Old 10-09-2007, 09:52 AM   #15
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Uh, better check you AAA policy again. I tried to tow a used car I bought that had frozen brakes. AAA wants to make sure that the car/MH is 1) road ready 2) legally tagged. NOT to discourage you Uwe!
I thought about this MH (it was posted about earlier here and in Craigslist), but the broken windows made me pause (I don't know why the lack of engine wouldn't though! : > ).
Can't wait to hear more!
Good luck Uwe!
Marc
Old 10-09-2007, 10:07 AM   #16
2007 25' Safari FB SE
Suburbia , Sunny So Cal
How much does this Moho wiegh?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 10-09-2007, 10:17 AM   #17
According to the manual for our 74 20' Argosy Moho the weight is around 6700 lbs. For planning purposes I would use 7000 lbs as the curb weight.
Old 10-09-2007, 10:33 AM   #18
uwe
418
uwe's Avatar
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
That's only a little bit more than my old Suburban with a full tank of fuel.
Uwe
www.area63productions.com
Old 10-09-2007, 10:39 AM   #19
Uwe, Let's rent a trailer and go get it.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 10-09-2007, 10:45 AM   #20
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
OK. When? I am open.
Uwe
Old 10-09-2007, 10:48 AM   #21
Uwe, I can call in sick tomorrow and we can go then. Milo
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 10-09-2007, 10:56 AM   #22
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
OK. Let's find a suitable trailer...
Uwe
Old 10-09-2007, 11:04 AM   #23
TIMEMACHINE's Avatar
Huntington Beach , California
call in sick.....everyday
Milo,
You should call in sick even when you do go to "work". I can call in sick and help you guys, but I don't think it would be much help considering I am a few miles away.
Uwe,
Are you selling shares in your new opportunity, I heard str8strm did it with MOHO 2 and was successful in selling 180%....go figure....I am guessing you two are about the same level of deal making.....
Time
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 10-09-2007, 11:40 AM   #24
Uwe,
You will need a trailer that is at 16' to 18' long and at LEAST 7' wide with NO fenders, or a trailer that is 8' wide. The 20' argosy moho sits lower than the newer Classic models so you have to watch for fender clearance on the trailer. We got lucky when we picked ours up since even on our 7' wide x 16' long trailer the tires hung 3" over each side. You'll also need a double or triple axle trailer rated for about 9'000 lbs minimum.
I'd highly recommend chains and load binders along with 2" straps to hold the moho to the trailer. Thats how I tied ours down and it worked great. You'll probably also need a load equalizing hitch.
Oh yeah, also be prepared for a LOT of strange looks from people
Definitely post pictures as the saga unfolds.
Old 10-09-2007, 01:52 PM   #25
JB,
I would be interested in buying the driver's side exterior front and back wheel arch opening aluminum trim if it's straight and door lock assembly.
MCS
911rs is offline   Reply With Quote
Old 10-09-2007, 08:32 PM   #26
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Why use a trailer??
just snag the powerplant from the wrecked burb and do a motor swap in the alley!!
Then drive that bad boy home!
Just thinking outloud!
That thing weighs less than my Excella,
Milo has a big truck; tow it home!
Get er done boys.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 10-09-2007, 08:40 PM   #27
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Originally Posted by doorgunner
Why use a trailer??
Get er done boys.
The burb is gone, unfortunately. It's engine was perfect, though. Too bad.
Working on logistics... car trailers in my area are too small, commercial equipment trailers need air brakes...crazy world when things get 8ft wide.
The owner said that there is a wheel missing, possibly some brake or suspension stuff. Best to go for a ride and take a look, before showing up with moving equipment. Stay tuned.
Uwe
Old 10-13-2007, 07:49 PM   #28
Originally from OR
This is a MH that I picked up along I-5 in OR some three or fours years ago. Sold it to the fellow in SD.
I brought her home on my 3 car flatbed. The towing companies will tow it fine, I had her moved twice on a flatbed, the type that pitches back, lowers and using the winch, pulls it upwards.
No luck tracking down original owners.
Fabian
Fabofabo
fabofabo is offline   Reply With Quote
WANTED: 1977-78 Argosy 20' motorhome litup Argosy Motorhomes 9 04-23-2008 03:58 PM
Free 1978 Argosy 20' Motorhome Craigslist San Diego elfirebob All Argosy Trailers 0 09-22-2007 11:59 PM
Cheap 20' in San Diego secnwind Argosy Motorhomes 3 08-25-2007 12:10 PM
Greetings from San Diego Fenghuang Member Introductions 7 02-10-2007 12:23 PM
San Diego gklott On The Road... 1 08-24-2003 12:20 PM
