Old 06-30-2016, 07:15 AM   #1
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
difficult question
I change my transmission TH400 with a new one, I found yesterday driving my Argosy that the speedometer reads wrong, discovered in google I have to change my gear speedometer, I found on google there are different colors for each color corresponds to the amount of teeths. and now comes the difficult question.
the color of gear in the transmission is the same colo geaer in my speedometer?
or as few teeth I know I need to get my speedometer measure correctly?
Herman
german6563 is offline   Reply With Quote
Old 06-30-2016, 08:01 AM   #2
Herman, can you get the gear from your old transmission and use it?
Old 06-30-2016, 08:07 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
these Guys are the best
Fast, responsive and inexpensive. They will answer any question....thing is, they like to text, mostly. I HATE texting.http://stores.ebay.com/LA-Speedomete...=p4634.c0.m322
Old 06-30-2016, 08:13 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
No surprise! I'm thinking about changing the MG four speed transmission to a European Ford five speed. All available as a kit with bell housing, clutch, drive shaft, the works. Except for a recalibrated speedometer.
Lynn
WBCCI 21043
Old 06-30-2016, 12:14 PM   #5
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
hi Brad
unfortunately the old transmission can not recover, was destroyed, so now I have this big problem
Here's the technical service we have to do every 2 years controlled my speedometer and if not in order not give me approval to circulate
I was thinking of placing an electronic speedometer, but the truth not as an official at the Argosy, as it is all mechanical
Herman
Old 06-30-2016, 01:15 PM   #6
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
This site gives a good explanation of how to find the correct gear,
http://www.v8volvo.se/mekartips/arti...eedo-gear.html
You can also check the speedometer error with your GPS.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 07-02-2016, 10:54 AM   #7
1977 20' Argosy 20
Arlington , Texas
Herman, I have had a 77 Argosy with TH400 for a number of years. Last year I went through the "speedometer gear questions". I will have to dig out some old records of what I found but in the end I got everything resolved and the original speedometer works great and is very accurate when I compare to my GPS. By the way any GPS that displays speed has to be accurate in the way that they work. If you are still in the need of speedometer gear information (color and/or number of teeth) respond and I will find my old notes.
Gregg
GWallace is offline   Reply With Quote
Old 07-02-2016, 11:34 PM   #8
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
hi Gregg
I compare with my GPS and speedometer registers a 60% faster, with time tomorrow I'll disarm the wheel with teeth and I'll see how many teeth I have. in the spec sheet says the wheels, from 34 to 42 teeth, but if I calculate my 60% more need 25 extra teeth, for example if I have 34 teeth in the transmission plus 25 I need (equivalent to 2.5% a tooth) Total 52 teeth, so there is something wrong, and before the old transmission worked well.
I am really know what's inside the tranmission
Old 07-03-2016, 12:59 AM   #9
Herman I'm not sure about your numbers. Check out this site.
http://www.jegs.com/p/TCI/TCI-Speedo...langId=-1&No=0
It shows the drive gear for a TH400 trans should be 15 tooth. If you have the 16" tires I'm guessing maybe 30"to 31" dia. and a 4.56 to 1 differential gear using the formula a 44 or 45 tooth driven gear should work.
If you have the 8x19.5 tires at 33.9" dia. the formula shows a 40 or 41 tooth driven gear.
Most Argosy's have a GM 454 engine and TH400 trans and 4.56 differential, if yours is different you will have to change the numbers.
Maybe check to make sure both your speedo and GPS are both reading in miles or kilometers. Good luck
Cheers, Dan
Old 07-03-2016, 05:46 AM   #10
Dan, my 74 20' Argosy has a 4:10 differential. I'm not sure at what point (and length) they made the change to a 4:56. Herman's is a 24' and I wouldn't be surprised if it was a 4:10 as well.
Old 07-03-2016, 08:14 AM   #11
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Herman, look at the Speedometer housing cover, it has numbers written on it. As far as i know thats the only range you can use (like 38 39 40 41)
Your drive gear may not handle any other size gear.
When I swapped out my TH475, the company wanted to know the gear number and the transmission code number.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-03-2016, 10:23 AM   #12
1982 31' Airstream 310
Henniker , New Hampshire
I recently changed my tire size, replacing my old tires with 225/70 R19.5s. The smaller tire diameter resulted in a 6 mph error in my speedo reading. I replaced my original 42 tooth driven gear with a 45 tooth gear and now my speedo reads within 1 mph of my GPS reading. There are two size housings, mine accepted the 45 tooth gear even though it was marked for up to 43. The drive gear can also be changed but that requires the removal of the transmission tail shaft. The driven gear was an easy change, I drove the rear tires into 6" blocks to elevate the rear and was able to take the gear housing out with very little fluid loss.
1982 310 motorhome 454
Henniker New Hampshire
1982 310 motorhome 502
chiefair is offline   Reply With Quote
Old 07-07-2016, 07:00 AM   #13
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hello
I found the solution after experiencing in google, that I need wheel transmission, there is a possibility between the speedometer and the transmission of building a small adjustable transmission according to speed
and ist working
thanks for help
Herman
Old 07-07-2016, 11:04 AM   #14
Originally Posted by german6563 View Post
Hello
and ist working
thanks for help
Herman
Herman, I'm glad you found a solution for your problem!
Can you post a link to what you purchased?
windows difficult to open wolf146 Off Topic Forum 5 04-19-2009 03:51 PM
Difficult to remove AC? 71_safari Furnaces, Heaters, Fireplaces & Air Conditioning 5 07-02-2004 07:04 PM
Ready to Roll a difficult read... Safari Tim Our Community 1 01-20-2004 12:09 PM
Difficult Hot Water Lighting JLD Water Heaters, Filters & Pumps 3 02-23-2003 03:48 PM
How difficult would it be to add... Chuck Waste Systems, Tanks & Totes 5 01-28-2003 10:06 AM
