Old 10-02-2018, 02:19 PM   #29
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I don't want to get too far out but every cab over or forward control truck with a manual transmission has a long linkage setup from the shift lever back to the transmission. Cars with front engine/rear wheel drive that have a manual transmission and column shift have interesting linkage from shift lever to the transmission. It' just not a difficult problem to solve.
Tony my 2 CV has a tiny trans with the normal shift lever coming straight up from the top of the box. It is connected by a simple link to a horizontal shift lever coming through the dash. It is shifted by pushing or pulling the lever and twisting side to side. A very simple system that works very well.
Cheers, Dan
~ Margaret Thatcher ~
Old 10-02-2018, 02:25 PM   #30
Originally Posted by Isuzusweet View Post
By Jove, I've got it!
My Grandfather owned a Renault back in the UK that had the shifter coming out of the dash. I think my Dad's Citroen 2CV had the same dash mounted shifter.
So shifter is in the dash hooked up to some sort of electronics box that would recognize what gear was being selected; sending a signal down to another box that would actually select the gear.
Easy, peasy.....right?
Cheers
Sidekick Tony
Easy if you're in my line of work which is Automation Engineering
Old 10-02-2018, 03:30 PM   #31
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I can tell you guys are warming to the idea....well being less hostile any way!
martin300662 is offline   Reply With Quote
Old 10-02-2018, 04:08 PM   #32
This is a YouTube on 2 CV.
You can see the under hood linkage @ 3:00 minutes in and the shift lever operation @ 4:30. Fun little cars.
Cheers, Dan
Old 10-02-2018, 04:51 PM   #33
Well.....I'm no sure I'd go quite that far....
Old 10-03-2018, 07:21 AM   #34
1977 24' Argosy 24
Space Coast , Florida
Everything I have seen in this thread I have taken as encouragement!
I am a fabricator. I have ideas in my head that I will never be able to implement because I am more creative than capable, but I never shy away from a challenge.
This thread is tremendous, I am grateful for the inspiration it is creating.
The dash in our Argosy has already been removed. In my opinion, it has always begged for a redesign. I have done this before with great success both on vehicles and airplanes. It would now be a simple task to replace the General Motors instruments with the gauges from the donor. The biggest benefit here is the ability to redesign the air conditioning distribution system. Huge added benefit. We live in Florida and our destinations of choice definitely tend towards warmer climes.
The biggest factor that grabbed me, or hooked me here, was this picture posted by martin300662 on the 1975 Argosy value thread.
It shows the Cummins power plant resting in the frame rails with a magnificent manual shift lever sitting within very close proximity of where the Argosy driverís seat should be. In my "Imagineering" of a diesel conversion, I have not found a practical solution to this. Manual is definitely my preference. I've been looking for a way do fabricate this on a dodge pick up donor, and here it is.
It makes more sense in the whole scheme.
I know registration can be a huge issue, and importation even more so. The goal here is to modify our 40 year old Argosy, not build a DAF motorhome and take it to another country, so thats what I'll focus on.
Big Mahalo! keep it coming.
mikeajana is offline   Reply With Quote
Old 10-03-2018, 07:26 AM   #35
1977 24' Argosy 24
Swapping over a dashboard into an Argosy from any other vehicle would be no easy task.......I'm still hopeful I can somehow transfer the main dashboard binnacle from the Bounder to the Argosy.....all I'm saying is this; the newer the donor vehicle, the harder it gets. The wiring harnesses that I saw in the Isuzu NPR scared the beejeezers out of me as there were going to computers, fuse boxes and sensors everywhere on the truck, leaving me wondering on stuff like, how was I going to incooperate the Isuzu huge air box and tube affair, (which had maintainance and performance sensors all over it), into the Argosy.
I decided it was way above my pay grade.
Cheers
Sidekick Tony
I see this as a fun challenge, like a puzzle.
It gets me so excited and keeps me awake and my the shop.
I get so immersed in it that my wife brings our dinner to the project, something we both enjoy.
Old 10-03-2018, 07:28 AM   #36
1977 24' Argosy 24
I'm warm to the idea.
Old 10-03-2018, 08:17 AM   #37
1977 24' Argosy 24
So I had to go visit the Argosy and her paperwork for a picture.
