Old 06-10-2014, 06:43 PM   #29
r carl's Avatar
Lin , Ne
Originally Posted by Silvertwinkie View Post
Vapor lock? Saw this happen on another engine with a carb as a fuel delivery system.
Originally Posted by Tomzstream View Post
LOL! That was my Dad's best theory until he moved on to the battery being too hot. Then again the starter solenoid theory sounds good too. He sold the 57 chevy wagon for $150 in 68 and never looked back. BTW it was a small block (283 ci). Just saw one on EBAY for 12K reserve not met. They are actually asking 30K on their website. Bet it has the same problem!
I would recommend using the process of elimination, without waiting 30 minutes... Try giving different components a blast from a CO2 extinguisher and see which one responds to the cool down test.
Originally Posted by drboyd View Post
It's the starter solenoid. Common GM issue, as noted above. If you're the adventurous sort, you can get a super-size soda cup of water and throw it up on the starter from underneath. Count to 10 and turn the key.
Obligatory Story:
My son had just graduated from college, and we were driving across the country to take him to grad school in his 76 Nova; it did that at a Subway stop somewhere in Ohio.
Now, he's an annoyingly sharp kid, but when he turned the key and nothing happened, he had this deer in the headlights look that I'd only seen maybe once before on him.
Dad walks back in the Subway with a cup he fished out of the trash, fills it up with water from the fountain, throws it up on the starter, waits a few seconds, and says, "OK - start it now!"
Come on now guy's, he said we get a clunk and then clicks and will not turn over. That means the solenoid is working but not getting sufficient voltage.
Old 06-11-2014, 08:03 AM   #30
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
One more time.
The starter solenoid on a Chevy does more than supply electricity to the starter. It also has the job of kicking the starter bendix gear into the flywheel. When the solenoid gets hot it requires more amperage to do the job. The 14 or sometimes 16 gauge wire from the ignition switch is not large enough to do the job when the solenoid is hot. If you use a Ford type starter solenoid mounted on the fender well or fire wall it will stay cool. Detach the wire that comes from the ignition switch from the Chevy solenoid, and us it to activate the Ford . Use #10 wire from the terminal on the starter where the large battery cable attaches to one of the large terminals on the Ford solenoid, and another #10 wire from the other large terminal on the Ford solenoid to the terminal where you removed the ignition switch wire on the Chevy solenoid. When you hit the start on your key switch the ford solenoid will supply more than enough amperage to the Chevy solenoid to allow it to do it's job when hot. This is what I do on all street rods.
Or, you can get the Ron Francis "Chevy Hot Start Kit". It does the same job the same way.
Or,,,,,,,you can wait until things cool off,or,,,,,,,you can climb under with a hammer and give it a tap (might work) or,,, you can try to cool it off with water.
We all have choices to make in life.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 06-12-2014, 06:04 AM   #31
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
Or you can purchase a nice sized CO2 Fire extinguisher with a funnel spout and blast away to cool it down (a short burst does the trick). Also useful for quick chilling a 6 pack of beer while you wait! LOL!
Tomzstream is offline   Reply With Quote
Old 06-12-2014, 07:47 AM   #32
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Great idea
Now why didn't I think of that. I love a good beer on a hot day
Cheers, Jim
Old 06-12-2014, 01:01 PM   #33
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
After some thought, the fire extinguisher may be better than the actual modification that I outlined. My fix will solve the hot start problem forever, but it will not cool beer, this loosing many opportunities for a cold one.
Old 06-13-2014, 01:34 AM   #34
In Cornwall's Avatar
Thanks Jim, we've got our Chevy supplier checking out a high torque starter and new solenoid and a hear sheet - all angles covered! Sounds like you've had to tell us newby's how to sort it out many times - thank you, you've got your excellent explanation real slick
In Cornwall is offline   Reply With Quote
Old 06-13-2014, 01:36 AM   #35
LOL!! I think we'll forget the new starter and just go for a fire extinguisher - we'll use it on the beers and drink them while the motor cools down 😃
Old 06-13-2014, 06:31 AM   #36
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This thread is one of those epic threads that are started by a simple question which is answered in the very first couple of reply's then continues on to thread hell.
Unless the OP posts what results he found I think this thread should die.
PS as I stated earlier…..it's the coil.
Old 06-13-2014, 06:41 AM   #37
r carl's Avatar
Lin , Ne
The 454 motor probably has a HEI distributor.
Old 07-27-2014, 03:35 PM   #38
Hi guys - just to say a big thank you.
We fitted a new high torque mini starter motor with heat shield and our hot start problem is sorted... We've taken the Argosy on two trips now and he's been perfectly behaved :-) thank goodness - we were staying in the grounds of Sir Walter Raleigh's castle in Sherborne with our hotrod and that would have been embarrassing if we couldn't leave ;-)
Chris and Beverly
Name:	ImageUploadedByAirstream Forums1406493109.389968.jpg
ID:	217539Click image for larger version
Name:	ImageUploadedByAirstream Forums1406493170.873113.jpg
ID:	217540Click image for larger version
Name:	ImageUploadedByAirstream Forums1406493230.503833.jpg
ID:	217541Click image for larger version
Name:	ImageUploadedByAirstream Forums1406493241.451197.jpg
Old 07-27-2014, 06:38 PM   #39
ottawa (greely) , Ontario
You say it's hard to turn over hot I say you need a starter, I would also do a load test on the battery.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
'02 LY 26', engine won't turn over, no power to dash kardy Land Yacht/Legacy Motorhomes 6 01-28-2014 10:58 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
Lights over bed won't turn on - '79 Sovereign air79 Lights - Interior & Exterior 5 06-30-2011 03:07 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 03:01 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
