Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 10-01-2012, 06:14 PM   #1
Deteriorating vent caps
I realize that the Argosy line was the "cheaper" line that Airstream produced but I was definitely surprised this evening when I stood on a step ladder to look at the pipe vent cover(s). Turns out the covers are cheap plastic that are deteriorating rapidly. As you can see by the picture the normal aluminum pipe cover is one heck of a lot nicer than the Argosy version.
At first I thought the Argosy only had one pipe cover and then after taking a closer look I realized there were three. The two that I saved from the 345 are now going to be installed on the Argosy along with one that I will salvage from the 74 Excella trailer.
Unfortunately I only ordered one rubber gasket and screen kit so now I have to order two more
Maybe that will teach me to do a little more research before ordering...nah not likely
1975 24' Argosy Motor Home
Old 10-02-2012, 06:22 AM   #2
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Dang!
I think my 1977 has the same style. I may have to get that replaced before I take it in for painting in 2 weeks! My fridge vent cover is a fiberglass material and is broken in half. I have the aluminum Airstream replacement to get installed as well.
It's hard to tell if those things were are of the "Argosy experiment" or part of the Argosy brand.
ViewRVs is offline   Reply With Quote
Old 10-02-2012, 06:47 AM   #3
Fred,
Does anyone sell the aluminum pipe vent caps? At this point I consider myself lucky that I had two I could remove from the 345 and the old Excella trailer that we have appears to have three on it. I was surprised to see my Argosy has three caps, one for the bath/shower, one for the sink and I'm assuming one for the black water tank.
I would think a place like Colaws might have some in stock. If you strike out send me a PM if it looks like you might need a couple of the aluminum ones.
You could say it is part of the "Argosy experience"
Old 10-02-2012, 07:06 AM   #4
wyomingair's Avatar
1968 26' Overlander
Buffalo , Wyoming
Inland RV has carries the aluminum vent caps for airstreams which should be the same.
wyomingair is offline   Reply With Quote
Old 10-02-2012, 07:16 AM   #5
That's good to know. Thanks for the tip.
Old 10-02-2012, 07:37 AM   #6
ViewRVs's Avatar
1977 20' Argosy 20
You beat me to it! I was just looking up the page!
Inland RV - Vents and Vent Covers
I think he sells the vent cover separate from the gasket and screen!
Old 10-02-2012, 07:52 AM   #7
wyomingair's Avatar
1968 26' Overlander
Buffalo , Wyoming
Yes the screen gasket kits comes separate.
Old 10-02-2012, 08:09 AM   #8
I'm just surprised (and happy) the aluminum pipe cover is still available. At least you should be able to meet your paint schedule now
Old 10-02-2012, 08:32 AM   #9
I didn't realize the fridge vent cover was fiberglass. I'll have to take a look tonight and see what shape it is in. I saved the aluminum vent cover from the 345 so at least I have something to replace it with.
I wonder how many more little surprises are waiting to be found
Old 10-02-2012, 10:24 AM   #10
Retired.
. , At Large
FYI, any Airstream dealer will have those plumbing vent covers and gaskets. The gaskets are still used on the newer trailers that have the cheesy round plastic covers as well.
Old 10-02-2012, 10:59 AM   #11
ViewRVs's Avatar
1977 20' Argosy 20
Here are pictures of my fridge vent cover (original and the replacement aluminum one from Inland RV) and my vent cap.
My vent cap is not aluminum, it is made of the same plastic or fiberglass material that the fridge vent is made of. Mine just has not deteriorated like yours.
ID:	169393   Click image for larger version
ID:	169395   Click image for larger version
Old 10-02-2012, 11:17 AM   #12
The originals are oval shaped, did they not change the shape for the new round ones?
Old 10-02-2012, 01:08 PM   #13
That fiberglass fridge cap looks taller and shorter (side to side) than the aluminum one. Have you taken any measurements to see if the aluminum cover will fit?
Maybe I better pull the shell that attaches to the roof under the vent cap just in case I need it.
Old 10-02-2012, 01:58 PM   #14
ViewRVs's Avatar
1977 20' Argosy 20
According to Inland RV:
Refrigerator Vent Cover, stamped aluminum. 28"L x 8.5"W x 4"H The original vent was made in a small and large size (P/N 84000) if you are replacing a smaller cover we suggest installing rivets and sealer in the old holes and spanning the opening equally with the new vent.
Yes, it is longer so I will need to seal the old rivet holes with new rivets. My understanding is that the larger size is the only one currently available. It is roughly the same width and height. The aluminum one will cover the fridge vent and allow space to .... vent!
Old 10-02-2012, 07:32 PM   #15
wyomingair's Avatar
1968 26' Overlander
Buffalo , Wyoming
I replaced my fiberglass with the longer aluminum vent. Did exactly what Inland suggested with no problems. Looks much better and vents fine. No issue with leaks.
Also getting back to the issue of gasket kits for vents, I simply made my own gasket. I used high quality gasket material you can by at any hardware store. I made a template and cut to specs. I used metal screen on vent pipe which is held in place with a radiator clamp. This is hidden inside the aluminum vent cover. Looks and works great.
Old 10-02-2012, 08:17 PM   #16
Retired.
. , At Large
No, stil using the rubber gaskets under the new plastic covers.
Old 10-03-2012, 03:29 AM   #17
Using a radiator hose clamp is a great idea! I'm going to stop and pick up some hose clamps on the way home from work this evening.
Thanks!!!
Old 10-03-2012, 03:31 AM   #18
That's just weird. The new covers are round, seems like it would make sense to use a round rubber gasket. Who knows, maybe Airstream has a million of them in stock and wants to use them up before changing their shape
Thanks!
Old 10-03-2012, 05:02 AM   #19
Retired.
. , At Large
Thanks!
Now you know what's in that building across the street from the factory...
Old 11-12-2012, 02:54 PM   #20
Brad,
I used pond liner... and did a mod on the vent stack to protect further..
http://www.airforums.com/forums/f455...ons-82910.html
