Old 06-04-2007, 11:24 AM   #1
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Door Step
The step on my 28 ft Argosy motorhome does not retract. The vacumn actuator has a leak. The diapham in the actuator is still good....the leak is in the rubber boot (seal) on the actuator rod....see picture
Can anyone tell me if this can be repaired with new seals or will I have to buy a whole new vac actuator?
Thanks Charles
ID:	38606   Click image for larger version
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 06-20-2007, 02:24 PM   #2
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
tn2,
I don't know if any parts are still available for these steps. My solenoid valve shorted out, so I replaced the vacuum step with a two-step electric.
I still have the actuator from my vacuum unit. The seal does not look to bad. It worked fine until the solenoid problem.
It is yours for $5.00 plus shipping.
Rob
Robfike is offline   Reply With Quote
Old 06-21-2007, 03:21 PM   #3
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Vac Actuator
Yes I would very much like to have that actuator....Can you give me a total with shipping to zip 38320. I live in Camden, TN. I'm originally from Terre Haute, IN but live in TN now
email avichal1@peoplepc.com
Thanks much....sure appreciate it
Charles
