Old 03-13-2012, 06:07 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Chassis Wiring Diagram
I need a P30 chassis wiring diagram for a 1975 Argosy 26ft. My problem is I have no headlights. I have park lights, brake lights, but when I try the headlights nothing. The other strange thing is when I pull on the head lights the left signal indicator and the high beam indicator light up.
Anybody had a problem like this before
shepherd57 is offline   Reply With Quote
Old 03-13-2012, 06:38 PM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
These symptoms usually indicate a ground problem.I'd begin by inspecting the headlight ground from the lightbulb to the chassis itself. You could do a voltage drop test of the ground side to trace the issue or you can just begin by inspecting the wires and connectors themselves. The indicators are lighting up as the missing ground forces the current to try and find an alternate path back to the battery. All kinds of things can happen when you have bad grounds.
Bruce
Bruce B is offline   Reply With Quote
Old 03-14-2012, 08:29 AM   #3
shepherd57's Avatar
Lindsay , Ontario
Thanks Bruce
I have had the dash apart to repair the dash air and re insulate the firewall. So maybe I have removed a ground and didn't realize it.I guess I will have to remove the dash cover again to get access to the wiring. I was hoping I wouldn't have to do that.
I guess there are no wiring diagrams available, Because wiring is not one of my best skills.
Old 03-15-2012, 02:05 AM   #4
Bruce B's Avatar
I always look at the last place I had my hands when something I am working on goes wrong..... I'm guessing you may be correct and I have no idea where the headlight grounds are but I might look at the headlight harnesses themselves before I'd pull the dash apart again. Most of the time the issue is found there at the light itself. It can even be as simple as a corroded connector at the headlight preventing the circuit from functioning (a corroded ground wire at the bulb has exactly the same impact!).
Good luck!
Bruce
Freightliner Chassis, Oshkosh, Clipper masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 40 03-01-2016 09:09 AM
'72 Safari wiring question iscraigh Lights - Interior & Exterior 7 10-13-2013 10:20 AM
wiring for vent fan? paul55 Roof Vents, Skylights & Fans 3 03-13-2012 02:21 PM
wiring for vent fan? paul55 Electrical - Systems, Generators, Batteries & Solar 0 03-12-2012 11:02 AM
2012 airstream interstate 3500 van mercedes benz diesel chassis save huge sale eBay Watch Airstreams on eBay 0 03-10-2012 08:40 AM
