Old 05-07-2018, 12:07 PM   #29
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
I remember AS NE did the entry latch but I couldn't remember about the dead bolt.
Is there any writing or numbers on your existing dead bolt? My guess is if parts are available you won't find them in the UK. Send me what info you can and I'll see what I can find.
I finally got around to following up with this Brad.
It appears I have a fairly standard domestic Schlage deadlock, but the bolt is notched to allow a smaller width hole in the plate.
Name:	2018-05-07 17.02.50.jpg
Name:	2018-05-07 17.03.04.jpg
Name:	2018-05-07 17.05.07.jpg
I can also confirm if I put my thumb on the bolt and try and engage from the inner lever I can't stop the bolt being pushed out. Yet if I do the same with the key the bolt tries to move but then it is possible to totally rotate the key without the bolt pushing my thumb out. I think this means it can't be the cam bar being worn (because that moves the bolt whether using the key or the lever). Hope it is just the cylinder rim needs replacing.
martin300662 is offline   Reply With Quote
Old 05-07-2018, 12:31 PM   #30
Attachment 310398
Attachment 310399
Attachment 310401
Did you want me to try and find a replacement deadbolt assembly?
Old 05-07-2018, 01:14 PM   #31
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Can I hold fire Brad?
I want to remove the current one and have it checked by a local locksmith first
Old 05-07-2018, 03:48 PM   #32
Let me know if there's something you need this side of the pond.
replacement keys for main door lock (have number) nickglase Classic Motorhomes 8 06-22-2017 05:50 AM
Entry Door Lock Replacement mortond Land Yacht/Legacy Motorhomes 8 05-05-2014 09:53 AM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 11:19 AM
Door lock replacement for 1955 trailer "?" RichardT 1950-1955 Flying Cloud 2 10-12-2005 07:29 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-16-2002 12:12 AM
