Old 04-21-2014, 01:14 PM   #1
Stephenssg's Avatar
1977 28' Argosy 28
Katy , Texas
Brake Line Pins for '77 Argosy
Hello, everyone!
My 1977 Argosy has been at the shop for around 6 months now. The mechanic is trying to install new brake lines, but says he is held up because he can not find the right brake line pins anywhere (he can't even figure out what size they need to be).
I'm tired of waiting, and we have a cook-off to attend in May, so I told the mechanic I would turn to my trusty, knowledgeable and helpful friends in this forum for ideas on where we can find the pins.
I am not a mechanic, nor am I the least bit mechanically informed/educated. So I hope what I've said makes sense, and that someone can help me.
(The mechanic also says the RV's rear end needs to be rebuilt, but he's afraid to touch it. Any suggestions for a shop in the Houston area that can address this would be greatly appreciated).
Thanks, everyone!
Sara
Stephenssg is offline   Reply With Quote
Old 04-21-2014, 01:41 PM   #2
1974 Argosy 20
Kooskia , Idaho
Argosy motorhomes were built on Chev P-30 chassis and so any engine, transmission, brake and rear end parts should be very standard issue and available from GM and GM truck dealers. The chassis VIN number should be all you need to get the correct parts. I think you need a different mechanic.
Old 04-21-2014, 02:29 PM   #3
1977 Argosy 24
Milltown , Wisconsin
What is a brake line pin? Worked around cars and trucks for 50 years and never heard of a brake line pin.
ventport is offline   Reply With Quote
Old 04-21-2014, 02:58 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, me too!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-21-2014, 03:02 PM   #5
Salem , Oregon
Images: 18
Hi, maybe he means caliper pins? I haven't had my P-30 for about 20 years now. I worked at new car dealers as a mechanic since 1968 [now retired] and never heard of a brake line pin.
2005 Safari 25-B
Old 04-21-2014, 04:18 PM   #6
Stephenssg's Avatar
1977 28' Argosy 28
Katy , Texas
He just said "pins," and they were for the brake line job, so I just put the two together. If caliper pins make sense, then that's probably what he's talking about. I wish I understood more about it. It just mystifies me that the mechanic is so helpless. I think you guys are right. I need a new mechanic--fast.
Thank you for responding!
Old 04-22-2014, 06:47 AM   #7
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
I just re-did all of the brakes on my 76 Argosy within the past month and had no need for new pins. Your rig might be in slightly different condition than mine but I just cleaned the caliper 'pins' off and applied new lubricant. For my rears, which were in excellent shape, I just blasted the dust out and replaced one wheel cylinder. Those P30 chasis were built really well so a lot of the stuff can be reused as long as its not worn and its cleaned really well.
mprokop87 is offline   Reply With Quote
brake shoe retainer springs and pins.. safari25-05 Brakes & Brake Controllers 1 04-08-2007 05:17 PM
Source for ZipDee Snap Pins? Bob Thompson Awnings 7 03-19-2007 05:04 PM
Door Hinge Pins on 79 Excella Dano57 Doors & Locks 1 07-24-2006 07:35 PM
Cleco pins eubank Ribs, Skins & Rivets 8 02-23-2006 12:14 AM
toilet seat hinge pins? JohnGalt48 Sinks, Showers & Toilets 1 06-28-2004 11:05 AM
