Old 01-14-2007, 08:58 PM   #1
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
drain tubes?
I am replacing some parts of my floor ,75 26' Argosy MH. I was cutting the remaining wood out of the chanel and found a plastic tube that runs up between the windows and comes out in the small storage compartment over the rear windows. It looks like a drain,but for what? I also have a bigger hole near the door,I think this might have been a drain for the AC but there is no hose ,there was a plastic bump out cover,down on the floor,so the hose could jog around the rim chanel,and the wall is cut open insulation was parted too. Any body have any idea If the AC drain would go there?
thanks to everybody again
Doug
bibbs is offline   Reply With Quote
Old 01-16-2007, 04:43 PM   #2
bibbs's Avatar
1975 26' Argosy 26
Vista , California
anybody? did I ask a forbiden question? Where does the AC condensation go? Do you have drains? Where do they come out?
thanks
Doug
Old 01-16-2007, 04:50 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Doug, I am not sure about your trailer. On my 75 TW the AC drain runs from the unit and down the street side inner wall. It comes out the bottom of the trailer just in front of the wheels. Many of the other trailers of this vintage are the same.
Richard
Old 01-18-2007, 10:46 AM   #4
1977 28' argosy moho
scarborough , ontario
Good question. I don't think it is a FORBIDDEN question however. My answer, unfortunately, is "I have no idea". Sorry 'bout that.
Warbs is offline   Reply With Quote
Old 01-18-2007, 04:04 PM   #5
Doug
What year and length is the trailer?
What make and model AC?
Old 01-18-2007, 04:07 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Let's assume whatever AC came in it from the factory.
Tom
Old 01-18-2007, 04:16 PM   #7
Tom
Assuming is not a good idea when there is trouble.
Different years use different setups.
Old 01-18-2007, 07:26 PM   #8
TomW's Avatar
1967 26' Overlander
Uh, he said it was a 75.
Tom
Old 01-18-2007, 07:53 PM   #9
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I think he said it was a 1975, 26 foot Argosy MH (motor home)? Is it possible that the motor homes had two AC units in those days? I'd like to see a couple of pictures of the two tubes. The front one does make sense as the AC drain. The rear one is a mystery to me. ANy Argosy MH owners out there?
JIm
www.nesa.org
Air No. 6427
Old 01-18-2007, 08:47 PM   #10
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
"Isn't anybody gonna help that poor man"?
As much fun as this has been to read, I hope someone out there has an answer.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 01-19-2007, 09:20 AM   #11
thanks
Doug
The drain line goes through the wall from 1969 and newer.
The drain tube usually is behind the wheel on the left side in the trailers.
Old 02-03-2007, 09:01 PM   #12
bibbs's Avatar
1975 26' Argosy 26
Vista , California
Hi thanks for all your responces I gotta learn to relax more.I had about given up on getting any help.
Pictures,I an working on that,I dont know how yet.
I figured out the rear tube! I looked on my 'parts'74-24ft and the thermometer senser caliper tube goes down to the outside inside it.
the other one was about 1+inch diameter and came out curb side in front of the door, it must be a drain but what happened to the pipe/tube? Why would any one remove it? I think i will pull out the door switches and see if there is any pipe in there.
I dont know what brand ac it is I will look, I think its orignal
Another thing :What kind of door latch would a 75 MH have? Are they repairable?
thanks again
Doug
Old 02-04-2007, 06:56 AM   #13
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Doug, also when you post late at night or at a busy posting time your post will perk down through the portal list of new posts rather fast. If you're posting in the MH section it is very likely that only MH members will see it after it falls off the bottom of the portal list.
My 84 moho had drain lines coming down the wall in the head from the bus type a/c that was tossed when I got it home. It also had coolant hoses from the big condenssor fan assembly in the belly....also tossed.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
