Old 10-01-2010, 04:53 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Blower motor
I have a very noisy heater blower motor sounds like the bushings are loose it vibrates the dash when I run it. Dose anybody know how to remove one from the dash. Do I have to remove the entire dash to get to the blower.
Is there a manual that would cover the re & re of the heater motor on the 1975 P30 Chassis
shepherd57 is offline   Reply With Quote
Old 10-01-2010, 05:48 PM   #2
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Thumbs up
If it is the same as an '86 345, it is an easy job.
There is a carpeted vertical panel in front of the passenger seating area. Below the padded dash. Remove it and the heater/AC unit is behind the panel.
There should be a large black metal "box" which is the heater/AC unit. Remove the cover of the box, and you will see the blower motor, fans, heater coil, and AC condenser.
From here the motor with the dual fans are easy to remove. When I had mine out I discovered that I had a small heater core leak, so I had a little more work to do to remove it and have it resealed.
Good luck, Rob
Robfike is offline   Reply With Quote
Old 10-01-2010, 07:11 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Hmm, might open the hood and take a look, ours is in plain sight on the left hand side.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-01-2010, 07:27 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'm with Rob, ours is behind the passenger kick panel. Just pull the panel and everything is right there.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 10-01-2010, 07:29 PM   #5
shepherd57's Avatar
Lindsay , Ontario
Thanks Rob
I have the top off the dash and that panel out but I could not fiquer out how to remove the black panel.There is 2 small holes in it and I can see the end of the blowers. I will have another look in the daylight tomorrow and take a picture.
John
Old 10-01-2010, 07:39 PM   #6
James Rogers's Avatar
1987 34.5' Airstream 345
Dandridge , Tennessee
go to "replacing blower motor for dash ac". They have some good photos on how to find the blower and how to get it out. I had mine repaired and it still squeals. Them I found this site on the forum.
James Rogers is offline   Reply With Quote
Old 10-01-2010, 09:16 PM   #7
shepherd57's Avatar
Lindsay , Ontario
I tried to search for that can't seem to find that post
Old 10-01-2010, 09:43 PM   #8
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Try this link. the photos start aound post 21.http://www.airforums.com/forums/f311...tml#post342973
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-02-2010, 08:33 AM   #9
shepherd57's Avatar
Lindsay , Ontario
mine seems to be a bit different.It looks like the top alum piece has to come off and it has to be accessed from the top
Name:	Window leak repair 029.jpg
ID:	112142   Click image for larger version
Name:	Window leak repair 032.jpg
Old 10-02-2010, 08:39 AM   #10
shepherd57's Avatar
Lindsay , Ontario
Here is the top it looks like someone has been in there at one time.I can't see another way to get in to the motors. There is no door in the front of mine???
Name:	Window leak repair 031.jpg
Old 10-02-2010, 05:47 PM   #11
1977 20' Argosy 20
san diego , California
Before you go much further you might want spraying some WD-40 to the fan intake. Sounds like a problem I've had before. Seems like I've had to repeat that about every year and a half, for the last eight years.
So far it's worked for me.
Keith
argy is offline   Reply With Quote
Old 10-02-2010, 07:19 PM   #12
shepherd57's Avatar
Lindsay , Ontario
Blower Update
Well I finally have the heater,AC blowers out. And one of the blower wheels not running true i.e. it has a lot of run out and that is causing the vibrations. I am going to take it apart and see if I can true it up.If I can't I will be on the hunt for a new one or a good used one.
How to remove a blower housing from a 1975 26ft Argosy.
1 Remove the top plastic dash cover be very careful it is old and brittle.
2 Remove the plastic trim panel on the pass side below dash.
3 Drill out all of the rivets on the alum plate that is below the plastic dash and remove, In my case someone had been in there and cut this plate in half at the center of the windshield.this plate is off you will have access to the top of the blower housing. There are about 10 screws that hold the plastic duct on top of the housing. Once that is off you will see the blowers there are a couple more screws where the front trim panel was then it can be removed.
I have likely missed something it is pretty self explanatory when you get in there. I have included a couple of pics to help a bit.
I don't know when the change was to make this a lot easier I just purchased it a month ago so I am still learning if anybody has anything to add please do.
John
Name:	Window leak repair 033.jpg
ID:	112183   Click image for larger version
Name:	Window leak repair 036.jpg
Name:	Window leak repair 037.jpg
Old 10-04-2010, 10:54 AM   #13
John,
Thanks for the write up! This will no doubt come in handy when I tear into the A/C on our 74 Argosy.
Old 10-05-2010, 08:30 PM   #14
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
WOW john, didnt know you dug in that deep! I had my rooftop blower motor go bad. I went to our local electric motor shop and the found me a replacement unit. there's a million sizes and shapes of those motors so a good shop should be able to source something with the same specs
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Dash blower motor heat/air James Rogers Classic Motorhomes 11 10-30-2010 07:29 AM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
NT-30 blower motor mojofilter Furnaces, Heaters, Fireplaces & Air Conditioning 8 06-24-2009 06:05 AM
Dash AC blower motor PeterH-Airstreamer Airstream Motorhome Forums 6 07-15-2003 06:01 AM
