Old 11-22-2010, 08:04 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Control panel light
Would anyone know if the red light indicators are available for the control panel. The power on and a couple more are burned out on mine. I tried to take out the bulb but it is not removable with out breaking the tiny wires.
shepherd57 is offline   Reply With Quote
Old 11-22-2010, 08:23 PM   #2
Those bulbs are available from parts stocking dealers.
Old 11-22-2010, 08:34 PM   #3
shepherd57's Avatar
Lindsay , Ontario
Thanks Andy
Do they come complete with the plastic housing because it is wired with 2 tiny wires the size of a hair. I don't mean the bulbs that light the whole panel
John
Old 11-23-2010, 03:33 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Thanks Andy
John
John,
If those are the same ones I have you should be able to get them at an electronics supply house, take the old one with you.
Aaron
WBCCI #XXXX AIR #2495
Old 11-23-2010, 07:33 AM   #5
shepherd57's Avatar
Lindsay , Ontario
Thanks Aaron
I will check that out today
John
Old 11-23-2010, 09:54 AM   #6
blickcd's Avatar
Milford , Ohio
I suspect your bulbs are LED's and you can get those at Radio Shack. You need a soldering iron to remove and replace them. Since they are diodes, there is a right way and wrong way to put them in. Pay attention to which leg is longer when taking the old one out and put the new one in the same way.
On my panel, not only were a few LED's bad, but the logic chip for the gray tank level sensing was bad. Again, it was a Radio Shack item and cheap. Tough to solder all those pins in, but worth it.
Christopher
blickcd is offline   Reply With Quote
Old 11-23-2010, 10:30 AM   #7
power on light
This is Airstream's "power on light" that they have used for many years.
Old 11-24-2010, 09:51 AM   #8
blickcd's Avatar
Milford , Ohio
I have a different power on light. Not sure how many years this monitor panel design was used.
Christopher
Battery Disconnect interior panel red light jsinus 2006 Safari SE 4 04-17-2010 01:21 PM
Bathroom Atwood panel w/center red light RLS Water Heaters, Filters & Pumps 5 10-01-2008 01:34 PM
Need '77 Argosy Motorhome Tail Light Assembly Panel adamstarr Lights - Interior & Exterior 1 09-29-2006 01:58 PM
Removing interior light panel covers... How? WaltL Lights - Interior & Exterior 1 06-24-2006 06:37 AM
AC Power Light on Control Panel? 66Overlander Electrical - Systems, Generators, Batteries & Solar 8 10-20-2005 08:13 PM
