Old 02-23-2016, 02:40 AM   #225
1978 28' Argosy 28
Broken Arrow , Oklahoma
The AT 545 is a giant slush box. They have no lockup in the converter and I believe that motor/pump combo is governed at 2700rpm. It starts defueling at about 2300 rpm. That can all be changed though. I'm assuming this is a mechanical inj. motor.
A better combo would be a 24v electronic inj. and Allison 1000 from a small frieghtliner.
Chevyboy123 is offline   Reply With Quote
Old 02-27-2016, 03:05 PM   #226
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I found the key!
It was one of about 25 on the donor key ring, so the cover should be on the way to you soon Ben.
martin300662 is offline   Reply With Quote
Old 02-29-2016, 08:07 AM   #227
1978 28' Argosy 28
Thanks Martin! I owe you!
bpg_austin is offline   Reply With Quote
Old 03-30-2016, 10:49 AM   #228
1978 28' Argosy 28
Took me forever to post this, but a massive thanks to Martin for sending me the generator cover off his parts Argosy. Its GREAT. Fits right in where the old one was and the paint even matches. I don't know where I would have ever found another one. So, here's me, at the exact same campsite and park that I lost the cover about 6 months ago. And.. ta-da.. there's a nice genny cover still attached to the moho. Its the little things..
Time to add that extra latch now before I put on too many miles.
Ben
Old 03-30-2016, 11:04 AM   #229
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Ben
Glad you could put it to use Ben - better there than getting crushed!
Old 03-30-2016, 11:11 AM   #230
It doesn't get any better than that
Ben
I'm surprised you drove without having the extra latch! I would have put that cover in my safety deposit box at the bank until I had a second latch ready to go
bkahler is online now   Reply With Quote
Old 03-30-2016, 11:34 AM   #231
1978 28' Argosy 28
[QUOTEI'm surprised you drove without having the extra latch! I would have put that cover in my safety deposit box at the bank until I had a second latch ready to go [/QUOTE]
LIFE ON THE EDGE!
Old 03-30-2016, 11:50 AM   #232
LIFE ON THE EDGE!
Old 04-09-2016, 03:06 PM   #233
1977 28' Argosy 28
dexter , New York
Here's a trick I discovered a while back RMS drop the pan as far as you can now unbolt the oil pump drop it in the pan most every time the pan wiggles right out .
jonesy 1 is offline   Reply With Quote
Old 05-16-2016, 04:37 AM   #234
1978 28' Argosy 28
Jonsey, great tip. Wish I had tried that last spring. Probably would have saved me about 40 hours of headache. But I DO have new motormounts because of the long way around.
Help topic of the day: Blower motor. If anyone has a part number I'd appreciate it. Mines shot and there's no apparent markings to get a new one. Seems to be a pretty generic 12v motor. Just don't know the amperage.
Also, if anyone remembers, I almost have the headlight situation solved. One of the wires that leads to the hi/low dimmer switch was pulled out. My 2 year old did a number on it. The contact was pulled, reinserted, cleaned and.. headlights. Now I just have a dim right side headlight and the brights don't work on that side either. I'll be pulling the lights all out to check connections there as well. However I'm one solid step closer to driving in the dark again. whoop!
Steering column. Ughh.. Its almost out of the motorhome now for evalutaion. Pretty sure a 'new' one will be in order. PITA job. Updates coming shortly, when it stops raining again here in central TX.
Ben
ID:	262608   Click image for larger version
Old 05-16-2016, 05:25 AM   #235
1978 28' Argosy 28
http://www.rockauto.com/en/catalog/c...wer+motor,6916
MM... part 35478 (four seasons blower motor for $46.79) appears to be correct. However it has the 3rd wire which mine does not have. A green one. Is this an extra ground? Look like the right part to you guys?
Old 05-16-2016, 05:27 AM   #236
Ben, I wouldn't worry about amperage or part number. Find a generic blower motor that will physically fit, runs the right direction and use it. Small DC motors of that style will have about the same current rating.
Check out this place that sells older motorhome AC parts. I bought some vacuum motors from him several years ago that worked for my Argosy.
If a motor has 2 shafts and you only need one then cut the one off that you don't need.
Old 05-16-2016, 12:01 PM   #237
1978 28' Argosy 28
Done. E-bay, $28 bucks shipped.
Old 05-16-2016, 04:03 PM   #238
That's cheap!
Ben and Lynn's Bambi II Re-do PA BAMBI II 1964 Bambi II 122 05-12-2017 08:11 PM
Ben's Bed :: 1994 Airstream Sovereign kmaggard Airstream Registry Discussions 0 06-20-2013 08:20 PM
