Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 10-20-2018, 12:58 PM   #1
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Coolant tank
Need help with finding a new coolant tank for '78 Argosy 24' moho. Click image for larger version
All leads appreciated...
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'18 F150 Lariat maxtow --- Liz
tinbender is offline   Reply With Quote
Old 10-20-2018, 02:52 PM   #2
Zil
Curtis Wright
Eyren Haven , South Jersey
I used a gallon antifreeze bottle with some zip ties. But I have seen some universal that look a lot like yours on SummitRacing.com autoparts.
Zil is offline   Reply With Quote
Old 10-20-2018, 08:39 PM   #3
1977 20' Argosy 20
Arlington , Texas
For my my 1977 I purchased from OReilly Auto, part number 603-001 Universal Recovery Tank made by Dorman. It had a tubing nipple on the bottom which I had to drill out for the hose to the radiator. I then mounted it to the plate where the original one was mounted behind the front access cover. The tank came with cap that sealed and would not vent. However in the “Help” section was a vented cap that fit the tank. Except for the capacity being slightly less than the original from Chevy, the replacement has worked just fine. The price locally for the tank is $9.95.
Good luck!
GWallace is offline   Reply With Quote
Old 10-22-2018, 05:53 PM   #4
tinbender's Avatar
2001 16' Bambi
Zil,
You win the creative engineering of the year award!!
GWallace,
I have the one from O'reilly Auto on order.
Thanks to both of you...
Coolant Recovery Tank GTOChucky General Repair Forum 1 10-21-2015 12:08 PM
coolant overflow tank replacement ralley Classic Motorhomes 5 08-14-2014 05:33 AM
Coolant recovery tank for 1992 300LE ... ? Silver City Classic Motorhomes 3 05-01-2011 07:04 PM
Radiator coolant tank Boom Sounds Classic Motorhomes 8 06-30-2008 03:14 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
