Old 07-09-2009, 12:35 PM   #1
End Play Specifications on a Argosy 20' MH P-30?
Going to replace the seal on the diff. Wonder if anyone has a shop manual that lists the end play specs? I obtained three different shims from GM but they could not tell me what the set up should be. Brad, you out there?
911rs is offline   Reply With Quote
Old 07-09-2009, 03:20 PM   #2
Matt,
Do you know which rear end is under the 20' Argosy? I have the 74 service manual and can give you the info once we know which one it is. The choices from the manual are:
Chevrolet 8-7/8" ring gear
Chevrolet 10-1/2" ring gear
Dana 10-1/2" ring gear
Dana 9-3/4" ring gear
Chevrolet 12-1/4" ring gear.
I'll go look at mine to see if I can identify which one it is and get back to you with more info. I can scan in the appropriate pages once I know which one it is.
Old 07-09-2009, 04:11 PM   #3
Matt,
I looked at the diff and it is what is considered to be a GM Corporate 14 bolt (12-1/4" ring gear) rear end. There is no mention made of needing shims for any reason. Here are the instructions for replacing the drive pinion oil seal:
1: Disconnect the propeller shaft (dah!)
2: Scribe a line down the pinion stem, pinion nut and companion flange.
3: Use J-8614-11 to remove the pinion nut and the companion flange.
4: Remove the bolts retaining the oil seal retainer to the carrier, and remove the retainer. See figure 77
5: Pry the oil seal from the bore, using care not to damage the machine surfaces. Thoroughly clean all foreign material from the contact area.
6: Lubricate the cavity between the seal lips with a high melting point bearing lubricant.
7: Install a new pinion oil seal into the bore, using J-22281. Be sure seal bottoms against shoulder in bore.
8: Install the bearing retainer to the carrier.
9: Reinstall the companion flange, pinion nut and propeller shaft.
You might check your pinion shaft to see if it is scored or worn. If it is you can probably get a speedi-sleeve to repair it with.
Hope this helps.
ID:	83716   Click image for larger version
Old 07-13-2009, 08:19 AM   #4
Brad, Thanks. very helpful info. Went like a charm this weekend. Now I can park on a incline nose first and not leak and fluid. Matt
Old 07-14-2009, 04:06 AM   #5
Matt, glad you got the seal replaced. Would you happen to know the part number for the seal? I need to replace mine sometime this summer as well.
Old 07-15-2009, 09:50 AM   #6
Brad,
I will try I threw out the box. I purchased it at a Advance Auto store.
Old 07-15-2009, 09:55 AM   #7
Brad, I called Advance and they where able to pull the ticket. Brand was "National" and the part number is #2286
Old 07-15-2009, 10:26 AM   #8
Matt,
Thanks for digging up the number!
What I normally "try" and do is pull the lids off of parts boxes and label them as to what they are for. This way I know what part I used and what part I need to get (or not get) when it goes bad again.
Thanks!
Argosy Minuet 20' Value angeljo57 Member Introductions 1 04-17-2009 07:52 AM
73 20' Argosy Vancanargo20 Member Introductions 2 03-15-2007 07:39 PM
74 Argosy 20' for $? 3x2x4sp389 Trailer Values 6 03-09-2006 01:05 PM
Possible parting of 20' Argosy Rick Alston All Argosy Trailers 7 07-12-2004 08:32 PM
