Old 06-08-2014, 03:49 PM   #1
In Cornwall's Avatar
Engine won't turn over when hot
Hi all, can anyone help with a mystery with our Argosy 24 engine... When we've been out and stop the engine wont start - it seems the battery is flat BUT if we leave it for a couple of hours - it will start again no problem!
Has anyone come across that problem and knows what it is and what we need to do to fix it?
We'd be very grateful for any wisdom!
Many thanks Chris and Beverly Hill
In Cornwall is offline   Reply With Quote
Old 06-08-2014, 04:14 PM   #2
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
My Dad had a 57 Chevy Wagon which did the same thing. After many years of misdiagnosis, and various attempts to fix, he came to the realization that the battery sat very close to the exhaust manifold and was getting so hot it lost its charge... temporarily. Sometimes the answer is right in front of you.
Tomzstream is offline   Reply With Quote
Old 06-08-2014, 04:26 PM   #3
r carl's Avatar
Lin , Ne
Jump starting will tell you if its the battery, but its probably the starter.
Old 06-08-2014, 04:32 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Check your coil…..I had a 1969 Dodge Dart 340 GTS convertible that wouldn't start when hot. I would have to leave it for 1/2 an hour or so before it would rumble back to life again. It was the main coil that sent boosted power to the distributor.
Work from least expensive to most.
Check battery
Check wires
Check coil
Check starter solenoid
Old 06-08-2014, 04:40 PM   #5
Thank you all - that's some great advice, we'll give them all a go!
Cute thing - even stranded at the gas station we were getting some lovely comments from people about how much they loved our Argosy :-)
Old 06-09-2014, 06:57 AM   #6
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
My 345 did the same thing and my Argosy 20 (both with 454 engines) has hints of that. My hunch is the starter gets too hot from the engine. I think some have put some kind of heat shield around the starter. Check the engines and transmission section (back in the motorhome section) for threads on the starter.
It is pretty embarrassing when your old rig won't start back up at a gas station pump!
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 06-09-2014, 06:59 AM   #7
ViewRVs's Avatar
1977 20' Argosy 20
On your Argosy, the battery is on the side of the coach in a box away from the engine so I doubt the battery is getting too hot. If that was the case, the driver would be cooked as well!
Fred H.
Old 06-09-2014, 07:00 AM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Retarded engine timing can produce this effect.
If the other advice does not fix the issue, advance the distributor a couple degrees.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-09-2014, 07:05 AM   #9
SteveH's Avatar
Common Sense , Texas
Like others have said, I'd bet it's the starter. You didn't say, but we're assuming you have a 454 Chevy engine, and Chevy starters are notorious for doing that. It's called heat soak, and to stop it put a heat shield around the starter. Here's one that should do the trick: http://www.summitracing.com/parts/mrg-3678/overview/
Regards,
Steve
Old 06-09-2014, 08:36 AM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Most Street Rods are powered by Chevy engines. Most have heating problems due to small engine compartments. Many have toe same hot start problem. It seems that the Chevy starter solenoid, which is located on top of the starter, has difficulty working of it gets too hot. Many, including myself, have overcome this frustration problem by installing a Ford type solenoid to operate the Chevy solenoid. I don't know just why this fixes the problem, but it does. Use # 10 wire for the installation. My starter has never failed when hot since I made this modifIcation.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 06-09-2014, 09:24 AM   #11
andreasduess's Avatar
1984 34' International
Toronto , Ontario
One of my old Land Rovers uses to do that. It was the old starter motor getting too hot. A new starter motor fixed it.
andreasduess is offline   Reply With Quote
Old 06-10-2014, 07:04 AM   #12
Thank you all so much for sharing your experience and advice. We have plenty to try this weekend!
Chris and Beverly
Old 06-10-2014, 07:13 AM   #13
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Try this.
http://www.hotrodhardware.com/cartim...01211281358570
Old 06-10-2014, 07:25 AM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
This is from Ron Francis wiring.
Go to their website and read about it. It will solve your hot start. Problem forever.
'02 LY 26', engine won't turn over, no power to dash kardy Land Yacht/Legacy Motorhomes 6 01-28-2014 10:58 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
Lights over bed won't turn on - '79 Sovereign air79 Lights - Interior & Exterior 5 06-30-2011 03:07 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 03:01 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
