Old 01-20-2013, 10:04 AM   #1
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
fresh water fill
Does anyone know where I can find a replacement for the fresh water filler? When the previous owner took out the tank they busted it pretty good
mprokop87 is offline   Reply With Quote
Old 01-20-2013, 10:09 AM   #2
Attachment 177064
There is a similar replacement, but not exactly the same.
Old 01-20-2013, 10:28 AM   #3
dznf0g's Avatar
Oswego , Illinois
Andy,
Can you point us to the replacement and would it work for my 07 Classic with some rework. I would like to lose my plastic door (it's the last plastic piece of hardware on my unit). I can't find a suitable stainless or aluminum door with the connections I need for fill and vent. Ideas?
-Rich-
Old 01-20-2013, 10:42 AM   #4
Ottawa , ON
Another source is marine items. Have a look at ebay seller "halfpricemarine" for some nice-looking filler ports.
Not sure how they would work with the air vent on your Airstream though.
Perhaps someone that has already changed out the port could comment.
Old 01-20-2013, 04:30 PM   #5
Where can we find the similar replacement you mentioned? The one on my Argosy has been busted similar to Matt's.
Old 01-20-2013, 05:31 PM   #6
dznf0g's Avatar
Oswego , Illinois
Thanks, Aage,
I've looked a marine sites til I'm blue in the face. The opening in the skin is about 4 or 5" square. I cant find anything that looks like it belongs on the side of an AS. Most of the marine stuff is round and small.
-Rich-
Old 01-20-2013, 06:38 PM   #7
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
I was thinking it over and I might just seal up the opening on my motorhome. Instead I will tap into the city water lines right where it comes through the door and put a valve in so I can fill just by opening the valve (I have to use a hose anyway, right?). There will also be a filter from inside as well so I can use water jugs to fill the tank. I have relocated my water tank to the drivers side on top of the wheel well so I can use the space on the passengers side for storage. I have a second 18 gallon tank that I can place in the storage area on the passengers side in the event of a long trip but it will have to tee it in. We don't go on many trips where a water hook up is not available so I don't see this as a big deal.
Opinions and criticisms are welcome to make sure this is a good idea.
Old 01-20-2013, 06:48 PM   #8
Ottawa , ON
Hi again!
Well, as for the size, a nice square (or even round, I suppose) patch all nicely riveted in would set it off smartly and solve your size problem.
Also, the point of the large square opening is I believe, to give you the ability to fill from any source, like a bucket dipped into a stream, as one example. To remove that opening reduces your possibilities...
Old 01-20-2013, 07:08 PM   #9
Matt,
That's an interesting idea. I've found filling from the potable water opening to be a royal pain in the backside. I assume you would have two valves inside, one feeds the water system directly the other would fill the tank. At the moment I don't see a downside to your plan.
One thing to remember however, the water tank isn't meant to be pressurized so you'll need to be careful about that.
If you need a small patch panel to cover the opening let me know I could probably come up with something.
I might consider doing something similar although instead of water jug filling from the inside I'll just use the existing opening on the outside.
Old 01-20-2013, 08:59 PM   #10
1988 32' Excella
Robbinsville , New Jersey
You will still need a vent for both letting air in while using the water and for when filling. The vent line should be at least as big as the fill line in case you over fill the tank (also located where water coming out wont do damage).
Old 01-21-2013, 05:23 AM   #11
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
I was talking it over with a friend/co-worker this morning and I think I am going to go ahead with it. We ran through a couple of flow diagrams and everything appears that it will work that way I have imagined.
I am going to keep the original filler door but it will be sealed up from the inside. This way I do not have a patch on the outside and if for some reason in the future I wanted to utilize it I could. Also, the two tanks that I have are both vented at the top, all I have to do is connect a garden hose or something similar and run it through a hole in the floor for venting.
I will post some pictures when I am all done.
Old 01-21-2013, 07:25 AM   #12
Matt, sounds like a workable plan. I think you're smart to leave the original filler in place. Something you might consider, since the filler housing is ABS plastic you can repair it well enough to where you could fasten a hose to it. You could then use the filler as your vent to the outside.
After you started this thread I've been thinking about it and since I have to totally replumb the coach I think I'll set things up the way you are with the exception of the vent. I'll just use the existing outside filler port.
