02-25-2016, 05:59 AM
1977 24' Argosy 24
North Port
Door Lock Replacement?
Anyone ever replace the door lock? Ours does not seem to be original and does not lock, anyway. I can't sleep with a gun on my pillow all the time!!!
02-25-2016, 09:18 AM
Richmond
, Kentucky
Elisa, there are replacement options available. None of them are original fit and each would require some sort of modification to the door.
I know you can use a Bargman L300 as that is what's on one of the doors I have for my Argosy.
If you decide to go with a Bargman I could probably get you pictures of what needs to be done so you at least have a guide as to what to do.
1975 24' Argosy Motor Home
02-28-2016, 11:14 AM
Dazed and Confused
Hillsburgh
, Ontario
Could you please post pictures and any info written on the lock you presently have in your door that you state is NOT original.
Brad is the man to figure out what and where you can replace it with, but people have butchered other brand locks into Argosy's and Airstreams before so we need to know what size hole and lock brand that you have.
As for the gun under the pillow, I prefer a Kukri as it doesn't wake up the other campers if used properly.
Cheers
Tony
02-26-2017, 05:13 PM
1966 20' Globetrotter
lexington
, Oklahoma
Door lock
I'm interested also in knowing if a door lock from Home Depot, etc would work I have no door lock no deadbolt not even a door knob.
lexington
, Oklahoma
Following... I've got same question.
02-26-2017, 06:30 PM
Richmond
, Kentucky
I doubt you'll find anyone on the motorhome side of the forums that would know much about a 66 Globetrotter!
You would probably have better luck posting your question on the trailer side of the forums.
Good luck!
03-06-2017, 11:49 PM
1991 25' Airstream 250
Oxford
, Oxfordshire
If you are referring to the deadbolt integrated into the silver door handle. I have replaced mine. I used a schlage deadbolt mechanism. Google the site and you'll find some threads. From memory, Brad did one which showed the Airstream modified pin which turns the lock. This seems to fail or cause failure over time, but is an easy fix. Don't drop the mechanism between the skins.
05-12-2017, 08:09 PM
1976 Argosy 20
1974 24' Argosy 24
Los Angeles
Hi
I just had keys made for my 24 and 20 a guy (locksmith) in Phoenix did them he charged me 80 bucks for both locks. You could you take the lock apart and send the appropriate part in the mail?
Mark Kessman 602 242-6422
zkeyman@amarkslockandkey.com
04-05-2018, 03:34 PM
1991 25' Excella
Chino Valley
Hi Brad, when I do searches on my 1991 Excella door handle lockset ~ your name seems to pop up. I hope that you may be kind enough to answer my question.
Symptom: Exterior key side, key would not engage deadbolt but thumb latch inside trailer would engage deadbolt
Action so far: Removed handle and lockset. A lot of rust on back of tumblers where a square shaft is attached. Due to rust it appears that the end of square shaft that is attached to back of tumblers has rusted away. I can literally spin it 360 degrees.
Question: Can I buy an entire replacement assembly or can I buy a new square shaft and replace mine that has rusted away.
Lastly: I would greatly appreciate any guidance you can provide.
04-06-2018, 08:13 AM
Richmond
, Kentucky
I've had the unfortunate experience of having seen three different latch assemblies that Airstream used on the Argosies and Classics
Can you post pictures of your latch assembly? I'm not sure when Airstream changed from the Keeler latch to something new and different. Also are you referring to the latch assembly in the door or as found on the Classics the deadbolt located in the door jam?
Pictures would really help.
04-06-2018, 09:33 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I am following along keenly! Some folks will remember back in Sept'ish 2016 I was using Bella as a mobile base whilst we completed the move back to UK. I got locked out with exactly the same symptoms and put it down to the inner latch lever being fouled by the sliding panel on the screen door. Well it was, but the fundamental problem was that the key throw from outside slides past the point where the bolt moves....the sliding panel fouling just added resistance to the bolt moving and amplified the issue. Since then I have avoided using the dead-bolt unless we are inside!
04-06-2018, 10:18 AM
1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
Trying to repair or replace an older AS lock is difficult at best. If overnight security is prime concern just contact Vintage Trailer Supply in VT. They carry a deadbolt lock that mounts in frame of door. Has a key on exterior. Works well during travel keeping door from swinging open. The dead bolt is cut down to be 1/2" wide not the standard 1".
04-06-2018, 10:24 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
In my case it is the deadbolt, not the regular latch lock that has failed - it looks similar to the VTS unit (below) but the bolt retracts flush back into the lock, not the reinforcing circle of the modern unit and so is not a direct replacement.
04-06-2018, 12:56 PM
Lichfield
, Staffs
Hey Brad looks like mines gone on my 34 limited is this what you used to replace it with??
http://airstreamsupply.com/New-Airstream-Parts/Doors-and-Locks/Handles-and-Hardware?product_id=1670
Also how easy is it from the inside to remove the lock and stuff? It looks like it's in a metal box behind the wall?!
Tom
04-06-2018, 01:02 PM
Lichfield
, Staffs
Mate I think my pin has broken the key turns the lock but not all the way and the latch on the inside doesn't move so I think it's the pin that has broken.....
I've seen this is this the kit you need??
http://airstreamsupply.com/New-Airst...roduct_id=1670
Also how easy is It to access and change?
Tom
04-06-2018, 04:38 PM
Richmond
, Kentucky
Martin, did AS NE install that deadbolt or was it in the door when you bought the Argosy?
04-06-2018, 04:45 PM
Richmond
, Kentucky
Tom
Tom, the only deadbolts I'm familiar with are the ones used in the Airstream Classic motorhomes. The kit in the link you attached doesn't look quite like the ones I'm familiar with. That's not to say it won't work but the long pin is visually different. The ones in the Classic's are about 3/16" square, about 1-1/2" long and the square part is welded to the flat pin as shown in the picture.
If your pin is just broken there's a good chance it can be repaired. The hardest part will probably be in gaining access to the be able to remove things. On the 310 and 345 motorhomes you have to remove the inside door trim and peel back the skin. On the 310 I actually had to cut a hole in the skin due to an interior wall.
04-07-2018, 01:24 AM
Lichfield
, Staffs
Thanks for replying mate and luckily my door trim is off and I can gain access to the rear so I don't need to cut a hole or well I hope I don't heve too ha ha
I'll see how I get on today!
04-07-2018, 01:41 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
AS NE installed a new latch lock/repair panel to let a new latch lock be installed, but the Schlage deadbolt was already there.
The throw when using the tumble latch from inside works great, and the key turn is positive, so I am assuming it is just the tailpiece (at least I think that is the name for the bar that engages the actual bolt!) that is worn. If that is the case I just need a new rim cylinder. The issue is finding one that matches!
04-07-2018, 05:38 AM
Richmond
, Kentucky
I remember AS NE did the entry latch but I couldn't remember about the dead bolt.
Is there any writing or numbers on your existing dead bolt? My guess is if parts are available you won't find them in the UK. Send me what info you can and I'll see what I can find.
