Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 10-27-2015, 11:41 AM   #1
1977 24' Argosy 24
Smile Carly's Argosy Remodel
Now that October is mostly out of the way, my husband and I are able to dive into the remodel of our Argosy. We are planning to move into it in mid-January, so we've got our work cut out for us. Other complicating factors are: my husband will be having back surgery in mid-November.
We worked on cleaning it out some this past weekend, and I've got a couple photos to share, if I can figure out how to get the files to upload successfully. We still need to pull out the sofa/bed that's just behind the driver's seat as well as remove the kitchen. My husband will be fabricating a new pull out sofa/bed and we will be re-doing the entire kitchen but reusing all the original appliances.
Seridia is offline   Reply With Quote
Old 10-27-2015, 02:22 PM   #2
Carly, you've certainly set an ambitious goal considering your husband's upcoming surgery!
When posting a message look for the paperclip symbol at the top of the editing window. Once you click on the paperclip a window should pop up with a "Choose File" button. Click on the button and follow the directions from there.
Looking forward to pictures
1975 24' Argosy Motor Home
Old 10-28-2015, 07:06 AM   #3
1977 24' Argosy 24
Brad,
It's definitely an ambitious goal. We're not likely to get much more than the bed and the work station completed before we move into it, but that's okay.
The issue I'm having when trying to upload photos is that it always says they fail to upload. I've tried via the website and even installed the mobile app on my phone to try to upload directly from there. Still no success.
-Carly
Old 10-28-2015, 07:27 AM   #4
1977 24' Argosy 24
I can't get pictures to upload, but I can provide a link to them, so here we go:
This picture shows part of the kitchen and where the second sofa/bed used to be. This will be the workstation area.
Imgur: The most awesome images on the Internet
This shows part of the driver area and where the first sofa/bed used to be. My husband will be re-building the bed to take a full size futon with drawers for storage underneath.
Today my husband plans to replace the rotted floorboards you can see in the second picture. I realized after starting to pull things out that the prior owners had painted part of the shell. I plan to re-paint everything to give it a fresh, clean feeling surface.
Old 10-28-2015, 07:27 AM   #5
Have you checked the picture size that you're trying to upload.
There are limits to picture sizes that you might be running up against. I think supporting members can upload larger pictures. As a test try reducing the image resolution from whatever your file is to something like 1600x1200 or smaller and try again.
I always use 1600 x 1200.
Old 10-28-2015, 07:53 AM   #6
1977 24' Argosy 24
Brad,
They are definitely within size requirements. Fortunately I can post links to the pictures.
This first image shows what was the second sofa/bed and which will become a workstation. On the left I'm going to have my desk setup and the area below the desk will hopefully be able to hold the two bar stools I have.
Photo 1
The second image shows the first sofa/bed which will be re-built to hold a full size futon and have drawers underneath for storage.
Photo 2
Today my husband will be replacing the rotted floorboards there just behind the driver's seat.
During demolition I also discovered that the prior owner had repainted quite a bit of the inner shell. My goal today is to prep the areas to get a fresh coat of primer and maybe the primer itself. I think it'll help give everything a fresh and cleaner look/feel. Most of the surfaces are unnervingly sticky right now, even after using Clorox wipes.
-Carly
Old 10-28-2015, 08:22 AM   #7
1977 24' Argosy 24
Brad,
Sadly my photo size was already smaller than that. And I wasn't reaching the file size limit, either. I've got a post with some links to my photos awaiting moderator approval.
-Carly
Old 10-28-2015, 08:34 AM   #8
I'll see if I can upload a picture as I haven't tried in a few days.
Must be a problem with either your login or computer system you're using. Hopefully a moderator will look into shortly.
Old 10-28-2015, 06:11 PM   #9
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Please try again with the images - we've been having some server issues and believe they are fixed now.
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-28-2015, 08:25 PM   #10
1977 24' Argosy 24
So now my photos appear to be loading correctly. Hooray! I feel a little silly that the two posts I made earlier with the photos as links are now both showing in the thread. I think I didn't realize what had happened the first time and thought the post just didn't go through.
Here are the photos, just so they're available in thread.
We did some more work on the interior tonight. My husband patched the rotted part of the floor and I cleaned (and cleaned and cleaned) the wall just behind the driver seat, ran some mineral spirits over it, and then put on a coat of primer. We'll see how well it holds up. I've heard there can be some difficulty in painting the interiors.
Here's how it looks when we finished working this evening. I plan to do another coat of primer before painting color. I do plan to leave the faux wood paneling the way it is, but I'm going to take out the partition that's right next to the kitchen counter.
-Carly
Old 10-29-2015, 04:48 AM   #11
Your Argosy appears to be in reasonably good condition. If that's the only floor damage then you got real lucky!
There area lot of threads dealing with painting the interior walls although I haven't paid to much attention to them as I don't plan on painting the interior walls. You might browse through this forum for ideas as to how to deal with wall painting.
Old 10-29-2015, 08:58 AM   #12
1977 24' Argosy 24
I think we got super lucky on this Argosy. The vacuum hoses in the engine need to be re-done, but otherwise it runs pretty well. The onboard generator had also been recently worked on. We haven't tried really using the water system yet, but my husband advises that he tested it and it seemed fine.
A lot of the interior was original when we got it. He pulled up the shag carpet off the floor before he surprised me with the vehicle at a campout in late May (what a surprise!).
Eventually we are considering doing some remodel work in the bathroom. Specifically, he is wanting to make the shower bigger. He's over 6' tall, so that shower is pretty teeny for him.
Thanks for the link to the threads on paint. I'll definitely give them a look.
Old 10-29-2015, 04:51 PM   #13
I've found the real problem with the showers is the curvature of the outside wall. That really limits headroom.
It will be interesting to see what he comes up with as a shower mod.
Old 10-30-2015, 07:43 AM   #14
1977 24' Argosy 24
His plan is to potentially take out the closet that's next to the shower and just make the space wider. This will also give the shower access to more headroom as it'll put it into the body of the RV a little more. Time will tell if we decide we can get rid of that closet space, though.
-Carly
Old 10-30-2015, 04:54 PM   #15
-Carly
Hmm, I think I sense a difference of opinion...
Airstream Argosy Office Remodel - FINISHED WITH PICTURES! Wgbarrbevco Interior Restoration Forum 21 05-11-2013 07:39 PM
1978 30' Argosy Remodel - Here we go! Markeyro All Argosy Trailers 44 12-09-2012 06:00 AM
Update on '74 Argosy 26' remodel TG Twinkie All Argosy Trailers 13 09-12-2012 10:08 PM
1975 Argosy Remodel Pics Apache_Camp General Interior Topics 0 08-04-2009 07:13 PM
Argosy 28' remodel rodkerns Argosy Motorhomes 5 04-19-2005 02:47 PM
