Old 05-15-2009, 09:37 PM   #1
1978 28' Argosy 28
Atlanta , Georgia
Carpeted Univolt Box and other Questions
So I have just a couple of questions after our first stay in the Argosy 28 Moho. I've searched though the forums and couldn't find the answer. so here goes:
1. Our Univolt box is completed carpeted over with no vent other than the exterior vent under the passenger window. Does it need any venting or did it come from the factory this way? The first night we heard quite a bit of cycling fan noise with the lights dimming each time (we were plugged in). After that first night it ran without making any noise and experienced no more dimming.
2. Has anyone done anything to reseal the engine compartment access hatch between the front seats? I think it gets a tight seal, but some of the old seals look like they have seen better days and I want to make sure we don't get any fumes in the coach.
Thanks in advance for sharing any and all of your experiences!
Todd
todbot is offline   Reply With Quote
Old 05-17-2009, 04:18 PM   #2
fozzies's Avatar
1974 Argosy 24
1974 24' Argosy 24
Manningtree , essex
Send a message via Skype™ to fozzies
Don't know about the univolt, sounds as if you had a bad connection with the lights dimming tho. The engine cover on our MH has a hinge along the front edge which makes it quite difficult to seal, but when we picked it up from the port and drove it home (200 miles), it was hanging off anyway and we had no trouble with fumes even tho the exhaust was shot and you could see the road rushing past (noisy too!) When we replace the cover some soundproofing will definitely go in as well as new seals, but probably no hinge this time, just some good overcentre clips.
All the best, Keith and Sara
fozzies is offline   Reply With Quote
protecting beautiful carpeted walls in Excella from cat attack BeccaSue Repairing/Replacing Floor &/or Frame 25 06-02-2008 08:58 PM
Can't get into the battery box! bandboss Doors & Locks 0 07-16-2006 10:09 PM
Univolt replacement questions AV8 Electrical - Systems, Generators, Batteries & Solar 6 09-15-2005 09:55 AM
'78 Tradewind labeled fuse box pics & questions BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 20 06-15-2005 06:33 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
