Old 01-10-2014, 01:50 AM   #1
Loomis , California
Carpet or Wood floors?
In chasing down my water leak, I have removed both the dinette and gaucho. It doesn't take much more to replace the flooring. I am thinking of taking out the carpet and putting in wood flooring.
I am wondering how that has worked out for those who have done this. Any advice is greatly appreciated.
Aldo is offline   Reply With Quote
Old 01-10-2014, 03:46 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
In my opinion... carpet is the silliest idea! I'd go with a very cleanable surface and throw down an area rug.
Who thought a dirt moisture pet hair mold spilled soda sand wet dog ant stinky sponge if a carpet would be a good idea in a camper? I think something like rhino line should be sprayed on at the factory! It can be scrubbed then hosed out if needed! In my Pan America went with solid sheets of textured rubber flooring. Area rugs keep your feet warm in cool weather but overall a dream to clean. Can't wait to do the Classic 34 this coming fall.
Old 01-10-2014, 05:37 AM   #3
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
My motorhome came with carpet and wood flooring. 1st thing I did was clean all the carpets when I purchased it. Then I went camping. Between me and the dog, the carpet was dirty all over again. Running a vacuum cleaner while camping is not my idea of fun, so now all of the carpet has been removed and will be replaced with hardwood flooring throughout. Will keep a bit of carpet in rear bedroom area though.
Just my .02, Derek
Old 01-10-2014, 05:40 AM   #4
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Wood, or laminate, or vinyl sheet goods - get rid of the carpet, you'll be so much happier.
kswelsh is offline   Reply With Quote
Old 01-10-2014, 06:25 AM   #5
Assenede , Europe (Belgium)
I removed my complete floorsystem of my Excella 310 motorhome last winter. I worked my way down up to the Aluminium sheet hat covers the chassis. Have glued 3cm thick (1,18inch) (sorry, living in Europe = decimal system) PIR foam rigid board insulation on top of the aluminium. covered the whole with light weight poplar multiplex board with a thickness of 12mm.(0.47 inch). I then have put on a 2.3mm vinyl floorcovering. Very easy to clean, just put an extra carpet under the table in cold periods. Sweeping the floor is very ease with this vinyl material, it comes in thousands of different designs and colours. Will post some pics. if you want.
EZEtwo is offline   Reply With Quote
Old 01-10-2014, 06:59 AM   #6
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
I might be the only vote here for carpeting…for the following reasons:
It is warmer on the tootsies. It has reduced the road noise noticeably. (also quieter while parked) And, it is no harder to clean than the old vinyl we covered over & easier than the old carpet. What makes it work for us, is a good quality, low nap, stain guard type product, and, yes, running the vacuum occasionally. But I did that with the old floors, too. I also like the way it looks. Here's how it looks after 3 years use.
ID:	203277   Click image for larger version
Schools Out is offline   Reply With Quote
Old 01-10-2014, 07:14 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Carpeting is not a good idea if you do any amount of camping away from paved campsites.
Also trailers tend to leak in non obvious places . Wet carpet in these areas won't dry out and will cause floor problems much sooner than would otherwise happen.
Having had carpeting, tile, and sheet vinyl, my vote goes to sheet vinyl and throw rugs.
Most of our camping is boondocking so we tend to track in much dirt, grass, etc.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-10-2014, 07:53 AM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Seems to me that sheet vinyl product is perhaps the most practical flooring for an RV. Our trailer has a combination of that plus carpet in the lounger area and bedroom and really I wish it were sheet flooring throughout.
Even though there are just two of us and we try to be careful it is hard to keep that carpet looking good.
Our last trailer had carpet with hardwood in the galley/ bathroom area. The hardwood looked great at first, but looked a mess a few years later when condensate leaking from the fridge and water from the shower found its way between the wood strips and caused black mold to appear in those areas!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-10-2014, 08:27 AM   #9
1982 34' Limited
Harrowsmith , Ontario
Actually, I'll vote for carpet too. I know it doesn't make sense for all the reasons listed above (but perhaps having an Airstream doesn't either) - it is a treat for us. We have hardwood throughout our home and this just makes for a nice change. That being said I am vigilant about leaks knowing the issues there.
BradB is offline   Reply With Quote
Old 01-10-2014, 08:53 AM   #10
dougandlori's Avatar
2004 28' Classic
Fresno , California
I just replaced the emerald green carpet in my new to me 99 safari. I read the forums, looked at product and settled on hardwood. Definitely worth the effort to make the change. The hardwood was the most expensive, hardest to install and the detail work of the molding, still a work in progress. I need to get the project completed before the Pinnacles rally next month. If I had to do the project again I wouldn't change a thing.
dougandlori is offline   Reply With Quote
Old 01-10-2014, 09:08 AM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
replaced the carpet with a engineered laminate flooring. Best thing we did in the trailer. Makes it easier to clean and makes it brighter. Our other trailer already had hardwood flooring in it when we bought it. Looks better than the laminate, but has the cracks between the boards. I like the laminate better for traveling.
Old 01-10-2014, 09:40 AM   #12
1974 Argosy 20
Kooskia , Idaho
I am another in favor of carpet in my RV's. I like the warmth of it, I like the fact that you can easily pull it up to look at the condition of the real floor, especially for water leaks, I like the fact that it does hold dirt! Yes. Carpet holds dirt very well and I don't have to constantly chase a small amount of dirt on a solid surface floor all the time.
When the carpet is no longer easily cleaned, I change it out.
Laminate floors are another current fad, and in a few years will be a great way to date an RV... Oh, that was from the 2005 on era.
The silliest thing is the fake laminate flooring in my new 20' FC. It is vinyl flooring made to look like wood laminate which was made to look like real wood. Just nuts in my mind.
Old 01-10-2014, 10:20 AM   #13
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We replaced the carpet with vinyl and throw rugs in our '65 Caravel. The PO of our '83 Excella replaced the carpet in the living and kitchen areas with hard wood and area rugs, still have carpet in the bed and bath areas. Wish the bed and bath were hardwood with throw rugs.
The removable area rugs are easily removed and cleaned. While removed, the hard floors can be easily mopped or swept.
If the floor is cold, we put on socks or slippers. Usually not a problem as the trailers have wheels and are usually in a warm climate.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 01-10-2014, 12:48 PM   #14
1986 31' Sovereign
Miami , Florida
We have laminate everywhere except the bathroom which is Marmoleum. The laminate can be cold on the toesies so we do have some throw rugs. If I had it all to do over again, I'd do the whole rig in the Marmoleum -- it is warmer that the laminate, easily cleans with a wet swiffer and, so far, is indestructible.
Mike
