Old 10-06-2010, 06:50 PM   #15
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
I fixed the blower fan today it had been bent somehow it runs true now so it doesn't vibrate know. I also found a mouse nest when I pulled everything apart I now know where the smell was coming from it was 12 inches long and 6 inches deep right on top of the heater box.
This all started with a leak in the drivers side window that was leaking between the alum side panel and the trim panel. And saturating the plywood below the drivers seat I have replaced the plywood and I am going to put a drain tube in the window frame to drain the water to the outside.The drain hole was drilled to close to the edge of the frame and any water would drip between the 2 inside panels and seep under the carpet unnoticed and keep the plywood wet forever
Name:	Window leak repair 021.jpg
ID:	112567   Click image for larger version
Name:	Window leak repair 011.jpg
shepherd57 is offline   Reply With Quote
Old 10-16-2010, 03:03 PM   #16
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Thanks for the pics, nice to know what's in there
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Dash blower motor heat/air James Rogers Classic Motorhomes 11 10-30-2010 07:29 AM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
NT-30 blower motor mojofilter Furnaces, Heaters, Fireplaces & Air Conditioning 8 06-24-2009 06:05 AM
Dash AC blower motor PeterH-Airstreamer Airstream Motorhome Forums 6 07-15-2003 06:01 AM
