Old 02-15-2016, 05:10 PM   #211
Originally Posted by bkahler View Post
I'm betting you find a better way to fasten it to the trailer....
Oops, meant motorhome not trailer
Old 02-15-2016, 09:27 PM   #212
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
zip dee awning hook
1983 310 Classic Motorhome
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 02-16-2016, 08:24 AM   #213
Originally Posted by PeterH-Airstreamer View Post
zip dee awning hook
Peter, do they make the hooks in RH and LH configuration?
Old 02-16-2016, 08:51 PM   #214
Airstream Driver
1997 30' Excella
Images: 51
Yeah, by flipping them...
But, I have to give it to you, you got me thinking real hard, since i had one one both sides.
AIR #13
Old 02-17-2016, 05:06 AM   #215
The reason I asked is it sorta looks like the hook is a one piece unit. If you can flip it then it must be a separate spacer that makes the hook stand off the hatch.
Old 02-17-2016, 05:54 AM   #216
Airstream Driver
1997 30' Excella
Images: 51
that would be true. But I looked at a another hook I have and it looks different and could only be used on the left, unless you would latch it from the bottom on the right. No telling where I got the hooks i used in 2002
AIR #13
Old 02-17-2016, 07:30 AM   #217
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Hey Ben, just a heads-up; I haven't mailed the cover as yet because it has a lockable latch, and I don't have the key!
I assumed it was the same as the other lower compartment covers (which are now installed on Bella), but my key for Bella's covers doesn't work on that latch. ASNE are searching at their end to see if there is a second key somewhere - may take a few days.
martin300662 is offline   Reply With Quote
Old 02-17-2016, 07:51 AM   #218
I would imagine the key from your donor cover is the same as the cover that was on Ben's coach. I found the keys for the rectangular twist handles on the compartments of the 84 310 and the 86 345 were the same.
If Ben has his old key I bet it will work
Old 02-17-2016, 07:52 AM   #219
1978 28' Argosy 28
Martin, I never thought of that! I'm in absolutely no rush on the cover. I"m currently working on the steering, so the motorhome isn't going anywhere for at least a month or two.
No worries even in the key can't be found. I can source out another fastening device if needed. Though I certainly appreciate the shop doing a sweep for an extra key!
edit: Brad, I've got a host of keys for my Argo. We could be in business here with a little luck.
bpg_austin is offline   Reply With Quote
Old 02-17-2016, 07:55 AM   #220
I'm always forgetting where I got something so I know how that feels
Old 02-17-2016, 11:01 AM   #221
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I am a little surprised as the same latch is on the donor lower compartment covers, so I thought would be the same key. The latch actually works fine, just without the key is not able to be locked closed.
ASNE moved two of the lower compartment covers from the donor to Bella - one covers the propane so can not be lockable (for safety reasons), the other covers the batteries so can be locked (and includes a cubbie for the Zamp extension cable, etc so I am glad it does!)
Old 02-17-2016, 11:11 AM   #222
The lower compartment keys for the 310 & 345 were not the same as the generator compartment covers. I never did check the two generator locks to see if they were the same as I never locked the generator cover. Since it was hinged I saw no need to lock it.
Old 02-17-2016, 08:38 PM   #223
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
hmm, on ours it's a Chicago Lock 1101X.
ymmv!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 02-19-2016, 02:51 AM   #224
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Going back few pages there was a discussion about replacement engines and transmissions. I suggested state and local government auctions for old school buses. I just noticed this one.
OWNING AGENCY STATES :
Cummins 6BTA 180 HP engine - (replaced 3/21/06 at 170,462 miles, 23,708 miles on this engine) No Known Issues
Allison AT 545 transmission - Automatic (replaced 5/6/02 at 150,595 miles, 43,575 miles on this transmission), No Known Issues
No known Issues
No oil, coolant or diesel leaks.
Interior is average or above (no tears in seats)
Front Tires 15/32 (Spare 6/32)
Rear Tires 9/32
BUDD wheels
2 Additional Rims
Being sold because depreciation schedule is complete.
There is about 17 hours left on the auction and the bid is $1875. It would make nice low mileage transplant. You do have to have room for the bus while you are removing the engine and trans.
Cheers, Dan
~ Margaret Thatcher ~
Ben and Lynn's Bambi II Re-do PA BAMBI II 1964 Bambi II 121 05-22-2016 08:56 PM
Ben's Bed :: 1994 Airstream Sovereign kmaggard Airstream Registry Discussions 0 06-20-2013 09:20 PM
