04-22-2016, 07:27 AM
1978 28' Argosy 28
Victor
, New York
Front Air bags/springs
I finally tore the old airbags from my from coils and need to replace them. What have you guys used as a replacements?
04-22-2016, 08:10 AM
1982 31' Airstream 310
champaign
1978 28' Argosy 28
Victor
, New York
I found a kit on sdtrucksprings meant for the p30 chassis that were made by firestone. Ordered those. Someone at my work bought the same ones for his P30 (Winnebago I think) and said they installed easily.
04-22-2016, 08:11 AM
1978 28' Argosy 28
Victor
, New York
Thanks Mayco! Those are the ones I bought for the front, I dont have rears. Wouldnt mind installing some at some point.
04-22-2016, 12:53 PM
Richmond
, Kentucky
Originally Posted by mprokop87
...Someone at my work bought the same ones for his P30 (Winnebago I think) and said they installed easily.
Whoever your friend is at work is more than welcome to come and install mine!
I found installing them to be one of the more frustrating tasks to undertake on these rigs.
1975 24' Argosy Motor Home
04-22-2016, 01:07 PM
1991 25' Airstream 250
Oxford
, Oxfordshire
Bit of a bugger to fit. Lots of washing up liquid, soften bag first. I think I tied mine with cable ties so it didn't keep unravelling. Make sure the rubber discs are properly in position. Once you have delivered a steady stream of expletives, shredded the skin from your knuckles and spent several hours underneath her - you'll be ready for a beer!
http://www.sdtrucksprings.com/firest...-p30-1963-1999
1979 24' Airstream Excella 24
Tipp City
, Ohio
I'm with Brad on that one. Aggravating. I found that cutting the last 8" off a broom handle made a nice tool for forcing the bladder into the hole in the bottom of the A arm. Squeeze all the air out of it before you roll it up and start trying to get it in the hole. Use plenty of lubricant.
04-22-2016, 02:59 PM
1985 32.5' Airstream 325
Lindsay
, Ontario
I dropped the lower control arms on mine and just slid the bags in much easier than fighting them.
04-30-2016, 12:38 PM
1978 28' Argosy 28
Victor
, New York
I don't know what you guys were talking about . It took about 90 minutes to install the whole thing, including mounting remote fill points.
I vacuumed the air from the bags
Tied them up
And slid them in
The disks were a little tricky but overall it was an easy job.
04-30-2016, 02:07 PM
Richmond
, Kentucky
Show off.....
What did you use for a vacuum pump?
04-30-2016, 02:40 PM
1978 28' Argosy 28
Victor
, New York
Old faithful
04-30-2016, 02:43 PM
Richmond
, Kentucky
Is that an AC system vacuum pump?
Since my suspension is totally apart right now I plan on stuffing the airbags inside the springs before putting the spring between the control arms.
That's the John Warden method
04-30-2016, 02:46 PM
1978 28' Argosy 28
Victor
, New York
It does work for AC systems and I've used it to fix many friend's vehicles. I use it for changing oil on my boat too
04-30-2016, 02:47 PM
1978 28' Argosy 28
Victor
, New York
You better hurry on that suspension work, rally is just over a week away!
04-30-2016, 02:48 PM
Richmond
, Kentucky
Great tip! I knew there would be more uses for the vacuum pump than just AC work
04-30-2016, 02:50 PM
Richmond
, Kentucky
Ain't gonna happen this time
If there's a Get Together next year I "might" be able to drive an empty shell but that's about it.
04-30-2016, 02:57 PM
champaign
But you are coming to the get together.....right?
Mike
04-30-2016, 02:59 PM
Richmond
, Kentucky
Definitely!
I've got a bunch of parts for various people that I will be bringing along.
05-02-2016, 04:52 AM
1978 28' Argosy 28
Austin
Nice work Mike. I've got those exact bags in mine. PO had them done. Frustratingly enough they leak. Not enough to be an issue during a day of driving, but enough to have to pull out the airline and pump them up prior to leaving the campround each trip. Just one extra hassle. I've vowed to replace them with weight matched springs alone next time. Just remove them entirely from the equation.
Great install time.
05-04-2016, 05:53 AM
1977 24' Argosy 24
North Port
Do these air bags really help - does it ride hard or better or what? Please let me know - we are debating doing the same thing.
Elisa