Here is or VIN plate, riveted to the Body:
and also the title, which identifies ARGS as the make.
ID:	324344   Click image for larger version
Old 10-03-2018, 08:36 AM   #38
The question is which vin number is on the title. Is it the CPY number or does it start with an M? The M number is the Airstream provided vin number which is what mine is titled under. If your's is the CPY number, that is the GM number and theoretically if you replace the chassis you're eliminating the CPY number.
I don't know if GM stamped the chassis with the CPY number like some manufacturers do, if so when you remove the GM chassis and put in a DAF chassis you're changing the vin. Technically the GM vin plate is riveted to part of the GM chassis. However when you swap chassis I doubt you'll be removing the firewall which would mean the GM vin plate stays where it is.
I guess it would all boil down to who does the inspections, how smart they are and just how much do they want to ruin your day!
Old 10-03-2018, 09:13 AM   #39
1977 24' Argosy 24
Title says ARGS. The number is CPY, not M.
It is the GM plate, riveted to the firewall that has the VIN number matching the title.
The plate says MFD by General Motors, same as my Oldsmobile and Corvette.
We would not touch this plate.
Vin plate stays where it is, registration stays where it is.
Most important, nothing with another VIN stamp gets transferred to the Argosy.
I love adventures, we can ship anywhere in North America that has a favorable entry point.
"All we did was repair and upgrade, officer"; an easier argument on 40 year old metal, one would hope.
IMHO Buying one of these commercial trucks and placing an Argosy body on top presents a host of new problems....
Meeting DOT regulations of your particular country you live in; let alone the one you drive into.
Also these are commercial vehicles, with possibly front beam with spring axles up front and really heavy duty spring axles out back; giving you a ride akin to an old western buckboard. I'd drive the truck before I'd dive into it.
Cheers
Sidekick Tony
This one seems like an easy fix to me. The DAF 4x4 chassis has leaf springs front and rear, as far as I can tell from the pictures. To lighten the ride, remove a leaf or 2 from each spring pack.
I've changed spring rates on numerous different vehicles in the driveway. Or take it to a spring shop and they can make a new set or modify yours.
We did it to several former Uhaul 28 foot box trucks we converted to mobile Foam Insulation spray rigs. The uhauls were a little weak for what we were hauling. A spring shop added a leaf to the existing springs and voila, it carried the 10,000 pound load like a champ.
We did it to a big 4x4 truck chassis in my youth, when we mated a mustang body with big mud bog tires. Pulled several leafs off and it worked.
My thought and opinion, but I'm not claiming to be a rocket surgeon.
Old 10-03-2018, 02:07 PM   #40
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Ok now we are getting to some of the specifics. If you are going the DAF 45 4x4 route (and remember they are not a dually rear axle so check the weight capacity) and you want a LHD I would look as some of the online vendors of ex-MOD trucks some list on eBay but others have online stores. These will not yet be registered for civilian use on the road but can be bought for export only so will not ever be registered for use in the UK.
Old 10-08-2018, 12:22 AM   #41
1974 24' Argosy 24
Glenns Ferry , Idaho
I have a argosy 24 that i put a 6bt 5.9 in it is a grate improvment over the 454. I have sense put a 6bt in a FMC 2900r will be selling the argosy. Your cheapest way is to put the dodge 4x4 axle under the p30 frame. I wold be glad to share info with you. call me at 208-590-1898 best Jim
JT5.9 is offline   Reply With Quote
Old 12-28-2018, 06:16 PM   #42
1977 24' Argosy 24
Nice talking to you today Jim.
I appreciate the information and encouragement.
Airforums.com is awesome!
Martin, have you shipped a Motorhome to Europe already?
I am hard at researching. I'll be back in Eastern Europe in April.
Argosy Drivetrain Swap mprokop87 Argosy Motorhomes 16 02-06-2016 06:47 PM
'78 Argosy converter swap wildwetz Batteries, Univolts, Converters & Inverters 15 01-26-2015 07:57 AM
1977 Argosy 20' w/454...Shall I swap to Fuel Injection?? Your Comments Welcome! jbsails Mechanics Corner - Engines, Transmission & More... 24 02-01-2012 10:31 AM
Argosy Engine swap beemergb Argosy Motorhomes 3 11-07-2011 09:14 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 02:25 PM
