used 1/16" and 1/8" pieces. The thinner material is easier to heat and shape but, the thicker is much stronger. I used the thicker material on simple shapes and the thinner material on more complex shapes like around the visors. The key is being patient and getting the shape just right before gluing it up. I used some of the black ABS glue used in plumbing but, I found that plain MEK works as well or better. Just brush the MEK on the surface until there is a significant slurry on the surface of both pieces then quickly assemble them and clamp for 24 hours.
Practice on a couple pieces of scrap until you get the technique down. I think I posted some pics and narrative in my thread 'countdown to kick off'
Old 12-02-2016, 08:44 PM   #17
Gregsch's Avatar
Tipp City , Ohio
Yes, I glued 2" thick fiberglass to the underside of the aluminum skin and let the glue set up overnight before replacing the ABS end cap. I used Formica glue but you can use about anything.
Old 12-13-2016, 04:00 PM   #18
ViewRVs's Avatar
1977 20' Argosy 20
Woo Hoo! I managed to get the 39-year old ABS plastic cap out without it shattering into 1,000 pieces! Clearly Airstream thought the coach would be in the junk yard before that thing needed to be replaced!
Now is the $64,000 question. Do I patched this one together and slap it back up or do we get a mold made from mine and get a brand new one?
ID:	276658   Click image for larger version
Old 12-13-2016, 04:32 PM   #19
ViewRVs's Avatar
1977 20' Argosy 20
What did they do to refurbish it?
Old 12-13-2016, 06:19 PM   #20
Gregsch's Avatar
Tipp City , Ohio
They can be a bear to remove , can't they!
That doesn't look any worse than mine when I started. After repairing mine I did not even have to paint it, I was able to save the original finish.
Brad or Martin have some experience making a mold for the front valance. I bet they could give you an idea what something like that would cost. I would guess a couple thousand to make a mold and the better part of a thousand for each duplicate. They were working with fiberglass, I doubt making duplicates with ABS is an option.
Interior front end cap-How do I fix it? rogerdodger General Interior Topics 20 10-31-2012 06:53 PM
Rear Headliner nightmare (Bath headliner) Mrcrowley General Interior Topics 3 09-11-2010 07:35 PM
headliner replacement ? bikestreamer General Interior Topics 2 10-06-2006 09:43 PM
Measurement needed for '77 interior front headliner kooshka General Interior Topics 1 06-13-2004 06:31 PM
